Page 3 of 102
Posted: Tue Nov 03, 2020 7:57 pm
by prestwickwx
OK. All fixed!
Posted: Wed Nov 04, 2020 11:40 am
by weatherist34
Chuck there are new files pushed and a new setup option to select where the Airlink is located if it is selected as indoors then this is the appearance of Indoor screen . if outside it shows original indoor screen without air quality .
- ql.jpg (142.76 KiB) Viewed 7406 times
Posted: Wed Nov 04, 2020 3:30 pm
by prestwickwx
Ok. I am testing out the new option. When I select Inside I get the module you have shown - looks great. If I select Outside the Indoor Icon in the Legend disappears.
Posted: Wed Nov 04, 2020 3:58 pm
by weatherist34
ok I see ive simplified the option output in the index file to which file it points too and also added extra css so those without air quality will see same screen layout as per original ..beauty of CSS Grid
- airlw1.jpg (240.39 KiB) Viewed 7389 times
Posted: Wed Nov 04, 2020 4:13 pm
by prestwickwx
Ok. That fixed the problem. Works fine both ways!
Nice to have all of the Indoor data together.
I made one little edit to include my lightning.
Posted: Wed Nov 04, 2020 4:17 pm
by weatherist34
probably easier all round i dont know of many who actually use the same lightning setup as us , mine still churning away via a 2016 tplink mr3020 ..
Posted: Wed Nov 04, 2020 4:24 pm
by prestwickwx
Yes. No need for a major option. Easy edit and who knows how long the WF will last.
Posted: Thu Nov 05, 2020 9:06 am
by weatherist34
First batch of replies was sent this morning ..please read the email it might save you a lot of time and inconvenience .
Thank you for your request.Your password below to download the weather34 Aurora template password is valid until
Monday 16th November 2020.(
the password changes every Monday automatically ive set it to 16th November but after that it will revert to every Monday hence most replies go out at beginning of week rarely do I respond on a weekend as the password will expire in a day or two..)
Please note this version is English only it does not support other languages, so please think about this before using this version.
If you have used a previous version example 9.34 remember to back up your history data found in the weather34charts folder.If you don’t it will be lost forever and not recoverable.
This version is a full install you will need to apply the new settings.
Alternatively if you are upgrading from 9.34xx or earlier there will be a simple upgrade file release soon.So again think before installing this version.
Your Password is
Something out of this world
follow the setup guide once installed on your server
we are in debt to chuck for his observations and support to have this release up and running.
Posted: Thu Nov 05, 2020 3:13 pm
by prestwickwx
Hope all is well. The latest update has a small issue with the webcam icon. Everything else looks great!
- Capture.PNG (8.64 KiB) Viewed 7325 times
Best wishes,
Posted: Thu Nov 05, 2020 4:19 pm
by xray77
Hello, Brian,
Two exciting events:
- once the US elections
- second the waiting for the download code for Aurora...
has some similarities...
I don't know how much longer my nerves can take this...
stay healthy,
best regards
Mike
Posted: Thu Nov 05, 2020 5:00 pm
by prestwickwx
prestwickwx wrote: Thu Nov 05, 2020 3:13 pm
Best wishes,
All fixed!
Posted: Fri Nov 06, 2020 2:27 pm
by xray77
Hello Brian,
If the default path to MBrealtimeupload.txt is not used, the update time at the top of the header is incorrect.
- Bildschirmfoto 2020-11-06 um 13.19.56.png (14.79 KiB) Viewed 7276 times
The associated script evaluates only the upload time of MBrealtimeupload.txt in the standard directory. if i copy the actual file MBrealtimeupload.txt to the standard-directory, also the update-time is actualized.
- Bildschirmfoto 2020-11-06 um 13.19.37.png (62.39 KiB) Viewed 7276 times
Is it still possible to adapt it, so that the real associated path to MBrealtimeupload.txt is also considered to update the upload time? The displayed data on the screen are updated correctly (e.g. every 30 seconds on my setup).
I assume that the air quality graphics will be activated in later versions, when the MB-API has been adapted?
Otherwise Aurora is a really nice update, thank you very much for your work!
Best regards and stay healthy,
Mike
Posted: Fri Nov 06, 2020 3:07 pm
by weatherist34
The API path for meteobridge has always been the same Ive not changed anything in that respect in this version or any previous versions .your using a path that drives a previous version also ?? this I cant replicate locally as everything is using default developed path..
API values were updated a few days ago by Boris along with a quick update file released late this afternoon for all AQI stuff with the help of Graham.. ..
these were unified timestamps and time formats and Davis Air Quality averages.
see here for working references for AIR QUALITY from Graham at
http://ringwoodweather.ddns.net/Aurora/index.php
I might be able to help you next week sometime unfortunately this weekend Im having repairs done on our roof before the winter kicks in so Im pretty much pre-occupied until Monday ..
Brian ..
Posted: Fri Nov 06, 2020 3:41 pm
by xray77
yes, I use the API path of the previous version 3.x..
(See the screenshot in the previous post)
On this "old" path current MBrealtimeupload.txt will be stored in the mbridge folder every 30 seconds.
In the aurora-mbridge folder there is only an old MBrealtimeupload.txt file.
It seem's so the script, which generates the update time, apparently only looks at the creation date of the MBrealtimeupload.txt file in the /Aurora/mbridge-folder. But the current MBrealtimeupload.txt is not there, but in the other "old" mbridge folder.
The live-data for Aurora are updated correctly, so the path given in the setup is used for the MBrealtimeupload.txt saved in "old" location..
Please don't hurry, its no critical thing... all other works great!
I wish you good luck with the roof repair!
best regards
Mike
Posted: Fri Nov 06, 2020 3:43 pm
by prestwickwx
Just applied the latest updates. I noticed one thing on the Davis Air Quality. The 24 hour average values seem very high. My unit has not reported a value as high as 66. On second thought - these may be coming from the new API values and I have not rebooted meteobridge
Update: Rebooted to get new API values and all is well.
- Capture.PNG (64.1 KiB) Viewed 7260 times
After reboot of Meteobridge - New API values:
- Capture2.PNG (52.94 KiB) Viewed 7250 times
Good luck with your roof!
