alexeysailman wrote: Fri Feb 09, 2024 9:03 pm
Hi, Brian! Is there a possibility in the 9th layout to make the same font as in the center with the wind? Readability would increase. Maybe some visually impaired users have to get close to look at the numbers? Probably, this is more about situations with the use of additional screens. Example in the attached picture: 13.3 inch 1080p monitor.
Good morning Alex , luck has it !, it was raining hard this morning so here is what I did , each font size for the main value is now larger at 38px originally they were 26px .go any higher alignment for barometer/solar data start to push to far to the right so things become misaligned so 38px is really the max if all modules are to be identical in appearance.
expect update sometime later on Sunday (11th) ..also added missing theme 9 image in set up screen..have a good day..brian
Screenshot at Feb 11 10-23-56.png (237.53 KiB) Viewed 5349 times
as above email your login/ftp , also your path to the MBrealtimeupload.txt this will help eradicate the problem.brian..
Good morning Tom
i had a quick look and has I suspected TPLINK historical data not present for rainfall previous year/month? (memory serves me right TPLINK limited history storage data capability) and if i drop your MBrealtimeupload.txt into my demo I also dont see the last months rainfall see below of your data in screenshot
so in short unless the data is present in the meteobridge itself the template will not display any data for that specific .brian
Brain... how embarrassing but thanks for the confirmation... any recommendations on low profile options to move to a solution that could still service both my original: Historical weather page running MB-UB40-RRW and the newer Aurora MKII 2024 (Jan 16 Ver) ?
FYI - Attached what data my current TPLink MB has available..
Good morning Tom , sorry for the delay in replying there is a solution for history data using current template with TPLINK devices, it was coded by Torsten sometime ago .i don't have any solution to use both templates your using the older version is not supported by myself that was taken over by William but not sure if it there is any current support and he doesnt talk to me or contact me as he had one of those drama moments instead of contacting me to resolve the changes in the API . So in short i can help with current template with TPLINK sometime next week but my only concern it is not universal solution and future simple updates could or will probably break it so have a think about it has I do wish to keep things simple as possible for going forward.it is less maintenance , less time consuming to support.
brian..
Thanks Brian... does it makes sense to do a migration from the TPlink TL-MR3040 meteobridge setup i have used for years to the NanoSD? That would allow me to keep all templates still running strong and gain new features in history for newer templates?
hello Tom sorry for the delay i have been in hospital with a kidney stone dont wish it on anyone its pain beyond belief too almost 36 hours to pass through . using a NANOSD will remove all limitations of TPLINK and im sure with some reading of info you could migrate the data.. im not 100% sure as it has been a very long time since I used a tplink bridge possible last time was 2017 at a guess. so do some homework its a good way to learn the capabilities of the NANOSD..
Question for you guys being in South Florida we often have tornadoes, severe weather and hurricanes will the weather34 template show these alerts? I notice there are alerts being displayed on the top right corner.
there is no current alert for hurricanes,tornado,typhoon etc however if that type of data is present in the weather underground API then it can be easily added as an alert . something I can look at next week .
edit/... quite easy when I think about if icon or description in the API is hurricane or tornado or typhoon then kick an alert next week Adrian..
many thanks for the idea im sure others will benefit.. kind of ideas i like when others can benefit..
brian
weatherist34 wrote: Mon Feb 26, 2024 11:07 am
HAVE A GOOD DAY brian..
Thanks. I’ll look into the migration options from others. Hope your feeling better.
Good evening I have a pending simple update to release does anyone need anything or have any newer ideas to add on.
Simple Update
1.minor changes to since last rain theme 9
2.adds alerts/notifications for Hurricane,Tornado,Typhoon,Cyclone
3.minor PHP 8.3 change not significant
4..???? your ideas
weatherist34 wrote: Tue Mar 05, 2024 5:42 pm
Simple Update
4..???? your ideas
brian
Hi Brian.
I remember only these two little unimportant things:
- "Daylight remaining" error on the theme 7 and 8.
The error occurs both at sunrise and at sunset, only when it should be 0 hours.
It appears 12 instead of 0.
Senza titolo (1).png (19.27 KiB) Viewed 4788 times
- There are some small graph alignment problems.
Screenshot 2024-01-15 100720.png (203.63 KiB) Viewed 4788 times
i made some minor alignment on charts but Im struggling to reproduce this sunset/rise discrepancy , i give it a few days see if I can reproduce..its worth noting it kicks(change) in when sun below horizon or above horizon only thing I can adjust.
weatherist34 wrote: Sat Mar 09, 2024 9:18 am
good morning Lorenzo
brian
@lorenzo can I send you a file to test the sunrise/set daylight darkness hours ? i think I've nailed it but keep forgetting to be around sunset
Master Template download is now offline and updates are offline ..
I will explain in detail when I have time to write something informative with more detailed information.in short the template will support other software /api's and devices for a fee. This is a multiple effort/support by a small group of enthusiasts. its been in the making for a few months but I have done my upmost to keep it a free template for a number of years now but I would like to now see some small return for the effort.
nothing it seems to be free anymore even the software I use(for years) is now become subscription based so to cover the costs I have opened to the support for a wider a range of software/devices with a little bit of help.
sorry for the inconvenience it may cause but sometimes you got to be realistic and month in month out requests for supporting other software/methods is ongoing .it does not effect in anyway any existing installs just updates/method will be different .brian
