Let's wait for Brian, let's see if he can help usmikejeep wrote: Tue Jan 02, 2024 9:57 pmI am also having the same issue with both Weather Underground and CheckWX. I tried regenerating and re-adding my keys also. The data remains from Istanbul instead of my area (Massachusetts USA) and the API usage on both sites shows 0. I installed the template just a few days ago, then applied the R2 simple update, then configured everything accordingly. Everything else works great! Love the UI!xxvincixx wrote: Tue Jan 02, 2024 6:50 pm Hi Brian. For some time now I have had an error displaying the weather via the wu api key and the metar one. I bring some screenshots to try to show you what I'm talking about. I don't know what I can depend on, but it's as if the dashboard doesn't draw from the api keys. could you try to figure out what it could be?? Thank you
I figured out the issue! I did not properly set up the "Extra Services" in the last step of the instruction guide. My link to stationcron.php was incorrect.. fixing that resolved my WU/CheckWX issues. Ensure you have that set up and trigger a "Test" run to force a refresh.xxvincixx wrote: Tue Jan 02, 2024 10:50 pmLet's wait for Brian, let's see if he can help usmikejeep wrote: Tue Jan 02, 2024 9:57 pmI am also having the same issue with both Weather Underground and CheckWX. I tried regenerating and re-adding my keys also. The data remains from Istanbul instead of my area (Massachusetts USA) and the API usage on both sites shows 0. I installed the template just a few days ago, then applied the R2 simple update, then configured everything accordingly. Everything else works great! Love the UI!xxvincixx wrote: Tue Jan 02, 2024 6:50 pm Hi Brian. For some time now I have had an error displaying the weather via the wu api key and the metar one. I bring some screenshots to try to show you what I'm talking about. I don't know what I can depend on, but it's as if the dashboard doesn't draw from the api keys. could you try to figure out what it could be?? Thank you![]()
Fine
I can't find any problems with the WU prediction or CheckWx on my side.
Done,thanksmikejeep wrote: Tue Jan 02, 2024 11:11 pmI figured out the issue! I did not properly set up the "Extra Services" in the last step of the instruction guide. My link to stationcron.php was incorrect.. fixing that resolved my WU/CheckWX issues. Ensure you have that set up and trigger a "Test" run to force a refresh.xxvincixx wrote: Tue Jan 02, 2024 10:50 pmLet's wait for Brian, let's see if he can help usmikejeep wrote: Tue Jan 02, 2024 9:57 pm
I am also having the same issue with both Weather Underground and CheckWX. I tried regenerating and re-adding my keys also. The data remains from Istanbul instead of my area (Massachusetts USA) and the API usage on both sites shows 0. I installed the template just a few days ago, then applied the R2 simple update, then configured everything accordingly. Everything else works great! Love the UI!![]()
lorenz1982
- Expert Boarder
Hi Brian. In theme 7 and 8 is not shown the instantaneous wind speed but the average wind speed of the last 10 minutes. In my opinion the instant one is better.weatherist34 wrote: Tue Jan 02, 2024 3:56 pmHello Lorenzo , confused me ? its not easy but not sure which is incorrect ?lorenz1982 wrote: Tue Jan 02, 2024 1:05 pm I noticed that in theme 7 is shown the “average wind speed” value unstead of the “wind speed” value.
good morning
mikej,xxvinc glad you worked it out
Lorenzo all done I see what your saying so have corrected those see below
i could possibly release the Theme 8 this evening as there is not much left todo..
to those that provided FTP in the past or permission to update your sites are upto date with Theme 8 and fixes as of this morning.
...brian
...brian
lorenz1982
- Expert Boarder
Big thanks Brian from me for working on this new layout and updating my site. Looks great.
Paul
Paul
no problem paul/lorenzopwilman wrote: Wed Jan 03, 2024 11:36 am Big thanks Brian from me for working on this new layout and updating my site. Looks great.
Paul
you will see changes to bottom modules throughout the day , idea is to have bottom row matched in appearance , i find the over use of circles distracts me
as it is now with indoor and air quality stuff ..brian
3rd January 2024 Simple Update Download
Link to Simple update Weather34-simple-update-2024-January.zip (4.1mb) template:https://www.mediafire.com/file/h5flwp5e ... y.zip/file
Weather34-simple-update-2024-January.zip contains all the updates for year change over in charts ,updated forecast module,updated purple air module plus minor fixes/new themes 7/8 new options, new designed modules
please set new options for Theme 8 and 7 !!!!!!!!!
1. new LAYOUT Theme 8 with chart views
2. specific modules designed for Theme 8 only
3. FIXES raised by Torsten,Mike,Lorenzo,Alan,Harley
4. 95% identical menu layout across all 8 themes(work in progress )
5.Ideas/improvements implemented where possible and manageable suggested by Torsten
7.all bottom modules are interchangeable to your specific requirements see below something for the majority..
8.see screenshots below and back up your site prior to applying updates(trust me its worth doing).
hi brian,thanks for update. I was wondering if it was possible to change this and put the separate rain rate like in panel 6-7? for me it would be very welcome as an optionweatherist34 wrote: Wed Jan 03, 2024 8:12 pm 3rd January 2024 Simple Update Download
Hi im sorry too late Im afraid its feasible but too late, I had spent a quite a bit of time on these latest themes but now its time to go back outside enjoy the fresh airxxvincixx wrote: Wed Jan 03, 2024 8:52 pmhi brian,thanks for update. I was wondering if it was possible to change this and put the separate rain rate like in panel 6-7? for me it would be very welcome as an optionweatherist34 wrote: Wed Jan 03, 2024 8:12 pm 3rd January 2024 Simple Update Download
brian
Ok Brian,thanks for your workweatherist34 wrote: Wed Jan 03, 2024 9:26 pmHi im sorry too late Im afraid its feasible but too late, I had spent a quite a bit of time on these latest themes but now its time to go back outside enjoy the fresh airxxvincixx wrote: Wed Jan 03, 2024 8:52 pmhi brian,thanks for update. I was wondering if it was possible to change this and put the separate rain rate like in panel 6-7? for me it would be very welcome as an optionweatherist34 wrote: Wed Jan 03, 2024 8:12 pm 3rd January 2024 Simple Update Download
main.pngps I had started its in the zip rainratemod-Chart-2024.php not completed I remember these charts didnt play nice for those that get high rain rates of 100 plus per hour like Lars at singaporeweather the scaling was difficult to reflect small amounts when high rain rates of 100 plus occurred . may be next time when time permits to work out a method to get scaling looking useable at all scenarios....
brian
alexeysailman
- Expert Boarder
Hi, Brian! I noticed such a bug: in the archive for a month, days (on the x axis) are present, but if you turn on the archive for a year, they are not (circled in red). I looked at the pages of others - it's not just me.
- Screenshot 2024-013 317.png (203.06 KiB) Viewed 635477 times
- Screenshot 2024-01-03 223259.png (160.34 KiB) Viewed 635477 times
alexeysailman wrote: Wed Jan 03, 2024 9:38 pm Hi, Brian! I noticed such a bug: in the archive for a month, days (on the x axis) are present, but if you turn on the archive for a year, they are not (circled in red). I looked at the pages of others - it's not just me.
too late m8 im afraid ..as above .
brian
