MB keeps losing contact with Loggers.
Re: MB keeps losing contact with Loggers.
As far as I can see with netstat there is no flooding of sockets with CLOSE_WAIT state anymore. So this has been fixed.
However, there still is a problem that the logger process cannot generate new sockets. I added code to better understand this.
Lets see what it tells when it now runs into this problem.
Situation can be cured by restarting the logger process. Therefore, as a last option this can be triggered by the error message.
But this is more a work around than a solution. I still prefer to find a solution within the code.
davidmc36
Post by davidmc36 »
Quit just a bit ago.
command: netstat -pa
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      2267/wsdd2
tcp        0      0 0.0.0.0:netbios-ssn     0.0.0.0:*               LISTEN      1318/smbd
tcp        0      0 0.0.0.0:22222           0.0.0.0:*               LISTEN      1762/loggerd
tcp        0      0 0.0.0.0:5551            0.0.0.0:*               LISTEN      1762/loggerd
tcp        0      0 0.0.0.0:22223           0.0.0.0:*               LISTEN      1762/loggerd
tcp        0      0 0.0.0.0:5552            0.0.0.0:*               LISTEN      1762/loggerd
tcp        0      0 0.0.0.0:22224           0.0.0.0:*               LISTEN      1762/loggerd
tcp        0      0 0.0.0.0:www             0.0.0.0:*               LISTEN      699/uhttpd
tcp        0      0 0.0.0.0:5553            0.0.0.0:*               LISTEN      1762/loggerd
tcp        0      0 0.0.0.0:5554            0.0.0.0:*               LISTEN      1762/loggerd
tcp        0      0 0.0.0.0:5556            0.0.0.0:*               LISTEN      1762/loggerd
tcp        0      0 0.0.0.0:5557            0.0.0.0:*               LISTEN      1762/loggerd
tcp        0      0 192.168.2.59:domain     0.0.0.0:*               LISTEN      495/dnsmasq
tcp        0      0 localhost:domain        0.0.0.0:*               LISTEN      495/dnsmasq
tcp        0      0 0.0.0.0:3702            0.0.0.0:*               LISTEN      2267/wsdd2
tcp        0      0 0.0.0.0:ssh             0.0.0.0:*               LISTEN      536/dropbear
tcp        0      0 0.0.0.0:5559            0.0.0.0:*               LISTEN      1762/loggerd
tcp        0      0 0.0.0.0:microsoft-ds    0.0.0.0:*               LISTEN      1318/smbd
tcp        0      0 192.168.2.59:57166      gollum.meteobridge.com:www ESTABLISHED 2917/ssh
tcp        0    162 192.168.2.59:www        192.168.2.11:57817      ESTABLISHED 699/uhttpd
tcp      388      0 192.168.2.59:47212      192.168.2.90:22222      ESTABLISHED 1762/loggerd
tcp        0      0 192.168.2.59:www        192.168.2.11:57808      TIME_WAIT   -
tcp        0      0 192.168.2.59:www        192.168.2.11:57807      TIME_WAIT   -
tcp     1078      0 192.168.2.59:47402      192.168.2.58:22222      ESTABLISHED 1762/loggerd
tcp        0      0 192.168.2.59:www        192.168.2.11:57805      TIME_WAIT   -
tcp        0      0 :::netbios-ssn          :::*                    LISTEN      1318/smbd
tcp        0      0 :::5355                 :::*                    LISTEN      2267/wsdd2
tcp        0      0 :::www                  :::*                    LISTEN      699/uhttpd
tcp        0      0 fe80::ba27:ebff:febe:2e39:domain :::*                    LISTEN      495/dnsmasq
tcp        0      0 localhost:domain        :::*                    LISTEN      495/dnsmasq
tcp        0      0 :::ssh                  :::*                    LISTEN      536/dropbear
tcp        0      0 :::3702                 :::*                    LISTEN      2267/wsdd2
tcp        0      0 :::microsoft-ds         :::*                    LISTEN      1318/smbd
udp        0      0 192.168.2.59:domain     0.0.0.0:*                           495/dnsmasq
udp        0      0 localhost:domain        0.0.0.0:*                           495/dnsmasq
udp        0      0 0.0.0.0:3702            0.0.0.0:*                           2267/wsdd2
udp        0      0 192.168.2.255:netbios-ns 0.0.0.0:*                           1319/nmbd
udp        0      0 192.168.2.59:netbios-ns 0.0.0.0:*                           1319/nmbd
udp        0      0 0.0.0.0:netbios-ns      0.0.0.0:*                           1319/nmbd
udp        0      0 192.168.2.255:netbios-dgm 0.0.0.0:*                           1319/nmbd
udp        0      0 192.168.2.59:netbios-dgm 0.0.0.0:*                           1319/nmbd
udp        0      0 0.0.0.0:netbios-dgm     0.0.0.0:*                           1319/nmbd
udp        0      0 0.0.0.0:mdns            0.0.0.0:*                           746/avahi-daemon: r
udp        0      0 0.0.0.0:5355            0.0.0.0:*                           2267/wsdd2
udp        0      0 fe80::ba27:ebff:febe:2e39:domain :::*                                495/dnsmasq
udp        0      0 localhost:domain        :::*                                495/dnsmasq
udp        0      0 :::3702                 :::*                                2267/wsdd2
udp        0      0 :::mdns                 :::*                                746/avahi-daemon: r
udp        0      0 :::5355                 :::*                                2267/wsdd2
Active UNIX domain sockets (servers and established)
Proto RefCnt Flags       Type       State         I-Node PID/Program name    Path
unix  2      [ ACC ]     STREAM     LISTENING       3345 746/avahi-daemon: r /var/run/avahi-daemon/socket
unix  2      [ ACC ]     STREAM     LISTENING       3103 222/ubusd           /var/run/ubus.sock
unix  2      [ ]         DGRAM                      2667 1318/smbd           /var/lock/msg.sock/1318
unix  13     [ ]         DGRAM                      3184 398/logd            /dev/log
unix  2      [ ]         DGRAM                      2674 1458/smbd           /var/lock/msg.sock/1458
unix  2      [ ]         DGRAM                      2419 604/wpa_supplicant  /var/run/wpa_supplicant/global
unix  2      [ ]         DGRAM                      3497 1319/nmbd           /var/lock/msg.sock/1319
unix  2      [ ACC ]     STREAM     LISTENING       3514 1319/nmbd           /var/run/samba/nmbd/unexpected
unix  2      [ ]         DGRAM                      3524 1459/smbd           /var/lock/msg.sock/1459
unix  2      [ ]         DGRAM                      3290 603/hostapd         /var/run/hostapd/global
unix  2      [ ACC ]     STREAM     LISTENING       3320 722/dbus-daemon     /var/run/dbus/system_bus_socket
unix  3      [ ]         STREAM     CONNECTED       3294 222/ubusd           /var/run/ubus.sock
unix  3      [ ]         STREAM     CONNECTED       3293 603/hostapd
unix  2      [ ]         DGRAM                      3340 746/avahi-daemon: r
unix  3      [ ]         STREAM     CONNECTED        418 722/dbus-daemon     /var/run/dbus/system_bus_socket
unix  3      [ ]         STREAM     CONNECTED       3347 746/avahi-daemon: r
unix  2      [ ]         DGRAM                      3105 222/ubusd
unix  3      [ ]         STREAM     CONNECTED       3186 398/logd
unix  3      [ ]         STREAM     CONNECTED       3187 222/ubusd           /var/run/ubus.sock
unix  2      [ ]         DGRAM                      3287 603/hostapd
unix  2      [ ]         DGRAM                      3231 536/dropbear
unix  3      [ ]         STREAM     CONNECTED        414 722/dbus-daemon
unix  3      [ ]         STREAM     CONNECTED        413 722/dbus-daemon
unix  3      [ ]         STREAM     CONNECTED       3106 222/ubusd           /var/run/ubus.sock
unix  3      [ ]         STREAM     CONNECTED        280 1/procd
unix  2      [ ]         DGRAM                       284 1/procd
unix  2      [ ]         DGRAM                      3494 1319/nmbd
unix  2      [ ]         DGRAM                      4626 495/dnsmasq
unix  3      [ ]         STREAM     CONNECTED        408 222/ubusd           /var/run/ubus.sock
unix  2      [ ]         DGRAM                     12493 2267/wsdd2
unix  3      [ ]         STREAM     CONNECTED       4675 699/uhttpd
unix  3      [ ]         STREAM     CONNECTED       4622 495/dnsmasq
unix  3      [ ]         STREAM     CONNECTED       3216 222/ubusd           /var/run/ubus.sock
unix  2      [ ]         DGRAM                      4623 495/dnsmasq
unix  2      [ ]         DGRAM                      2416 604/wpa_supplicant
unix  3      [ ]         STREAM     CONNECTED       3296 222/ubusd           /var/run/ubus.sock
unix  3      [ ]         STREAM     CONNECTED       2422 604/wpa_supplicant
unix  3      [ ]         STREAM     CONNECTED       3302 222/ubusd           /var/run/ubus.sock
unix  3      [ ]         STREAM     CONNECTED       2427 646/netifd
unix  2      [ ]         DGRAM                      2425 646/netifd
unix  3      [ ]         STREAM     CONNECTED       2371 430/rpcd
unix  3      [ ]         STREAM     CONNECTED       3194 222/ubusd           /var/run/ubus.sock
unix  2      [ ]         DGRAM                      2501 646/netifd
unix  2      [ ]         DGRAM                      2657 1318/smbd
logger (19.04.2024 22:17:45): station 1 (Vantage), firmware version request sent.
logger (19.04.2024 22:17:45): station 0 (Vantage), firmware version 3.62 (supports LOOP2)
logger (19.04.2024 22:17:45): station 0 (Vantage), no reading of Vantage's internal logger.
logger (19.04.2024 22:17:45): station 1 (Vantage), firmware version 3.88 (supports LOOP2)
logger (19.04.2024 22:17:45): station 1 (Vantage), no reading of Vantage's internal logger.
logger (19.04.2024 22:17:48): station 2 (Vantage), gettime request sent.
logger (19.04.2024 22:17:48): station 2 (Vantage), no Vantage time offset.
logger (19.04.2024 22:17:48): station 2 (Vantage), eeprom request sent.
logger (19.04.2024 22:17:48): station 2 (Vantage), rain collector size 0.01 inch per tick.
logger (19.04.2024 22:17:48): station 2 (Vantage), transmitter 1 active as station type #3 "Temp/Hum" mapped to "th1".
logger (19.04.2024 22:17:48): station 2 (Vantage), transmitter 2 active as station type #4 "Wind".
logger (19.04.2024 22:17:48): station 2 (Vantage), transmitter 3 active as station type #0 "ISS".
logger (19.04.2024 22:17:48): station 2 (Vantage), firmware version request sent.
logger (19.04.2024 22:17:49): station 2 (Vantage), firmware version 3.80 (supports LOOP2)
logger (19.04.2024 22:17:49): station 2 (Vantage), no reading of Vantage's internal logger.
logger (19.04.2024 22:17:50): sensors are now providing data.
logger (19.04.2024 22:17:50): services started.
logger (20.04.2024 16:44:05): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 16:45:07): message above repeats 22 times.
logger (20.04.2024 16:45:10): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 16:45:10): disconnect station 0 (Vantage): socket reconnect failed
logger (20.04.2024 16:45:12): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 16:45:38): message above repeats 11 times.
logger (20.04.2024 16:45:40): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 16:45:43): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 16:46:09): message above repeats 8 times.
logger (20.04.2024 16:46:10): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 16:46:14): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 16:46:39): message above repeats 10 times.
logger (20.04.2024 16:46:40): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 16:46:42): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 16:47:09): message above repeats 8 times.
logger (20.04.2024 16:47:10): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 16:47:12): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 16:47:40): message above repeats 11 times.
logger (20.04.2024 16:47:40): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 16:47:44): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 16:48:10): message above repeats 10 times.
logger (20.04.2024 16:48:10): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 16:48:14): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 16:48:39): message above repeats 12 times.
logger (20.04.2024 16:48:40): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 16:48:41): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 16:49:07): message above repeats 7 times.
logger (20.04.2024 16:49:10): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 16:49:10): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 16:49:34): message above repeats 10 times.
logger (20.04.2024 16:49:40): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 16:49:40): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 16:50:05): message above repeats 9 times.
logger (20.04.2024 16:50:10): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 16:50:11): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 16:50:38): message above repeats 12 times.
logger (20.04.2024 16:50:40): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 16:50:41): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 16:51:09): message above repeats 8 times.
logger (20.04.2024 16:51:10): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 16:51:12): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 16:51:39): message above repeats 11 times.
logger (20.04.2024 16:51:40): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 16:51:42): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 16:52:05): message above repeats 7 times.
logger (20.04.2024 16:52:10): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 16:52:10): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 16:52:37): message above repeats 11 times.
logger (20.04.2024 16:52:40): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 16:52:42): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 16:53:07): message above repeats 9 times.
logger (20.04.2024 16:53:10): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 16:53:12): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 16:53:39): message above repeats 13 times.
logger (20.04.2024 16:53:40): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 16:53:43): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 16:54:09): message above repeats 8 times.
logger (20.04.2024 16:54:10): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 16:54:14): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 16:54:39): message above repeats 11 times.
logger (20.04.2024 16:54:40): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 16:54:44): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 16:55:10): message above repeats 8 times.
logger (20.04.2024 16:55:10): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 16:55:14): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 16:55:36): message above repeats 9 times.
logger (20.04.2024 16:55:40): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 16:55:42): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 16:56:06): message above repeats 8 times.
logger (20.04.2024 16:56:10): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 16:56:12): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 16:56:36): message above repeats 10 times.
logger (20.04.2024 16:56:40): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 16:56:42): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 16:57:08): message above repeats 8 times.
logger (20.04.2024 16:57:10): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 16:57:12): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 16:57:40): message above repeats 10 times.
logger (20.04.2024 16:57:40): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 16:57:44): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 16:58:10): message above repeats 10 times.
logger (20.04.2024 16:58:10): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 16:58:14): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 16:58:40): message above repeats 12 times.
logger (20.04.2024 16:58:40): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 16:58:44): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 16:59:06): message above repeats 6 times.
logger (20.04.2024 16:59:10): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 16:59:10): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 16:59:36): message above repeats 10 times.
logger (20.04.2024 16:59:40): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 16:59:40): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 17:00:06): message above repeats 9 times.
logger (20.04.2024 17:00:10): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 17:00:10): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 17:00:40): message above repeats 12 times.
logger (20.04.2024 17:00:40): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 17:00:44): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 17:01:10): message above repeats 8 times.
logger (20.04.2024 17:01:10): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 17:01:14): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 17:01:34): message above repeats 8 times.
logger (20.04.2024 17:01:40): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 17:01:40): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 17:02:08): message above repeats 8 times.
logger (20.04.2024 17:02:10): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 17:02:10): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 17:02:40): message above repeats 10 times.
logger (20.04.2024 17:02:40): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 17:02:42): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 17:03:10): message above repeats 9 times.
logger (20.04.2024 17:03:10): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 17:03:12): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 17:03:40): message above repeats 12 times.
logger (20.04.2024 17:03:40): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 17:03:42): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 17:04:09): message above repeats 8 times.
logger (20.04.2024 17:04:10): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 17:04:12): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 17:04:40): message above repeats 10 times.
logger (20.04.2024 17:04:40): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 17:04:42): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 17:05:06): message above repeats 7 times.
logger (20.04.2024 17:05:10): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 17:05:12): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 17:05:38): message above repeats 10 times.
logger (20.04.2024 17:05:40): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 17:05:42): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 17:06:10): message above repeats 8 times.
logger (20.04.2024 17:06:10): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 17:06:12): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 17:06:36): message above repeats 9 times.
logger (20.04.2024 17:06:40): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 17:06:40): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 17:07:06): message above repeats 8 times.
logger (20.04.2024 17:07:10): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 17:07:10): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 17:07:36): message above repeats 10 times.
logger (20.04.2024 17:07:40): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 17:07:42): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 17:08:08): message above repeats 10 times.
logger (20.04.2024 17:08:10): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 17:08:12): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 17:08:34): message above repeats 11 times.
logger (20.04.2024 17:08:40): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 17:08:40): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 17:09:06): message above repeats 8 times.
logger (20.04.2024 17:09:10): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 17:09:10): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 17:09:40): message above repeats 10 times.
logger (20.04.2024 17:09:40): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 17:09:42): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 17:10:10): message above repeats 9 times.
logger (20.04.2024 17:10:10): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 17:10:12): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 17:10:40): message above repeats 11 times.
logger (20.04.2024 17:10:40): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 17:10:42): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 17:11:10): message above repeats 8 times.
logger (20.04.2024 17:11:10): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 17:11:12): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 17:11:40): message above repeats 10 times.
logger (20.04.2024 17:11:40): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 17:11:42): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 17:12:06): message above repeats 7 times.
logger (20.04.2024 17:12:10): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 17:12:12): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 17:12:36): message above repeats 10 times.
logger (20.04.2024 17:12:40): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 17:12:42): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 17:13:08): message above repeats 9 times.
logger (20.04.2024 17:13:10): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 17:13:12): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 17:13:38): message above repeats 12 times.
logger (20.04.2024 17:13:40): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 17:13:42): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 17:14:10): message above repeats 8 times.
logger (20.04.2024 17:14:10): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 17:14:12): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 17:14:38): message above repeats 9 times.
logger (20.04.2024 17:14:40): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 17:14:42): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 17:15:08): message above repeats 8 times.
logger (20.04.2024 17:15:10): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 17:15:12): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 17:15:39): message above repeats 10 times.
logger (20.04.2024 17:15:40): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 17:15:44): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 17:16:09): message above repeats 8 times.
logger (20.04.2024 17:16:10): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 17:16:16): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 17:16:36): message above repeats 9 times.
logger (20.04.2024 17:16:40): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 17:16:41): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 17:17:07): message above repeats 8 times.
logger (20.04.2024 17:17:10): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 17:17:12): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 17:17:38): message above repeats 10 times.
logger (20.04.2024 17:17:40): station 0 (Vantage), error make socket 192.168.2.46: port 22222: unknown (22)
logger (20.04.2024 17:17:43): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 17:17:53): message above repeats 3 times.
logger (20.04.2024 17:17:55): error while doing accept on socket 5558 (22): Invalid argument
logger (20.04.2024 17:18:00): message above repeats 108 times.
logger (20.04.2024 17:18:01): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (20.04.2024 17:18:01): message above repeats 3 times.
logger (20.04.2024 17:18:02): error while doing accept on socket 5558 (22): Invalid argument
logger (20.04.2024 17:18:03): message above repeats 20 times.
davidmc36
Post by davidmc36 »
Keeps failing.
I'm about done with this MB. Cumulus on RPi Zero W doesn't do this.
May as well set up CMX now that I am on RPi anyway.
Can I give away my license to someone else?
Sorry that your unique issue could not be resolved and good luck on the Cumulus side.
davidmc36
Post by davidmc36 »
There's more to this than meets the eye.
I had a decent run after deleting the Station from MB that seemed to be at the root.
Taking a look at logger, it had an SD card installed that had intermittent data logs. Thinking the card that is total junk, nothing but 16GB printed on it but reports as a 32GB, is the issue, I set it up again and connect to MB.
Failed after 6 hours or so.
I now have 48 hours (--knock wood--) with no shutdown, with just the other two loggers.
Something about that particular piece of hardware, as it is on same FW, or MB not able to handle three Stations, or more than one WiFi Station.......
davidmc36 wrote: Wed May 01, 2024 12:30 pm ...or MB not able to handle three Stations, or more than one WiFi Station.......
That is not the issue for sure.
davidmc36 wrote: Wed May 01, 2024 12:30 pm .... Taking a look at logger, it had an SD card installed that had intermittent data logs. Thinking the card that is total junk, nothing but 16GB printed on it but reports as a 32GB, is the issue, I set it up again and connect to MB. Failed after 6 hours or so....
What is the make/model of that suspect SD card?
davidmc36
Post by davidmc36 »
Mattk wrote: Wed May 01, 2024 10:30 pm
As I said, the only thing printed on it is 16GB. Yet it reports as 32GB. No more comments on the quality of that card is reqd. lol I remember where it came from. A really crappy dash cam that failed.
At any rate, the card is physically removed and the logger is not a Station connected to MB at this time.
davidmc36 wrote: Thu May 02, 2024 6:38 am
Removed and binned is the only place for it :lol:
davidmc36
Post by davidmc36 »
I'm going to try my spare logger later today. Then I have one more "tweak" to test.
Stay Tuned!
D
davidmc36
Post by davidmc36 »
Finally found a spare minute to try a swap.
It seems to look like a hardware issue. With spare logger swapped in it seems solid (knock wood). Really needs a couple more days at least though.
If it remains good for a bit, I will upgrade Logger FW from current 2.41 to the 2.42 the other was running on. Then will set logger to Static IP and use the same IP as the offender.
That will duplicate every specific of the offender.
D
davidmc36
Post by davidmc36 »
Still working through different hardware combinations as no clear pattern has emerged yet.
Tests continue.
davidmc36
Post by davidmc36 »
It seems to be emerging as related to the particular console. Had trouble with only two loggers.
Next to try that unit exclusively.
D
davidmc36
Post by davidmc36 »
There has been no success in pinpointing any hardware as a culprit.
Will exhibit the same behavior with any combination of one or more of the four loggers attached to any of three consoles. Two consoles running 3.88 FW and one has 3.80 with the Ethernet Logger.
Keeps doing this, and eventually stops receiving Data.
The only thing I can think of at this point is have the RPi plugged into a WiFi controlled switch that has a schedule to shut down for one minute every hour or something.
I've left the MB on 5.9 as I read about some issue with 6.0
logger (16.06.2024 17:02:33): station 0 (Vantage), eeprom request sent.
logger (16.06.2024 17:02:33): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (16.06.2024 17:02:33): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (16.06.2024 17:02:33): station 0 (Vantage), transmitter 2 active as station type #4 "Wind".
logger (16.06.2024 17:02:33): station 0 (Vantage), firmware version request sent.
logger (16.06.2024 17:02:33): station 0 (Vantage), firmware version 3.88 (supports LOOP2)
logger (16.06.2024 17:02:33): station 0 (Vantage), no reading of Vantage's internal logger.
logger (16.06.2024 17:02:38): sensors are now providing data.
logger (16.06.2024 17:02:38): services started.
logger (16.06.2024 17:17:48): child process received termination signal (15).
logger (16.06.2024 17:17:48): parent process received termination signal (15).
logger (16.06.2024 17:17:48): disconnect station 0 (Vantage): exit
logger (16.06.2024 17:17:48): disconnect station 9 (System Data): exit
logger (16.06.2024 17:17:49): data logger stopped.
logger (16.06.2024 17:17:49): databases disconnected.
logger (16.06.2024 17:17:49): parent process to be terminated.
test5m (16.06.2024 17:20:43): logger stalled, will be restarted now.
system (16.06.2024 17:20:43): stop of logging process initiated.
system (16.06.2024 17:20:44): start of logging process initiated.
logger (16.06.2024 17:20:44): databases connected. Update interval 3600 seconds.
logger (16.06.2024 17:20:44): data logger started.
logger (16.06.2024 17:20:44): connect station 0 (Vantage via TCP/IP).
logger (16.06.2024 17:20:44): connect station 9 (System Data via Plug-in).
logger (16.06.2024 17:20:45): station 0 (Vantage), wakeup sent.
logger (16.06.2024 17:20:48): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (16.06.2024 17:20:48): services paused.
logger (16.06.2024 17:20:49): station 0 (Vantage), no need to update console date/time.
logger (16.06.2024 17:20:50): station 0 (Vantage), setup script executed.
logger (16.06.2024 17:20:50): station 0 (Vantage), internal logger activated.
logger (16.06.2024 17:20:50): station 0 (Vantage), syncing.
logger (16.06.2024 17:21:00): station 0 (Vantage), gettime request sent.
logger (16.06.2024 17:21:00): station 0 (Vantage), no Vantage time offset.
logger (16.06.2024 17:21:00): station 0 (Vantage), eeprom request sent.
logger (16.06.2024 17:21:00): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (16.06.2024 17:21:00): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (16.06.2024 17:21:00): station 0 (Vantage), transmitter 2 active as station type #4 "Wind".
logger (16.06.2024 17:21:00): station 0 (Vantage), firmware version request sent.
logger (16.06.2024 17:21:00): station 0 (Vantage), firmware version 3.88 (supports LOOP2)
logger (16.06.2024 17:21:00): station 0 (Vantage), no reading of Vantage's internal logger.
logger (16.06.2024 17:21:05): sensors are now providing data.
logger (16.06.2024 17:21:05): services started.
logger (16.06.2024 17:21:12): child process received termination signal (15).
logger (16.06.2024 17:21:12): parent process received termination signal (15).
logger (16.06.2024 17:21:12): disconnect station 0 (Vantage): exit
logger (16.06.2024 17:21:12): disconnect station 9 (System Data): exit
logger (16.06.2024 17:21:13): data logger stopped.
logger (16.06.2024 17:21:13): databases disconnected.
logger (16.06.2024 17:21:13): parent process to be terminated.
test5m (16.06.2024 17:26:38): logger stalled, will be restarted now.
system (16.06.2024 17:26:38): stop of logging process initiated.
system (16.06.2024 17:26:39): start of logging process initiated.
logger (16.06.2024 17:26:39): databases connected. Update interval 3600 seconds.
logger (16.06.2024 17:26:39): data logger started.
logger (16.06.2024 17:26:39): connect station 0 (Vantage via TCP/IP).
logger (16.06.2024 17:26:39): connect station 9 (System Data via Plug-in).
logger (16.06.2024 17:26:40): station 0 (Vantage), wakeup sent.
logger (16.06.2024 17:26:43): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (16.06.2024 17:26:43): services paused.
logger (16.06.2024 17:26:52): station 0 (Vantage), execution of setup script failed (console is not responding).
logger (16.06.2024 17:26:52): station 0 (Vantage), internal logger activated.
logger (16.06.2024 17:26:52): station 0 (Vantage), syncing.
logger (16.06.2024 17:26:52): station 0 (Vantage), gettime request sent.
logger (16.06.2024 17:27:02): message above repeats 1 time.
logger (16.06.2024 17:27:02): station 0 (Vantage), no Vantage time offset.
logger (16.06.2024 17:27:02): station 0 (Vantage), eeprom request sent.
logger (16.06.2024 17:27:02): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (16.06.2024 17:27:02): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (16.06.2024 17:27:02): station 0 (Vantage), transmitter 2 active as station type #4 "Wind".
logger (16.06.2024 17:27:02): station 0 (Vantage), firmware version request sent.
logger (16.06.2024 17:27:02): station 0 (Vantage), firmware version 3.88 (supports LOOP2)
logger (16.06.2024 17:27:02): station 0 (Vantage), no reading of Vantage's internal logger.
logger (16.06.2024 17:27:07): sensors are now providing data.
logger (16.06.2024 17:27:07): services started.
logger (16.06.2024 17:27:16): child process received termination signal (15).
logger (16.06.2024 17:27:16): parent process received termination signal (15).
logger (16.06.2024 17:27:16): disconnect station 0 (Vantage): exit
logger (16.06.2024 17:27:16): disconnect station 9 (System Data): exit
logger (16.06.2024 17:27:17): data logger stopped.
logger (16.06.2024 17:27:17): databases disconnected.
logger (16.06.2024 17:27:17): parent process to be terminated.
test5m (16.06.2024 17:30:18): logger stalled, will be restarted now.
system (16.06.2024 17:30:18): stop of logging process initiated.
system (16.06.2024 17:30:19): start of logging process initiated.
logger (16.06.2024 17:30:19): databases connected. Update interval 3600 seconds.
logger (16.06.2024 17:30:19): data logger started.
logger (16.06.2024 17:30:19): connect station 0 (Vantage via TCP/IP).
logger (16.06.2024 17:30:19): connect station 9 (System Data via Plug-in).
logger (16.06.2024 17:30:20): station 0 (Vantage), wakeup sent.
logger (16.06.2024 17:30:23): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (16.06.2024 17:30:23): services paused.
logger (16.06.2024 17:30:24): station 0 (Vantage), no need to update console date/time.
logger (16.06.2024 17:30:24): station 0 (Vantage), setup script executed.
logger (16.06.2024 17:30:25): station 0 (Vantage), internal logger activated.
logger (16.06.2024 17:30:25): station 0 (Vantage), syncing.
logger (16.06.2024 17:30:35): station 0 (Vantage), gettime request sent.
logger (16.06.2024 17:30:35): station 0 (Vantage), no Vantage time offset.
logger (16.06.2024 17:30:35): station 0 (Vantage), eeprom request sent.
logger (16.06.2024 17:30:35): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (16.06.2024 17:30:35): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (16.06.2024 17:30:35): station 0 (Vantage), transmitter 2 active as station type #4 "Wind".
logger (16.06.2024 17:30:35): station 0 (Vantage), firmware version request sent.
logger (16.06.2024 17:30:35): station 0 (Vantage), firmware version 3.88 (supports LOOP2)
logger (16.06.2024 17:30:35): station 0 (Vantage), no reading of Vantage's internal logger.
logger (16.06.2024 17:30:39): sensors are now providing data.
logger (16.06.2024 17:30:39): services started.
logger (16.06.2024 17:30:46): child process received termination signal (15).
logger (16.06.2024 17:30:46): parent process received termination signal (15).
logger (16.06.2024 17:30:46): disconnect station 0 (Vantage): exit
logger (16.06.2024 17:30:46): disconnect station 9 (System Data): exit
logger (16.06.2024 17:30:47): data logger stopped.
logger (16.06.2024 17:30:47): databases disconnected.
logger (16.06.2024 17:30:47): parent process to be terminated.
test5m (16.06.2024 17:35:59): logger stalled, will be restarted now.
system (16.06.2024 17:35:59): stop of logging process initiated.
system (16.06.2024 17:36:00): start of logging process initiated.
logger (16.06.2024 17:36:00): databases connected. Update interval 3600 seconds.
logger (16.06.2024 17:36:00): data logger started.
logger (16.06.2024 17:36:00): connect station 0 (Vantage via TCP/IP).
logger (16.06.2024 17:36:00): connect station 9 (System Data via Plug-in).
logger (16.06.2024 17:36:01): station 0 (Vantage), wakeup sent.
logger (16.06.2024 17:36:04): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (16.06.2024 17:36:04): services paused.
logger (16.06.2024 17:36:05): station 0 (Vantage), no need to update console date/time.
logger (16.06.2024 17:36:06): station 0 (Vantage), setup script executed.
logger (16.06.2024 17:36:06): station 0 (Vantage), internal logger activated.
logger (16.06.2024 17:36:06): station 0 (Vantage), syncing.
logger (16.06.2024 17:36:16): station 0 (Vantage), gettime request sent.
logger (16.06.2024 17:36:16): station 0 (Vantage), no Vantage time offset.
logger (16.06.2024 17:36:16): station 0 (Vantage), eeprom request sent.
logger (16.06.2024 17:36:16): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (16.06.2024 17:36:16): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (16.06.2024 17:36:16): station 0 (Vantage), transmitter 2 active as station type #4 "Wind".
logger (16.06.2024 17:36:16): station 0 (Vantage), firmware version request sent.
logger (16.06.2024 17:36:16): station 0 (Vantage), firmware version 3.88 (supports LOOP2)
logger (16.06.2024 17:36:16): station 0 (Vantage), no reading of Vantage's internal logger.
logger (16.06.2024 17:36:21): sensors are now providing data.
logger (16.06.2024 17:36:21): services started.
logger (16.06.2024 17:36:28): child process received termination signal (15).
logger (16.06.2024 17:36:28): parent process received termination signal (15).
logger (16.06.2024 17:36:28): disconnect station 0 (Vantage): exit
logger (16.06.2024 17:36:28): disconnect station 9 (System Data): exit
logger (16.06.2024 17:36:29): data logger stopped.
logger (16.06.2024 17:36:29): databases disconnected.
logger (16.06.2024 17:36:29): parent process to be terminated.
test5m (16.06.2024 17:40:27): logger stalled, will be restarted now.
system (16.06.2024 17:40:27): stop of logging process initiated.
system (16.06.2024 17:40:28): start of logging process initiated.
logger (16.06.2024 17:40:28): databases connected. Update interval 3600 seconds.
logger (16.06.2024 17:40:28): data logger started.
logger (16.06.2024 17:40:28): connect station 0 (Vantage via TCP/IP).
logger (16.06.2024 17:40:28): connect station 9 (System Data via Plug-in).
logger (16.06.2024 17:40:29): station 0 (Vantage), wakeup sent.
logger (16.06.2024 17:40:32): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (16.06.2024 17:40:32): services paused.
logger (16.06.2024 17:40:41): station 0 (Vantage), execution of setup script failed (console is not responding).
logger (16.06.2024 17:40:41): station 0 (Vantage), internal logger activated.
logger (16.06.2024 17:40:41): station 0 (Vantage), syncing.
logger (16.06.2024 17:40:41): station 0 (Vantage), gettime request sent.
logger (16.06.2024 17:40:41): station 0 (Vantage), no Vantage time offset.
logger (16.06.2024 17:40:41): station 0 (Vantage), eeprom request sent.
logger (16.06.2024 17:40:41): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (16.06.2024 17:40:41): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (16.06.2024 17:40:41): station 0 (Vantage), transmitter 2 active as station type #4 "Wind".
logger (16.06.2024 17:40:41): station 0 (Vantage), firmware version request sent.
logger (16.06.2024 17:40:41): station 0 (Vantage), firmware version 3.88 (supports LOOP2)
logger (16.06.2024 17:40:41): station 0 (Vantage), no reading of Vantage's internal logger.
logger (16.06.2024 17:40:45): sensors are now providing data.
logger (16.06.2024 17:40:45): services started.
logger (16.06.2024 17:40:52): child process received termination signal (15).
logger (16.06.2024 17:40:52): parent process received termination signal (15).
logger (16.06.2024 17:40:52): disconnect station 0 (Vantage): exit
logger (16.06.2024 17:40:52): disconnect station 9 (System Data): exit
logger (16.06.2024 17:40:53): data logger stopped.
logger (16.06.2024 17:40:53): databases disconnected.
logger (16.06.2024 17:40:53): parent process to be terminated.
test5m (16.06.2024 17:46:11): logger stalled, will be restarted now.
system (16.06.2024 17:46:11): stop of logging process initiated.
system (16.06.2024 17:46:12): start of logging process initiated.
logger (16.06.2024 17:46:12): databases connected. Update interval 3600 seconds.
logger (16.06.2024 17:46:12): data logger started.
logger (16.06.2024 17:46:12): connect station 0 (Vantage via TCP/IP).
logger (16.06.2024 17:46:12): connect station 9 (System Data via Plug-in).
logger (16.06.2024 17:46:13): station 0 (Vantage), wakeup sent.
logger (16.06.2024 17:46:16): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (16.06.2024 17:46:16): services paused.
logger (16.06.2024 17:46:17): station 0 (Vantage), no need to update console date/time.
logger (16.06.2024 17:46:18): station 0 (Vantage), setup script executed.
logger (16.06.2024 17:46:18): station 0 (Vantage), internal logger activated.
logger (16.06.2024 17:46:18): station 0 (Vantage), syncing.
logger (16.06.2024 17:46:28): station 0 (Vantage), gettime request sent.
logger (16.06.2024 17:46:28): station 0 (Vantage), no Vantage time offset.
logger (16.06.2024 17:46:28): station 0 (Vantage), eeprom request sent.
logger (16.06.2024 17:46:28): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (16.06.2024 17:46:28): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (16.06.2024 17:46:28): station 0 (Vantage), transmitter 2 active as station type #4 "Wind".
logger (16.06.2024 17:46:28): station 0 (Vantage), firmware version request sent.
logger (16.06.2024 17:46:28): station 0 (Vantage), firmware version 3.88 (supports LOOP2)
logger (16.06.2024 17:46:28): station 0 (Vantage), no reading of Vantage's internal logger.
logger (16.06.2024 17:46:33): sensors are now providing data.
logger (16.06.2024 17:46:33): services started.
davidmc36
Post by davidmc36 »
Seemed to go OK for about two hours..........then:
logger (17.06.2024 00:01:27): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (17.06.2024 00:01:27): station 0 (Vantage), transmitter 2 active as station type #4 "Wind".
logger (17.06.2024 00:01:27): station 0 (Vantage), firmware version request sent.
logger (17.06.2024 00:01:27): station 0 (Vantage), firmware version 3.88 (supports LOOP2)
logger (17.06.2024 00:01:27): station 0 (Vantage), no reading of Vantage's internal logger.
logger (17.06.2024 00:01:31): sensors are now providing data.
logger (17.06.2024 00:01:31): services started.
logger (17.06.2024 02:02:05): child process received termination signal (15).
logger (17.06.2024 02:02:05): parent process received termination signal (15).
logger (17.06.2024 02:02:05): disconnect station 0 (Vantage): exit
logger (17.06.2024 02:02:05): disconnect station 9 (System Data): exit
logger (17.06.2024 02:02:05): data logger stopped.
logger (17.06.2024 02:02:05): databases disconnected.
logger (17.06.2024 02:02:05): parent process to be terminated.
test5m (17.06.2024 02:05:07): logger stalled, will be restarted now.
system (17.06.2024 02:05:07): stop of logging process initiated.
