I was just referring to this page - air-quality-charts.php. I did not see it on your site. The data is working fine.
ha i see , i dont have purple air , my airlink i sniff via an old hacked dd-wrt router , same for my indoor nova .i dont use meteobridge for air quality in fact in comparison the airlink and nova i dont see much of difference when i had both outside .i think what you see on mine is a personal thing nothing todo with meteobridge output. im still on firmware 4.2 :-)
i use the dd-wrt router for most wireless gadgets that try to send somewhere over local network the just redirect to ip address or local server.. a google search will reveal the world of dd-wrt but not for the light hearted..
weatherist34 wrote: Sat Dec 26, 2020 9:02 pm ha i see , i dont have purple air , my airlink i sniff via an old hacked dd-wrt router , same for my indoor nova .i dont use meteobridge for air quality in fact in comparison the airlink and nova i dont see much of difference when i had both outside .i think what you see on mine is a personal thing nothing todo with meteobridge output. im still on firmware 4.2 :-)
Ok, that explains it. Yes, I have used dd-wrt and Tomato. The meteobridge output with the Airlink has worked fine for me. I am not on the latest firmware, but I did add Airlink as a second station when I first set it up.
garybridge
Post by garybridge »
weatherist34 wrote: Sat Dec 26, 2020 8:27 pm sincere apologies just came back 4 hours later only to find the file had not uploaded so you may have downloaded and you probably 99% got the early version that was sent out to a few testers the latest download contains all required files some were missing in earlier test download. sincere heartfelt apologies.. hint mr whaleybridge :-)
Brian
Mr WhaleyBridge is very confused now Brian... I had a look at Mark 2 decided I liked it, and installed that, but I’m sure I’ve goofed somewhere.. :roll:
Gary Bridge MIET, MIPS.
good morning Gary
just run this simple update I think you may have got the early test version as I mentioned above unknown to me the release upload had stalled and I did not realize till some 4 hours later . Aurora-MKII-simple-update-27-12-2020.zip use in identical way of original aurora version.
https://www.mediafire.com/file/ta9id4ny ... 0.zip/file
just contains those files that were not updated or missing and attempts to offer a better resolution for the pressure drop when greater than -15 as I saw in the UK there a impressive pressure drop in 24 hours . .
looking at your site think you need to just copy over your 2020.csv file from previous version into the weather34charts folder and also place the December.csv inside the weather34charts/2020/ folder apart from that I dont see anything but your better to be the judge of that.
have a good day.
It looks like there maybe some updated files missing on GIT. I noticed in the update zip package - console-settings, console-dark/light, livedata, weather34-logo-small, barometer-modmmHG, windmod - the ones I noticed.
Take care,
garybridge
weatherist34 wrote: Sun Dec 27, 2020 9:21 am good morning Gary
have a good day.
Thanks Brian, have just come inside from being up a ladder trying to get the webcam setup... It’s bloody Baltic up there. You get to know when the Lord doesn’t want you to have success, when it doesn’t work once it’s up... Light on back of camera on, ( POE working ) but network switch shows no data. Having described to Mrs B what a Lan cable tester looks like and where she might find it, discovered pair 1-2 broken 😡. Brand new out of the bag. WTF did I not test the cable before I put it in? Because in my entire career I must have put in 10’s of thousands of moulded network cables and have never had a dodgy one...I have found many 100’s of dodgy home made ones and in a Radio Station in Bradford the best I could get out of any network connection was less than 100 megs because every single cable had been crimped In pair order with no crossovers...
Have now replaced the new cable with another new one that I tested before I got the ties and cable clips out again.....
Hummppphh..
Decided to give MKII a whirl. I used the latest download and the Dec. 27 update. A couple of issues:
The side menu is missing some icons and I think there is a path issue with the Forecast link at the top.
Best wishes,
@Chuck try downloading the update and run I just uploaded
I saw these this morning but unfortunately our internet as only just come back(7:30pm) so there was nothing I could do to correct it.beware things may just go a bit wonky in non metric :-)
No problem. That fixed it other than a slight padding issue on the top bar and oddly the path to the Forecast on the top bar is /console/console/outlookwu.php rather than /console/outlook/php.
garybridge wrote: Sun Dec 27, 2020 5:41 pm
have a good day.
Hummppphh..
webcam outside for weather sometimes just quicker to look out the window :-) but i get it each to their own ..
and no baltic here mate the currant bun was out all day...😁 but hoping for some Cynthia Payne soon ..😁 sez just having watched another only fools and horses this afternoon ... for those curious im talking in cockney slang 😁.. being a southern shandy drinking bastad as the northerners would put it ..
prestwickwx wrote: Sun Dec 27, 2020 7:09 pm Brian,
miss that one just fixed it ..
garybridge
weatherist34 wrote: Sun Dec 27, 2020 7:19 pm
have a good day.
Hummppphh..
That's all looking a lot better now thanks Brian,
I had a bit of a scare as when I came to restore the data from the backup there was no data in the Zip file that I had downloaded from my hosting site. I went back and checked the last 4 I had done they are all the same A zip file yes with correct times and dates but an empty zip file.
I have absolutely no idea why or how ( file locking perhaps?), but if you are interested I can attempt to show you. This might affect others?
Fortunately I have a daily back up done by my host so easy to fix.
I thought you came from Chesterfield sort of way ? Or was that just work that took you there?
G
weatherist34 wrote: Sun Dec 27, 2020 7:42 pm
Got it.
@Gary ok must be a local server config issue your end normally points to a disabled or missing php module not seeing anything in my emails about that as an issue.but who knows??
I lived in Matlock Derbyshire for almost 10 years a very sleepy place back then with nothing else todo but drink local bitter it was a way of life there a good life and good people !! locals named me Del Boy because of my accent and gift of gab for selling , all legit :-)
apart from a short stint of 9 months living in a hotel in Livingstone Scotland which I couldn't wait to get away . I was born in Dorset and as a wee child we moved to East Malling Kent and I grew up in lived and worked majority of my life in UK in Kent with a year gap in Bowers Gifford Essex before moving back to Kent and then moving to Turkey 14 years ago..there we are my life story :-)
Don't feel the need to use this MKII version it was purely compiled to my own preference was never really intended to be a release just interest grew in recent days . So there may be a few quirks hidden in there ..
FWIW Im going to go very quiet for a few weeks I have taken on a private job for a tv personality here so I won't be on hand to deal with any issues that arise so be safe and if things don't work out use the original Aurora version and at some stage ill pick up the pieces and deal with them..
@chuck I see the /console/ I just removed that..
