lorenz1982
Post by lorenz1982 »
Hi.
How can I see the Davis Airlink Data in layout 4 and layout 5 instead of the average wind speed?
On layout 2 and 3 it is activated automatically.
Senza titolo.png (82.41 KiB) Viewed 9843 times
MeteoBorgo: www.meteoborgo.it
par wrote: Sun May 18, 2025 7:42 pm Dobrý den.mám takový problém,když kliknu na meteobridge aurora tak se mi objeví chybová hláška HTTP ERROR 500,jak to vyřešit?
English or German please!
par
Post by par »
Hello, I have a problem, when I click on meteobridge aurora, I get an error message HTTP ERROR 500, how do I solve it?
par wrote: Wed May 21, 2025 8:26 pm Hello, I have a problem, when I click on meteobridge aurora, I get an error message HTTP ERROR 500, how do I solve it?
Can you please send the link that does not work for you to "info(at)meteobridge.com"? Without this information there is little anyone can do.
lorenz1982 wrote: Tue May 20, 2025 3:40 pm Hi.
Hello Lorenzo
the option in these 2 themes is in the smaller module at the bottom however I have just checked the auto detection large module of davis airlink to theme 3 . theme 4/5 does not support large airlink module perhaps in the future if Boris thinks its a benefit but you can still use the bottom modules as shown below .
I am about to send Boris the updated files which also includes files for a request from another thread on here .
happy summer days ..brian
theme 3 shows auto option of airlink large module just added .
theme 4 does not support large airlink module only small module
lorenz1982
Thanks, I understand.
In layout 2 and 3 no changes are needed because it already works.
Another opinion, I would not put the gust module but the wind speed module when the Davis Airlink is active.
Just installed Aurora Cloud update realizes the request to be able to configure fist line of modules in theme 7.
Hopefully, I did not introduce new bugs by that;-)
Downloads for local installs have also been updated.
DouglasW
Post by DouglasW »
Brian and Boris, thank you both SO much for this great addition to Meteobridge.
Douglas
par
Post by par »
admin wrote: Wed May 21, 2025 10:59 pm
par
Post by par »
https://content.meteobridge.com/dashboa ... /index.php
par wrote: Sat May 24, 2025 6:23 pm
you ruined your settings by having a translator module working within your browser and compromising the HTML post data.
$unit = "metrický";
$metric = pravdivý;
$windunit = "km/h";
$windunitatc = "Ne";
$distanceunit = "kilometr";
With just released update I added a feature to reset Meteobridge Aurora settings from within your Meteobridge.
pwilman
Post by pwilman »
Morning Boris,
I posted a suggestion a while back but not sure if you saw it. Would it be possible to have a question in the setup window to allow you to set the default colour theme of the page ie it would be either black or white?
It used to be there ages ago.?I like the white theme but it keeps defaulting back to black. You can set the colour for the graphs, but not the main page.
Thanks for all your continued support on this.
Paul
lorenz1982
Only minor alignment issues in layout 7.
Immagine 2025-05-28 090707.png (202.45 KiB) Viewed 9531 times
Changed some parameters to allow for larges existing Aurora sites to be cloned by "Clone Data" feature of the Aurora Cloud. In order to have this working, the Aurora site to be cloned needs to be on a current Aurora version.
