Page 4 of 30
Posted: Wed Jan 18, 2023 4:35 pm
by WEATHER34
Aurora MKII Changes January 2023
Adds new Meteobridge PRO 2 hardware svg see
https://www.meteobridge.com/wiki/index. ... ridge_PRO2.
Simplifies some setup options
Changed highlight colors of setup options
Better rollover of a year charts handling
Adds chart capability to year 2030
Adds donation area to setup screen
Removes unused or no longer support CSS
Verified PHP 8.2.1 compatibility (No change from PHP 8.2 required)
Back up compiler tweaked code /removed unused code
Todo
Create an optional Year Chart selection page
Create a write up(PDF) on how to extract Weather34 chart data from Meteobridge in correct format.
- MBPRO2.png (70.4 KiB) Viewed 291014 times
Posted: Sun Jan 29, 2023 11:18 am
by jmontamat
Good morning, no changes for the moment...
thank you
Posted: Thu Feb 02, 2023 8:23 am
by WEATHER34
Good morning
I sincerely apologize for the delay in sending out the updated version just very preoccupied and also need to compile a new script to send out a bulk email and stagger it at 3-5 minute intervals so gmail doesn't class it as spam.If you attempt to bulk send 234 emails google will bounce it. so please be patient the update list is growing week by week so I will endeavor to get it all done for next week.
I would like to reiterate support is very limited meaning Im unlikely to respond in any timely manner but I will if I am familiar with the hardware your using i.e Davis hardware , support for Ecowitt hardware simply there is none if it works then its a stroke of luck but your on your own to fathom out to use all the sensors that this type of hardware offers.please don't be offended I simply have no understanding or experience with this brand or similar hardware you will know more about the possibilities than I .
have a good day ...Brian
Posted: Thu Feb 02, 2023 10:53 am
by jmontamat
Thanks Brian for being on the list.
Posted: Thu Feb 02, 2023 1:52 pm
by jmontamat
Thank you very much !!!
Posted: Thu Feb 02, 2023 7:32 pm
by alexeysailman
Hi, Brian! If there is such a big problem with mailing via email, maybe it's easier to make a link to some file sharing service?
Posted: Fri Feb 03, 2023 9:04 am
by WEATHER34
hello
for convenience it is here
however please ensure you or anyone does a backup prior to using the simple updates this means your history data stored CSV files are not lost.
can't believe I sent out a batch yesterday and the use of backup or advising back up was totally ignored by some. so use these at your own risk I can not offer much support when trying to advise people to be cautious . end of the day I can't actually be more supportive if the basic is ignored.
It is very important you are running the last and latest version of Weather34 Aurora MKII
which is available via https://download.meteobridge.com/files/Weather34.zip or meteobridge forum
viewtopic.php?t=16253
this update will not work or will 99% break any older version so please be aware and I can not be held responsible for any mishaps where you have tried to apply this update to an older version.
Please 100% back up your website prior to updating again I can not be held responsible if something breaks.
Brian
Posted: Fri Feb 03, 2023 9:32 am
by Bart
Thanks for all your work and efforts!
For my understanding although the message is crystal clear. Make a backup and see if you have the latest version. But a completely new blank version? Then I will lose my history. How can you see if you are running the latest version. I see this:
- This.png (179.23 KiB) Viewed 290726 times
Bart
Posted: Fri Feb 03, 2023 11:27 am
by WEATHER34
Hello should be fine your on MKII version , the simple update link in this thread contains all updated files from June 2022 , backup advisory is merely there preserve a copy of all previous years CSV files( data) for charts in the event things go a bit wonky
.therefore its easy to just upload the year.csv files back into the weather34charts folder . examples 2019.csv,2020.csv,2021.csv,2022.csv etc .
image chart data files for previous years
- csv.png (121.71 KiB) Viewed 290718 times
Posted: Fri Feb 03, 2023 11:46 am
by WEATHER34
Posted: Fri Feb 03, 2023 12:58 pm
by jmontamat
Good morning, Excellent work !!! could you fix the layout for the 5 themes ??
Posted: Fri Feb 03, 2023 5:04 pm
by WEATHER34
a quick knock up just replace this image in the root folder
- weather34-layout-options.png (291.14 KiB) Viewed 290653 times
Posted: Fri Feb 03, 2023 5:36 pm
by jmontamat
Thank you Brian.
Posted: Sat Feb 04, 2023 2:29 pm
by WEATHER34
Weather34 Aurora MK II PDF setup guides Download
https://www.mediafire.com/file/fpcf73z9 ... e.zip/file
partial screenshot
- setup-shot.jpg (284.26 KiB) Viewed 290596 times
Posted: Tue Feb 07, 2023 9:13 am
by dtrop1
I saw you removed the donation link. You adding it back in or care to post here? I for one would like to contribute.
