Meteohub Update 4.2f
What's hot...
Rikken
Re:Meteohub Update 4.2f
Post by Rikken »
Same here! Everything is working well after updating to 4.2g.
Have a nice time! :)
@skywright:
You caught a second Meteohub bug that I just fixed on your system (doing a recomputation now). This bug only occurs when you have calibration settings for rain in effect and if you are using data sensors. It has to do with that I am working on a better support for RFXmeter sensors, that do power consumption recording with counters that should be similar evaluated like rain totals. May sound a bit weird, but I am using cumulation techniques invented for rain sensor evaluation for this and did something wrong when referring to calibration settings.
I hope this is the last bug newly introduced by 4.2f. I will fix some more minor things before heading for a (hopefully mostly bug-free) 4.3 for the end of the coming week.
Thanks for your feedback that helped a lot to get this fixed in reasonable time.
Post by skyewright »
admin wrote:@skywright:
All fine now. :cheer:
Thank you for your prompt response and the backgrond explantion. I'm glad that I was able to assist.
The RFXmeter idea sounds like a great additional use for Meteohub.
I'm sure that many uses will be found for your generic "data" sensor type, both built-in (like the RFXmeter support) and via plug-ins. :)
