Page 6 of 12
Posted: Fri Jun 13, 2025 10:15 am
by lorenz1982
pwilman wrote: Thu May 15, 2025 6:20 pm Boris,
Not sure if its relevant, but I seem to have had 3 instances at 14th May added to the graphs. All with exactly the same data. Dont think I have done anything. Does not bother me majorly, but thought I would report it just incase there is a bug somewhere that others experience.
If you have a look at www.paulwilman.com you can see my cloud dashboard and if you click on the extra data button for any of the variables you will see what I mean. I have not noticed this before.
Paul
Hello, I had the same problem with yesterday's data. I manually deleted it by reloading the correct archive.
Posted: Sun Jun 15, 2025 4:36 pm
by lorenz1982
It happened again.
How can this be solved?
Posted: Sun Jun 15, 2025 5:43 pm
by pwilman
Lorenz,
I thought Boris implemented some sort of script that checked for instances of multiple daily records and then deleted the duplicates. It could have been that he implemented only on my version of the software???
I have not had any recurrence of the issue since I raised it with Boris. I noticed it happened about a week ago, but by the time I got round to thinking about reporting it the duplicates had disappeared.
One for Boris I think.
Paul
Posted: Mon Jun 16, 2025 7:56 am
by lorenz1982
Maybe it's as you say.
Today the duplicate of June 14th has disappeared.
Posted: Fri Jun 20, 2025 9:08 am
by MrPippoTN
Hi everyone. Over the past years, I have had four Davis weather stations installed for four friends of mine who live in my city. At one of these four stations, I also had Airlink installed (the Davis device for monitoring air quality). I would like to display the Airlink data on the website of a weather station that is located one kilometer away from the Airlink. So, I have this weather station that publishes data online through Aurora Meteobridge (https://content.meteobridge.com/dashboa ... /index.php), but unfortunately the Airlink is located in another place, with a different system for publishing wheater data online. Could you please implement a system suitable for displaying the Airlink data from a nearby station?
Posted: Sat Jun 21, 2025 7:17 pm
by pwilman
I got 7 instances today of the 20th June data. Strangely I got 7 instances of temp data from 20th June and only 5 instances of pressure data. Still here at 18:00
Paul
Posted: Fri Jun 27, 2025 12:35 pm
MrPippoTN wrote: Fri Jun 20, 2025 9:08 am Hi everyone. Over the past years, I have had four Davis weather stations installed for four friends of mine who live in my city. At one of these four stations, I also had Airlink installed (the Davis device for monitoring air quality). I would like to display the Airlink data on the website of a weather station that is located one kilometer away from the Airlink. So, I have this weather station that publishes data online through Aurora Meteobridge (https://content.meteobridge.com/dashboa ... /index.php), but unfortunately the Airlink is located in another place, with a different system for publishing wheater data online. Could you please implement a system suitable for displaying the Airlink data from a nearby station?
Why don't you make the airlink accessible from the internet (port forwarding on the router) and access it by that from your Meteobridge through the Internet. Meteobridge Aurora gets its data from a Meteobridge only, there will be no side channel implementation to collect data from other gear.
Posted: Fri Jun 27, 2025 12:39 pm
pwilman wrote: Sat Jun 21, 2025 7:17 pm I got 7 instances today of the 20th June data. Strangely I got 7 instances of temp data from 20th June and only 5 instances of pressure data. Still here at 18:00
Paul
Clean up is done once a day. I still wonder why this occurs at all. To make it harder to spot only some stations are impacted. It is on my todo list to avoid this happening instead of cleaning up... but the todo list is long...
Posted: Fri Jun 27, 2025 3:13 pm
by pwilman
Boris,
I dont know whether it is linked, but the day in question that I got about 8 instances of the same daily value I moved my console to another room, but did not remember to re-connect it to the closest mesh unit. As such it was constantly loosing WiFi signal all day. I only noticed from looking at my online graphs where they would plot for a few hour then have gaps for a few hours then plot for a few hours.
I rescanned my mesh network to connect the nano to the nearest node and had no further WiFi drop outs. I have also not had anymore duplicate entries.
Could be a co-incident, but thought it worth mentioning.
Paul
Posted: Wed Jul 02, 2025 11:46 am
by lorenz1982
Good morning. I still have several data repetition problems.
Repetition 3 times: May 24, June 5 - 14 - 24.
Repetition 2 times: June 27.
Another different problem:
June 28 and 29 have the same data but it is wrong.
From June 29 all the data is wrong by 1 day.
Example: July 1 shows the data of June 30.
Sorry for my English, I add the images.
Ich bin besser in Deutsch:
Guten Morgen. Ich habe noch Probleme mit Datenwiederholungen.
3-malige Wiederholung: 24. Mai, 5.–14.–24. Juni.
2-malige Wiederholung: 27. Juni.
Noch ein anderes Problem:
Die Daten vom 28. und 29. Juni sind zwar identisch, aber falsch.
Ab dem 29. Juni sind alle Daten um einen Tag falsch.
Zum Beispiel: Der 1. Juli zeigt die Daten vom 30. Juni.
Vielen Dank.
Posted: Wed Jul 02, 2025 2:16 pm
should work again fine.
Posted: Sun Jul 06, 2025 4:47 pm
by FedeMasso
Hello, good afternoon, I installed my new website, here it is for you to see: https://climachivilcoy.com.ar/
Here I am seeing that I have many duplicate files, is this normal or can I delete the ones that have the same name? :? :?
Posted: Tue Jul 08, 2025 11:04 pm
There are no duplicates, do not delete.
Posted: Sat Jul 12, 2025 2:06 am
by FedeMasso
Hi, thanks for responding. Yes, I looked at it carefully later and you're right. Sorry for misinterpreting. :)
Now I have a problem, when I click on the image of the WEBCAM, it remains with too much ZOOM, why is that? How can I solve it? :? :?
You can check it here: https://climachivilcoy.com.ar
I attach 2 images
Posted: Mon Jul 14, 2025 10:45 pm
Scaling of larger web cam image should be fine now.
