Meteohub Update 4.0 "multi station" (highly experimental)
What's hot...
Re:Meteohub Update 4.0 "multi station" (highly experimental)
just uploaded rc8, which fixes:
- broken support for rms300, wmrs200
- solar data not being logged
piombo
Post by piombo »
I got the same problem than darren7303. There is no historical data in dashboard nor than in my html-template.
I think that there might be a problem in the re computation of the data. At re computation my NSLU used to calculate about 450 records/sec. On rc7 and rc8 there were about 1500 records/sec!
Actual graphs show data until version change to rc7, after that moment there aren't any lines plotted. Data is being collected (shown on Datenansicht) and actual values are displayed in dashboard and html-template.
Post by skyewright »
skyewright wrote:rc7 dashboard only showing zeros in historical rows here too. The current figures row does however show correctly.
Now on rc8.
Historical lines showing outdoor temp, hum & pressure. Historical rain is all zeros. Historical windspeed is blank.
I've tried changing the sensor settings and saving.
html template only showing historic for outdoor temp/hum.
Graphs looking okay.
I've just set a Recompute going to see if that helps (first recompute since before update to rc7 I believe).
darren7303
Post by darren7303 »
Have just installed RC8 and it has recalculated my data, but with no improvements.
Boris, I have not changed any passwords etc. since you last requested access. Just access it whenever you feel the need to.
Darren
skyewright wrote:skyewright wrote:
Now on rc8.
Now on 4.1 (thanks Boris :)), and historical figures on the dashboard & in html templates are looking fine. :)
meinmotion
Post by meinmotion »
I've checked Solar data with 4.1 and it's working :-)
paul_1055
Post by paul_1055 »
Hallo,
zwei Probleme sind mir noch aufgefallen.
1. Bei einer VP2 mit weatherlink IP werden keine Werte mehr an www.weatherlink.com übertragen.
2. Der Sensor th1x für die Bodenfeuchte zeigt ab einem Wert von 100 über die Variable actual_th10_hum_rel immer 100 an. Die Durchschnittswerte für z.B. Stunde oder Tag werden aber mit den richtigen Werten größer 100 berechnet, die Ansicht in der Grafik stimmt auch. Dieser Fehler ist auch schon in den Vorgängerversionen.
Gruß Torsten
Gruß Torsten
1) it should do. may be the intended delay between sending loop packets is not correctly working with 4.x?
2) will be fixed with next update (4.1b).
paul_1055
Post by paul_1055 »
admin wrote:1) it should do. may be the intended delay between sending loop packets is not correctly working with 4.x?
getestet mit V4.1
Danke
Gruß Torsten
piombo
Post by piombo »
Running 4.1, WMR200, NSLU
I think that wind chill calculation still does not work, no mather if data calculated by meteohub or taken from the WMR.
sea-level-pressure works fine!
