Aurora 2026 Rev-4.4Q Release
Re: Aurora 2026 Rev-2 Release
March 2nd-6th Aurora 2026 Rev - 2
Download Simple Update -Aurora-2026-Rev-2
https://www.mediafire.com/file/tn923mxm ... 2.zip/file
Download Master Aurora-2026-Rev-2
https://www.mediafire.com/file/rx2bnw2t ... 2.zip/file
1. Fixed missing Purple Air data in charts
2. Fixed clock in small module when using 12 hour format am/pm
3. Fixed various erroneous code in max/min section of charts
4. Fixed alternative forecast overlap when using two forecast modules
5. Added clock/time option in setup screen to be shown at top of main template
6. Removed all traces of chart files prior to 2021 (no longer supported or used)
7. Added menu color highlight in chart menu whichever day/month.year you are viewing it is highlighted in menu
8. Removed setup chart options to display before 2021 (no longer supported)
9. Adjusted numerous CSS font sizes where text size not matching
10. Fixed missing Air Quality max-min in charts bottom bottom area
11. Fixed broken CheckWX icon
12. Chart icons reworked
13. Added Android Samsung Galaxy Tablet compatibility
14. Improved Samsung Galaxy Watch compatibility
15. Improved Apple Watch ULTRA 1/2/3 & Series 7-11 compatibility
Re: Aurora 2026 Rev-2.01 Release
Aurora 2026 Rev-2.01 Release (important fix)
Simple Update Simple-Update-Aurora-2026-Rev2.01
https://www.mediafire.com/file/xbwe1soj ... 1.zip/file
Master Download Aurora-2026-Rev-2.01
https://www.mediafire.com/file/ntomwfll ... 1.zip/file
1.Fixed 2025 chart year layout when viewing mobile
2.Fixed blank page when using Custom Soil Temperature/Humidity script ..thanks Daniel
3.Fixed No data when using Custom Lightning script .thanks Aaron
4.Fixed missing month large charts for Barometer
5.Fixed Metar Airport Description where Airport description/name is long
6.Added fallback when API or custom API script produces no data (not all server configurations are affected by blank page output )
7.Fixed Soil Temperature chart colors not matching icon in module
8.Re compiled Lightning module
**please note the simple update 2.01 is quite an important one to run contains a universal essential fix for servers producing blank pages when no data present ,hence it is a larger file size than normal update files . the master 2.01 has these fixes included
have a good week...thanks for the feedback and raising issues ..
Re: Aurora 2026 Rev-2.02 Release
Please find below again it is a significant update with many additions and a few fixes , corrections. I do not anticipate releasing or doing anymore until late September or Mid October really depends when our summer ends (cooler days) and I'm also starting another local commercial project which I generally take on one or two small ones per year nothing that pushes me beyond my comfort zone .If you find any major issue I would be happy to address however please no more ideas just highlight significant issues if any found and Ill do my upmost best to resolve them .
Brian..
Simple Update Aurora-2026-Rev-2_02 Download https://www.mediafire.com/file/k5t1e9ea ... 2.zip/file
Master Aurora-2026-Rev-2_02 Download https://www.mediafire.com/file/wkxb2wpq ... 2.zip/file
March 8th-14th Aurora 2026 Rev - 2.02 (Significant Update)
1. Added additional averages to modules where valid
2. Added cautionary/warning icons where valid
3. Added additional module values
4. Fixed Lufdaten missing current day data
5. Verified more code for future public PHP releases
6. Removed unused CSS across all modules and chart areas
7. Metar module if shows Data Offline fallback(its actually rarely offline just has missing data in icon description API output)
8. ** Do not run multiple modules of clock and sun modules it creates a conflicting mess in Jquery, a fallback added but not 100% reliable
9. Reworked chart layouts to simplified use of CSS across all pages of charts I.e one CSS file one edit for future ideas and quick fixes
10. Reworked all modules to simplified use of CSS across all pages of charts I.e one CSS file one edit for future ideas and quick fixes
11. Verified for Samsung Android and Microsoft Tablets in portrait or landscape view
12. All files verified for ERRORS in jQuery outputs
13. CSS files verified for errors
14. Recompiled charts eliminating jQuery conflicts result is a faster loading page when viewing pages with multiple charts
15. Recompiled small earthquake module to accommodate long location names
16. Fixed time format in large clock module for sunrise/set
17. Fixed time format for sunrise/set modules and info page
18. Added Davis console forecast output small module option
19. Fixed Solar Radiation displaying comma when value greater than 1000
20. Added meteobridge info/ canvasJs license pop up
Re: Aurora 2026 Rev-2.03 Release
March 15th Aurora 2026 Rev - 2.03 (theme/clock issue )
Simple Update Aurora-2026-Rev-2_03 Download https://www.mediafire.com/file/eki38mum ... 3.zip/file
Master Aurora-2026-Rev-2_03 Download https://www.mediafire.com/file/v89dh67s ... 3.zip/file
thank you too Daniel and Claude for reporting two issues so quickly one with theme switching which seems to be a device or browser dependant and the small clock module not displaying time .
Brian
alexeysailman
Post by alexeysailman »
Hello, Brian!
Finally, you're back to your old ways :D I am very glad!
Is it possible to add more years earlier than 2021 to the charts, starting from 2019 in particular? In my opinion, I'm not the only one with such nonsense on the forecast page. Here I looked at www.paulwilman.com/W34 and him. Although maybe this is my local problem.
Screenshot 2026-03-15 104608.png (974.11 KiB) Viewed 1509 times
pwilman
Post by pwilman »
Morning Brian,
Couple of issues I have noticed with the latest update:
1) The clock on the small module is not showing
2) On the daily rainfall module the text box for "No rain today" seem to have dropped down and so it now almost touches the box below
Paul
Re: Aurora 2026 Rev-2.04 Release
pwilman wrote: Sun Mar 15, 2026 11:20 am Morning Brian,
Paul
Hello Paul
clock issues were dealt with earlier this morning in 2.03 release ,though I have just aligned the "No Rain Today" area however based on Alex comments above I removed the 2.03 update and now uploaded 2.04 release addresses the wu-forecast charts issue that said I can't reproduce it locally so its another server side configuration that needs a workaround.ironic no changes were made to any forecast charts since 2025 so its a mystery !
Sorry Alex no charts prior to 2021 as mentioned last week the format for those years were different it is too much work to maintain due to the format process used back in 2020 and before.Sorry..and no Im just using the winter period and ramadan month to do some stuff but Im now about to disappear for the best part of the year as per previous years .
Download Simple-Update-Aurora-2026-Rev-2_04 https://www.mediafire.com/file/u1ve0ihm ... 4.zip/file
Download Master Aurora-2026-Rev-2_04 https://www.mediafire.com/file/agzxpi6z ... 4.zip/file
Screenshot 2026-03-15 at 14.31.45.png (1.01 MiB) Viewed 1233 times
Screenshot 2026-03-15 at 14.32.26.png (842.44 KiB) Viewed 1233 times
Screenshot 2026-03-15 at 15.29.29.png (1.04 MiB) Viewed 1216 times
lorenz1982
Post by lorenz1982 »
Some problems on iPad Pro 11” M4:
MeteoBorgo: www.meteoborgo.it
Re: Aurora 2026 Rev-2.05 Release
Hello once again thanks for the feedback ..hopefully nailed most of them .. :-)
Download Simple-Update-Aurora-2026-Rev-2_05 https://www.mediafire.com/file/81yrlzbr ... 5.zip/file
Download Master Aurora-2026-Rev-2_05 https://www.mediafire.com/file/ncvcexuw ... 5.zip/file
March 16th Aurora 2026 Rev - 2.05
1. Added Barometer mmHg charts today/month,year and back to 2021
2. Corrected Airlink and Purple Air day/month/year alignment in mobile view ref..Geoff
3. Corrected iPad Pro 11 alignment ..ref Lorenzo
4. Reworked modules to balance alignments across devices
5. Corrected Sun/Moon module alignment ..ref Claude
6. Reworked forecast chart page
7. Fixed Feels like output when using UK metric ..ref Geoff
8. Fixed Davis Console Forecast layout ..ref Geoff
lorenz1982
Some small problems also on the charts, always on iPad Pro 11”.
Good morning Lorenzo
interesting ! compare your charts page to mine locally..notice the difference ? think something wrong in the update file ,not sure I will take a look this evening .
Screenshot 2026-03-17 at 05.41.31.png (1005.21 KiB) Viewed 1130 times
Re: Aurora 2026 Rev-2.06 Release
weatherist34 wrote: Tue Mar 17, 2026 4:42 am Good morning Lorenzo
I checked the simple update zip and it was missing the updated CSS for the charts hence your weird looking appearance .
Download Simple-Update-Aurora-2026-Rev-2_06 https://www.mediafire.com/file/16jukia3 ... 6.zip/file
Download Master Aurora-2026-Rev-2_06 https://www.mediafire.com/file/yx0zm1au ... 6.zip/file
March 17th Aurora 2026 Rev - 2.06
1. Fixed missing updated chart css file in simple update
2. This fixes chart anomaly appearance on charts ref Lorenzo .
3. Adds better chart layout compatibility across devices (will never be perfect)
4. Reworked Trend area in modules
Screenshot 2026-03-17 at 17.06.21.png (1.21 MiB) Viewed 1110 times
lorenz1982
I still see it like this :(:
lorenz1982 wrote: Tue Mar 17, 2026 10:20 pm I still see it like this :(:
good morning provide a url not in a iframe or saturated in advertising its very difficult to navigate your main site . i will try and reproduce it and see if i can resolve it. definitely cant see it like that locally. your main website really hard to navigate see below through the adverts , I understand you may not much control over that but a direct to template url would help
Screenshot 2026-03-18 at 07.23.16.png (1.2 MiB) Viewed 1062 times
lorenz1982
Good morning, sure, sorry. Aurora 2026 isn't on the main site yet, but it can be found here: https://meteoborgo.altervista.org/Aurora/index.php. Thanks.
