Page 35 of 102
Posted: Fri Feb 05, 2021 8:57 pm
by prestwickwx
Ok that is what I was thinking. Since, it is indoors, the 24 hour averages are very low.
Posted: Fri Feb 05, 2021 9:00 pm
by Gyvate
Gyvate wrote: Thu Feb 04, 2021 8:03 pm
weatherist34 wrote: Wed Feb 03, 2021 8:13 pm nothing unusual found perhaps you need to look locally .
try adding
date_default_timezone_set($TZ);
as shown below thats all I can think of definitely don't see any issues locally.
that did the job :D 8) - thanks
Posted: Fri Feb 05, 2021 9:05 pm
by weatherist34
prestwickwx wrote: Fri Feb 05, 2021 8:57 pm Brian,
just do what i do wait till the wife starts cooking then put it in the kitchen soon goes up and guaranteed good test results . :D :D
Posted: Fri Feb 05, 2021 9:08 pm
by prestwickwx
weatherist34 wrote: Fri Feb 05, 2021 9:05 pm
Yes. Hair Spray is effective, as well! :lol:
Posted: Fri Feb 05, 2021 10:51 pm
by jasonmfarrow
All, I can confirm that at times the Davis Airlink reads almost nothing or actually nothing. However, despite a new extractor fan venting the cooking from the kitchen to the outside world, it will pick up a lot of particulates very quickly.
Apparently when I cook a steak my air becomes unhealthy.
Posted: Sat Feb 06, 2021 9:24 am
by alexeysailman
Hello, Brian!
After midnight today, everything was saved correctly. Before that, I did not go into the settings and did not restart meteobridge. Does it still make sense to write about the problem with saving daily data, if it happens again? With MK1, everything is fine.
Network access problems are excluded: meteobridge with the console and access point are connected to the UPS.
Posted: Sat Feb 06, 2021 10:32 am
by weatherist34
good morning, alex just watch it for a few days too see if it reoccurs . im running a test script at 2am but i want to see how it performs for a week then ill take it from there. if aint broke dont fix it.
Posted: Sat Feb 06, 2021 4:24 pm
by Bart
To understand it better I would like to know which files are affected by the cron. And in which map they are located. I have installed Aurora MKII.
Posted: Sat Feb 06, 2021 4:27 pm
by prestwickwx
I just updated from the simple update file - didn't see it on Git. Here is what I am seeing on the new month and year chart files.
Best wishes,
Posted: Sat Feb 06, 2021 5:27 pm
by weatherist34
hi chuck unfortunately I lost internet for a hour or so , GITHUB was just sitting there . the update file didn't go either as I corrected that outcome shortly afterwards along with adding the date/timezone to the preload file so either grab the GIT which was just sent or the updated simple update .
should resemble below and note the Davis airlink will not show if Purple Air is present !! if you was to have both you would sacrifice actual weather station data chart .so the update is really only of benefit to those who have only Davis Airlink without Purple Air i.e one sensor.
* Adds date/timezone to all charts via preload (6:19pm).
* Adds Davis airlink air quality to month/year charts (4:15pm).
* Webcam popup improved scaling size (4:15pm).
Posted: Sat Feb 06, 2021 5:47 pm
by prestwickwx
OK. So, the latest simple update fixed it - todays update wasn't showing on Git.
Posted: Sat Feb 06, 2021 7:06 pm
by weatherist34
Github upload hanged earlier and its still not showing updated even though the app triggered a push . ill take a look later .
Posted: Sun Feb 07, 2021 2:50 pm
by prestwickwx
Git looks up to date now. Just grabbed the month/year lightning chart files.
Posted: Sun Feb 07, 2021 3:38 pm
by weatherist34
prestwickwx wrote: Sun Feb 07, 2021 2:50 pm Brian,
OK chuck all done should see all files on GITHUB.
you need to trigger in the tplink an end of day service shown below at before each day the file is weather34-strikes-end-of-day.php
it will create 2021strikes.csv and current month for example Februarystrikes.csv
for current daily totals no change in how thats collected
thats it .you can access the charts via menu or small module as previous . chart layout should resemble below(using dummy data) but you will have to accumulate data over a period of time .
Posted: Sun Feb 07, 2021 4:03 pm
by prestwickwx
Ok. All setup. :D
Many thanks,
