Page 3 of 3
Re: WXSIM - Meteobridge Pro
Posted: Sun Oct 06, 2019 5:19 am
by hrvistaweather
Just had change to DST this morning, at 02: clocks forward (1) Hour to 03:00.
For some reason my Davis Console never changed (it used to for years when plugged into my PC but did not this morning (as plugged into my Meteobridge Pro Red).
Anyway manually set time on Davis Console and all OK.
What I did find was that the append script for cumulus export I have been using (by Bernd) because of the above issue I assume did not record the 01:00 to 01:59 period. resulted in below :
06/10/19,00:53,12.2,86,9.9,3.2,4.7,326,0.0,0.0,1014.5,0,21.3,44,4.7,12.2,12.2,0.0,0,0,0,0,0,0,0,0,0,
06/10/19,00:54,12.2,86,9.9,3.2,8.0,319,0.0,0.0,1014.5,0,21.3,44,8.0,12.2,12.2,0.0,0,0,0,0,0,0,0,0,0,
06/10/19,00:55,12.2,86,9.9,3.2,8.0,319,0.0,0.0,1014.6,0,21.3,44,8.0,11.9,12.2,0.0,0,0,0,0,0,0,0,0,0,
06/10/19,00:56,12.2,86,9.9,4.5,4.7,296,0.0,0.0,1014.6,0,21.3,44,4.7,12.2,12.2,0.0,0,0,0,0,0,0,0,0,0,
06/10/19,00:57,12.2,86,9.9,4.7,11.3,314,0.0,0.0,1014.6,0,21.3,44,11.3,12.0,12.2,0.0,0,0,0,0,0,0,0,0,0,
06/10/19,00:58,12.1,86,9.8,4.7,11.3,320,0.0,0.0,1014.5,0,21.3,44,11.3,12.1,12.1,0.0,0,0,0,0,0,0,0,0,0,
06/10/19,00:59,12.1,86,9.8,4.7,11.3,320,0.0,0.0,1014.5,0,21.3,44,11.3,12.1,12.1,0.0,0,0,0,0,0,0,0,0,0,
06/10/19,03:00,11.8,88,9.9,0.0,1.4,301,0.0,0.0,1012.5,0,20.7,45,1.4,11.9,11.8,0.0,0,0,0,0,0,0,0,0,0,
06/10/19,03:01,11.8,89,10.0,0.0,0.0,301,0.0,0.0,1012.5,0,20.7,45,0.0,11.8,11.8,0.0,0,0,0,0,0,0,0,0,0,
06/10/19,03:02,11.8,89,10.0,0.0,0.0,301,0.0,0.0,1012.5,0,20.7,45,0.0,11.8,11.8,0.0,0,0,0,0,0,0,0,0,0,
06/10/19,03:03,11.8,89,10.0,0.0,0.0,301,0.0,0.0,1012.5,0,20.7,45,0.0,11.8,11.8,0.0,0,0,0,0,0,0,0,0,0,
06/10/19,03:04,11.7,89,9.9,0.0,1.4,301,0.0,0.0,1012.4,0,20.7,45,1.4,11.7,11.7,0.0,0,0,0,0,0,0,0,0,0,
06/10/19,03:05,11.7,89,9.9,0.0,0.0,301,0.0,0.0,1012.4,0,20.7,45,0.0,11.7,11.7,0.0,0,0,0,0,0,0,0,0,0,
06/10/19,03:06,11.7,89,9.9,0.0,0.0,301,0.0,0.0,1012.4,0,20.7,45,0.0,11.7,11.7,0.0,0,0,0,0,0,0,0,0,0,
06/10/19,03:07,11.7,89,9.9,0.0,3.2,307,0.0,0.0,1012.4,0,20.7,45,3.2,11.7,11.7,0.0,0,0,0,0,0,0,0,0,0,
Also not sure if anyone can help with an earlier question :
"I have tried many was to achieve this one minute monthly output and one thing I would need to do is export historic (previous) Monthly Logs (in one Minute Resolution).
The stumbling block being inability to export monthly data in minute resolution."
Kind Regards,
Tony
Posted: Sun Oct 06, 2019 9:49 am
by thunderstorm
Hi Tony,
not sure what happened during the DST switch, but regarding accumulated rain-total: Looks like for data exports yearsum/daysum takes only the selected data-period into account (sums up the values and groups it by year or date), which isn't helpful for the wxsim support (see here).
I've a separate (email) thread with Boris and Tom so sort this out.
Bernd
Posted: Sun Oct 06, 2019 5:38 pm
Yes, rain totals are just computed for the requested time period. When you try to get around the 72h limitation of available data in 1 minute resolution by polling every hour data from it and by appending these snippets, rain-totals will not sum up in the export file over the day or month.
When you decide to go with hourly data you can get the current month in one request and the sums will work fine.
Posted: Sun Oct 13, 2019 9:17 pm
by hrvistaweather
Hi Bernd and Boris,
Thanks for all your help, however due to the inability to produce the accumulated Rain Totals in less than 1 hourly format etc. I have elected to go back to using CumulusMX (TCP/IP connection set to the ip-address of the Meteobridge Pro and the Port Number 22222) for now until a possible resolve may be found, without Tom having to re-script WXSIM for a different input format.
Kindest Regards,
Tony
Posted: Sun Oct 20, 2019 3:53 pm
I still don't see why a per minute data resolution is needed when doing forecasts, but may be I don't understand enough on that.
Posted: Thu Oct 31, 2019 8:49 pm
by thunderstorm
Right now I'm using following solution, that unfortunately doesn't include historical data with a resolution resolution less than an hour.
I schedule a ftp template upload every 5min to my webspace (you could choose a different schedule and vary the avg-selector)
#if#{*[th0hum-avg5.0:]>0*}#then#[DD]/[MM]/[YY],[hh]:[mm],[th0temp-avg5.1:],[th0hum-avg5.0:],[th0dew-avg5.1:],[wind0wind-avg5=mph.1:],[wind0wind-max5=mph.1:],[wind0dir-avg5.0:],[rain0rate-avg5.1:],[rain0total-daysum.1:],[thb0seapress-avg5.1:],[rain0total-yearsum.1:],,,,,,,[sol0rad-avg5.0:],,#else##[DD]/[MM]/[YY],[hh]:[mm] - no data#fi#
And download it with a script right after the upload to append it to a monthly log
#!/bin/sh
TARGET="/tmp/mnt/data/export/`date '+%b.%y'`log.txt"
URL="http://<...>/c`date '+%Y%m%d%H%M'`.txt"
wget -O - $URL >>$TARGET
exit 0
Not the best solution ever, especially since it requires an internet connection (I don't want to run an additional local ftp/http server), but it works for now.
Maybe Boris can provide a smoother integration at some point - knowing he's super busy :D
Best,
Bernd
