xxvincixx wrote: Wed Jan 03, 2024 9:30 pm
weatherist34 wrote: Wed Jan 03, 2024 9:26 pm
xxvincixx wrote: Wed Jan 03, 2024 8:52 pm
hi brian,thanks for update. I was wondering if it was possible to change this and put the separate rain rate like in panel 6-7? for me it would be very welcome as an option
Hi im sorry too late Im afraid its feasible but too late, I had spent a quite a bit of time on these latest themes but now its time to go back outside enjoy the fresh air :-) ps I had started its in the zip rainratemod-Chart-2024.php not completed I remember these charts didnt play nice for those that get high rain rates of 100 plus per hour like Lars at singaporeweather the scaling was difficult to reflect small amounts when high rain rates of 100 plus occurred . may be next time when time permits to work out a method to get scaling looking useable at all scenarios....
brian
Ok Brian,thanks for your work 😃😃😃
it looked like this but incomplete
Screenshot at Jan 03 22-58-42.png (227.92 KiB) Viewed 475129 times
xxvincixx
Post by xxvincixx »
weatherist34 wrote: Wed Jan 03, 2024 9:47 pm
brian
oh beautiful 😃😃😃, take your time and thank you again for your work
xxvincixx wrote: Wed Jan 03, 2024 10:53 pm
4th January 2024 Simple update
Link to Simple update Weather34-simple-update-2024-January-4th.zip (4.1mb)
https://www.mediafire.com/file/vt4q7b17 ... h.zip/file
4th January
1.added requested (xxvincixx) rain rate module for theme 8
2.moved UV and Solar modules to bottom row options
3.air quality modules alignment fixes
now off for 10 day break with wife has she has recovered from her "MAN FLU" so a late celebration of christmas and new year..
please hold off on requests/issues until Im active again otherwise there just get missed :-) please ..brian.
see below
Link to MASTER Aurora MKII 2024 (12mb includes JANUARY SIMPLE UPDATE ZIP FILE) template :https://www.mediafire.com/file/4t58g74x ... 4.zip/file
4th January 2024
Link to Simple update Weather34-simple-update-2024-January-4th.zip (4.1mb) template:https://www.mediafire.com/file/vsln3lvi ... h.zip/file
Weather34-simple-update-2024-January-4th.zip contains all the updates for year change over in charts ,updated forecast module,updated purple air module plus minor fixes/new themes 7/8 new options, new designed modules
Link Weather34-simple-update-2024-January-4th.zip no working, but file is inside Weather34-master-2024.zip
Thanks for the latest updates, have a great time!
ToTo wrote: Thu Jan 04, 2024 10:50 am Link Weather34-simple-update-2024-January-4th.zip no working, but file is inside Weather34-master-2024.zip
unfortunately corrupt upload the NEW rainrate module chart file shows incorrect data !! just renewed zip and checked now OK .
https://www.mediafire.com/file/vt4q7b17 ... h.zip/file master zip also had an error in the simple update so use this one .. .
must go have fun ..brian
xxvincixx
Post by xxvincixx »
weatherist34 wrote: Thu Jan 04, 2024 10:09 am
4th January
see below
4th January 2024
thanks Brian.now is perfect..!!! ;) ;)
Acquisisci schermata Web_4-1-2024_17133_meteoroccamezzomonreale.altervista.org.jpeg
Acquisisci schermata Web_4-1-2024_17133_meteoroccamezzomonreale.altervista.org.jpeg (159.69 KiB) Viewed 475061 times
mikejeep
Post by mikejeep »
I just installed this template a few days ago, but I see historical data on all of the yearly charts. Looking through the files on my web server, I see the source data appears to be in the /weather34charts folder. It does not match my records--not that I expected it to since Meteobridge does not store them--so I assume it is demonstration data? Is it possible to replace this with my own actual data if I have it recorded? Will the charts automatically update on the template or are more steps needed? If this is explained elsewhere, I apologize, I could not find the information.
hello Mike
that probably is demo data , but yes if you have been using for example the template throughout 2023 then yes you can simply replace the 2023.csv file in the weather34charts folder if you have it stored safely (most dont practice backups :-) ) if not get in touch next week we will back in Istanbul . currently sitting here with a 4 hour flight delay that seems to be increasing everytime I look at the board :-) it sux !
Simple Update January 5th 2024
So during this tedious boring wait for our flight drank shite loads of coffee chilled out listening to my new christmas gift Airpods Pro2 from my wife and bucket loads of coffee ,killed the time by doing some requested ideas(webcam overlay ) and some minor alignment fixes(overlaps) in bottom modules along with all icons color now matches the charts color as I just basically just used the same color script from charts for the icon colors in bottom row modules .improves the UV index module for those particularly in the period of no UV (northern gits) :-)
webcam module has simple overlay of temp/wind and if currently raining (current rain rate greater than 0 ) shows and an umbrella icon see below this can improved to cater for more data if needed in the future .
..brian
Simple Update January 5th 2024 https://www.mediafire.com/file/izolday4 ... h.zip/file
Screenshot at Jan 05 11-21-26.png (268.1 KiB) Viewed 475024 times
mikejeep
Post by mikejeep »
weatherist34 wrote: Fri Jan 05, 2024 10:13 am that probably is demo data , but yes if you have been using for example the template throughout 2023 then yes you can simply replace the 2023.csv file in the weather34charts folder if you have it stored safely (most dont practice backups :-) ) if not get in touch next week we will back in Istanbul . currently sitting here with a 4 hour flight delay that seems to be increasing everytime I look at the board :-) it sux !
Thank you for such a fast reply, Brian. I was not using your template until a few days ago, but I have my data recorded elsewhere. I will see if I can easily convert it to match your file structure and get it to work. Safe travels!
mikejeep wrote: Fri Jan 05, 2024 10:21 am
ok Mike i have a converter script that attempts to convert csv data from other formats its been a while since I used it but next week get in touch sure its feasible with some thought..brian
ps safe travels if and when we get off the ground ..
You can also export from the Meteobridge Pro or NanoSD, script see appendix.
The output in the browser must then be saved in a text editor as 2023.csv
http://MB-IP/cgi-bin/export.cgi?period= ... output.exp
I would also be interested in the converter script :-)
I always look at the year files e.g. 2023.csv and realize that sometimes days are missing because the server could not execute the call of weather34-chart-end-of-day.php...
I then always fill the day gaps with a data export from the Meteobridge. What cannot be restored are the AQI air values, as these are calculated in the PHP scripts and the MB can only output the PM2.5 AVG value.
MB_year_output.zip
(707 Bytes) Downloaded 648 times
mikejeep
Post by mikejeep »
ToTo wrote: Fri Jan 05, 2024 11:10 am You can also export from the Meteobridge, script see appendix.
Does that work on the regular Meteobridge software though? Or just NanoSD/Pro? I didn't think the original version saved any historical data beyond the max/min entries..
Yes, this is only possible with Meteobridge PRO or NANO SD, as these store the historical data.
Hello
some of you will have got the update overnight .. Theme 9 !! rain icon turns blue when raining(current rain rate greater than zero) all other icons change color to reflect chart color..
demo https://whaleybridge-weather.com/weathe ... yout-3.php
simple update with theme 9 will come at end of week(thurs/fri)
.@ woolfg(graham) your site was not accessible to update or view overnight/this morning.
..brian
Screenshot at Jan 07 09-50-27.png (352.46 KiB) Viewed 474895 times
alexeysailman
Post by alexeysailman »
Hi, Brian! After all, this bug is massive. Even here on the link from the last post.
Screenshot 2024-01-07 103605.png (375.65 KiB) Viewed 474887 times
