MB keeps losing contact with Loggers.
davidmc36
Re: MB keeps losing contact with Loggers.
Post by davidmc36 »
It is doing this over and over again. Sometimes only 10 seconds after Services Started it gets the termination signal.
Any ideas why it keeps getting this "signal". It happens over and over and eventually does not restart itself and stops sending data.
   ogger (22.06.2024 17:36:06): sensors are now providing data.
logger (22.06.2024 17:36:06): services started.
logger (22.06.2024 17:41:13): child process received termination signal (15).
logger (22.06.2024 17:41:13): parent process received termination signal (15).
logger (22.06.2024 17:41:13): disconnect station 0 (Vantage): exit
logger (22.06.2024 17:41:13): disconnect station 9 (System Data): exit
logger (22.06.2024 17:41:14): data logger stopped.
logger (22.06.2024 17:41:14): databases disconnected.
logger (22.06.2024 17:41:14): parent process to be terminated.
test5m (22.06.2024 17:46:07): logger stalled, will be restarted now.
system (22.06.2024 17:46:07): stop of logging process initiated.
system (22.06.2024 17:46:08): start of logging process initiated.
logger (22.06.2024 17:46:08): databases connected. Update interval 3600 seconds.
logger (22.06.2024 17:46:08): data logger started.
davidmc36
Post by davidmc36 »
Seems to last longer after a power cycle instead of SW Re-Boot.
davidmc36
Post by davidmc36 »
I rolled back to Version 5.0 for a laugh.
Still exhibiting same shutdown behavior but seems to "Self Heal" after about 10 minutes or less. It was restarting some before but would eventually totally stall.
Has been Self Healing for about a day now.
Not very good though as you can miss rain while down.
(GUI responds faster too :wink: )
davidmc36
Post by davidmc36 »
Seriously. What sort of mechanism causes it to get termination signal 7 seconds after startup?
logger (05.07.2024 17:20:31): sensors are now providing data.
logger (05.07.2024 17:20:31): services started.
logger (05.07.2024 17:20:38): child process received termination signal (15).
logger (05.07.2024 17:20:38): parent process received termination signal (15).
davidmc36
Post by davidmc36 »
The superstitious side of me hesitates to mention it.
For near 4 days now no stalling.
I set it to hold Version 5.5
(knock wood)
davidmc36
Post by davidmc36 »
9 days on V5.5
(throws salt over his shoulder)
davidmc36
Post by davidmc36 »
What could be different with 5.5 to stay stable?
davidmc36
Post by davidmc36 »
And for whatever unknown reason, back on 5.9 for 11 days now. (Tucks thumbs inside hands)
The events were gone using 5.5 so I decided to give latest a whirl. 🤔
davidmc36
Post by davidmc36 »
I must have changed something...........still ticking along.
setup  (27.08.2024 18:14:48): use UTC stamp 2024-08-27 22:14:48 (1 tries)
dbase  (27.08.2024 18:14:53): process started.
dbase  (27.08.2024 18:14:54): Content of RAM database restored.
wnetd  (27.08.2024 18:14:56): process started.
system (27.08.2024 18:14:56): start of logging process initiated.
logger (27.08.2024 18:14:56): databases connected. Update interval 3600 seconds.
logger (27.08.2024 18:14:56): data logger started.
wnetd  (27.08.2024 18:14:56): send data thread started (pid:1711 tid:1713)
logger (27.08.2024 18:14:56): connect station 0 (Vantage via TCP/IP).
logger (27.08.2024 18:14:56): connect station 9 (System Data via Plug-in).
logger (27.08.2024 18:14:56): station 0 (Vantage), wakeup sent.
dbase  (27.08.2024 18:14:59): database sync done (92 tables, 58/7991 writes).
logger (27.08.2024 18:14:59): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (27.08.2024 18:14:59): services paused.
logger (27.08.2024 18:15:01): station 0 (Vantage), no need to update console date/time.
logger (27.08.2024 18:15:01): station 0 (Vantage), setup script executed.
logger (27.08.2024 18:15:01): station 0 (Vantage), internal logger activated.
logger (27.08.2024 18:15:01): station 0 (Vantage), syncing.
logger (27.08.2024 18:15:11): station 0 (Vantage), gettime request sent.
logger (27.08.2024 18:15:21): message above repeats 1 time.
logger (27.08.2024 18:15:21): station 0 (Vantage), no Vantage time offset.
logger (27.08.2024 18:15:21): station 0 (Vantage), eeprom request sent.
logger (27.08.2024 18:15:21): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (27.08.2024 18:15:21): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (27.08.2024 18:15:21): station 0 (Vantage), transmitter 2 active as station type #4 "Wind".
logger (27.08.2024 18:15:21): station 0 (Vantage), firmware version request sent.
logger (27.08.2024 18:15:21): station 0 (Vantage), firmware version 3.88 (supports LOOP2)
logger (27.08.2024 18:15:21): station 0 (Vantage), no reading of Vantage's internal logger.
logger (27.08.2024 18:15:25): sensors are now providing data.
logger (27.08.2024 18:15:25): services started.
logger (16.09.2024 01:31:21): child process received timeout signal (14).
logger (16.09.2024 01:31:22): disconnect station 0 (Vantage): exit
logger (16.09.2024 01:31:22): disconnect station 9 (System Data): exit
logger (16.09.2024 01:31:22): data logger stopped.
logger (16.09.2024 01:31:22): databases disconnected.
logger (16.09.2024 01:31:22): parent process to be terminated.
logger (16.09.2024 01:31:22): databases connected. Update interval 3600 seconds.
logger (16.09.2024 01:31:22): data logger started.
logger (16.09.2024 01:31:25): station 0 (Vantage), error connect socket 192.168.2.58 (22): port 22222: Invalid argument
logger (16.09.2024 01:31:25): station 0 (Vantage), connect to station failed.
logger (16.09.2024 01:31:25): connect station 9 (System Data via Plug-in).
logger (16.09.2024 01:31:28): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (16.09.2024 01:31:28): services paused.
logger (16.09.2024 01:31:55): station 0 (Vantage), error connect socket 192.168.2.58 (22): port 22222: Invalid argument
logger (16.09.2024 01:32:54): message above repeats 2 times.
logger (16.09.2024 01:33:23): give up waiting for sensors after 120 secs.
logger (16.09.2024 01:33:23): services activated.
logger (16.09.2024 01:33:26): station 0 (Vantage), error connect socket 192.168.2.58 (22): port 22222: Invalid argument
logger (16.09.2024 01:41:56): message above repeats 17 times.
logger (16.09.2024 01:42:23): connect station 0 (Vantage via TCP/IP).
logger (16.09.2024 01:42:23): station 0 (Vantage), wakeup sent.
logger (16.09.2024 01:42:28): station 0 (Vantage), no need to update console date/time.
logger (16.09.2024 01:42:28): station 0 (Vantage), setup script executed.
logger (16.09.2024 01:42:28): station 0 (Vantage), internal logger activated.
logger (16.09.2024 01:42:28): station 0 (Vantage), syncing.
logger (16.09.2024 01:42:38): station 0 (Vantage), gettime request sent.
logger (16.09.2024 01:42:38): station 0 (Vantage), no Vantage time offset.
logger (16.09.2024 01:42:38): station 0 (Vantage), eeprom request sent.
logger (16.09.2024 01:42:38): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (16.09.2024 01:42:38): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (16.09.2024 01:42:38): station 0 (Vantage), transmitter 2 active as station type #4 "Wind".
logger (16.09.2024 01:42:38): station 0 (Vantage), firmware version request sent.
logger (16.09.2024 01:42:38): station 0 (Vantage), firmware version 3.88 (supports LOOP2)
logger (16.09.2024 01:42:38): station 0 (Vantage), no reading of Vantage's internal logger.
logger (16.09.2024 15:43:32): station 0 (Vantage), error connect socket 192.168.2.58 (22): port 22222: Invalid argument
logger (16.09.2024 15:43:32): disconnect station 0 (Vantage): socket reconnect failed
logger (16.09.2024 15:44:02): connect station 0 (Vantage via TCP/IP).
logger (16.09.2024 15:44:02): station 0 (Vantage), internal logger activated.
logger (16.09.2024 15:44:02): station 0 (Vantage), syncing.
logger (16.09.2024 15:44:12): station 0 (Vantage), gettime request sent.
logger (16.09.2024 15:44:12): station 0 (Vantage), no Vantage time offset.
logger (16.09.2024 15:44:12): station 0 (Vantage), eeprom request sent.
logger (16.09.2024 15:44:12): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (16.09.2024 15:44:12): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (16.09.2024 15:44:12): station 0 (Vantage), transmitter 2 active as station type #4 "Wind".
logger (16.09.2024 15:44:12): station 0 (Vantage), firmware version request sent.
logger (16.09.2024 15:44:12): station 0 (Vantage), firmware version 3.88 (supports LOOP2)
logger (16.09.2024 15:44:12): station 0 (Vantage), no reading of Vantage's internal logger.
logger (19.09.2024 09:32:21): station 0 (Vantage), error connect socket 192.168.2.58 (22): port 22222: Invalid argument
logger (19.09.2024 09:32:21): disconnect station 0 (Vantage): socket reconnect failed
logger (19.09.2024 09:32:51): connect station 0 (Vantage via TCP/IP).
logger (19.09.2024 09:32:51): station 0 (Vantage), internal logger activated.
logger (19.09.2024 09:32:51): station 0 (Vantage), syncing.
logger (19.09.2024 09:33:01): station 0 (Vantage), gettime request sent.
logger (19.09.2024 09:33:01): station 0 (Vantage), no Vantage time offset.
logger (19.09.2024 09:33:01): station 0 (Vantage), eeprom request sent.
logger (19.09.2024 09:33:01): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (19.09.2024 09:33:01): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (19.09.2024 09:33:01): station 0 (Vantage), transmitter 2 active as station type #4 "Wind".
logger (19.09.2024 09:33:01): station 0 (Vantage), firmware version request sent.
logger (19.09.2024 09:33:01): station 0 (Vantage), firmware version 3.88 (supports LOOP2)
logger (19.09.2024 09:33:01): station 0 (Vantage), no reading of Vantage's internal logger.
logger (22.09.2024 19:49:39): station 0 (Vantage), error connect socket 192.168.2.58 (22): port 22222: Invalid argument
logger (22.09.2024 19:49:39): disconnect station 0 (Vantage): socket reconnect failed
logger (22.09.2024 19:50:09): connect station 0 (Vantage via TCP/IP).
logger (22.09.2024 19:50:09): station 0 (Vantage), internal logger activated.
logger (22.09.2024 19:50:09): station 0 (Vantage), syncing.
logger (22.09.2024 19:50:19): station 0 (Vantage), gettime request sent.
logger (22.09.2024 19:50:19): station 0 (Vantage), no Vantage time offset.
logger (22.09.2024 19:50:19): station 0 (Vantage), eeprom request sent.
logger (22.09.2024 19:50:19): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (22.09.2024 19:50:19): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (22.09.2024 19:50:19): station 0 (Vantage), transmitter 2 active as station type #4 "Wind".
logger (22.09.2024 19:50:19): station 0 (Vantage), firmware version request sent.
logger (22.09.2024 19:50:19): station 0 (Vantage), firmware version 3.88 (supports LOOP2)
logger (22.09.2024 19:50:19): station 0 (Vantage), no reading of Vantage's internal logger.
logger (09.10.2024 07:18:03): station 0 (Vantage), error connect socket 192.168.2.58 (22): port 22222: Invalid argument
logger (09.10.2024 07:18:03): disconnect station 0 (Vantage): socket reconnect failed
logger (09.10.2024 07:18:33): connect station 0 (Vantage via TCP/IP).
logger (09.10.2024 07:18:33): station 0 (Vantage), internal logger activated.
logger (09.10.2024 07:18:33): station 0 (Vantage), syncing.
logger (09.10.2024 07:18:43): station 0 (Vantage), gettime request sent.
logger (09.10.2024 07:18:43): station 0 (Vantage), no Vantage time offset.
logger (09.10.2024 07:18:43): station 0 (Vantage), eeprom request sent.
logger (09.10.2024 07:18:43): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (09.10.2024 07:18:43): station 0 (Vantage), transmitter 1 active as station type #0 "ISS".
logger (09.10.2024 07:18:43): station 0 (Vantage), transmitter 2 active as station type #4 "Wind".
logger (09.10.2024 07:18:43): station 0 (Vantage), firmware version request sent.
logger (09.10.2024 07:18:43): station 0 (Vantage), firmware version 3.88 (supports LOOP2)
logger (09.10.2024 07:18:43): station 0 (Vantage), no reading of Vantage's internal logger.
