Aurora 2026 Rev-4.4X Release
Re: Aurora 2026 Rev-2.06 Release
lorenz1982 wrote: Wed Mar 18, 2026 9:54 am Good morning, sure, sorry. Aurora 2026 isn't on the main site yet, but it can be found here: https://meteoborgo.altervista.org/Aurora/index.php. Thanks.
Hello thanks that helped , I ended up installing newer simulators in XCODE . so can see the issue clearly once using iPad Air/Pro 11 M4 and M5 simulators
below is the result so the CSS change does fix it but I need to crosscheck this doesn't mess up all other devices so once I done that I will push an update but be a bit patient takes time to crosscheck devices ..Brian
Re: Aurora 2026 Rev-3 Release
March 17th-20th Aurora 2026 Rev 3
1. Fixed missing updated chart css file in simple update
2. This fixes chart anomaly appearance on charts.
3. Adds new CSS for better chart layout compatibility across devices (will never be perfect)
4. Recompiled Lightning charts pop up
5. Recompiled Soil Temp module and charts
6. Added compass day average wind direction arrow (blue arrow)
7. Tested 16 different IOS and Samsung,Microsoft device compatibility through simulator
8. Added better simpler compatibility for Samsung watches and Garmin (*just a basic view no charts)
9. Updated CSS for modules more universal css for all modules .
10. 14 specific device resolutions added to CSS for device compatibility (impossible to get it perfect but a suitable balance has been used )
11. Rev 3 is last update until late October 2026 if any ,please either use it or put it to one side there is not much I can do until later in the year due to other commitments .
..Brian
Download Simple-Update-Aurora-2026-Rev 3
https://www.mediafire.com/file/ikchswrb ... 3.zip/file
Download Aurora-2026-Rev_3.zip
https://www.mediafire.com/file/n5a3w691 ... 3.zip/file
alexeysailman
Post by alexeysailman »
Снимок экрана 2026-03-21 103153.png (1.39 MiB) Viewed 1895 times
lorenz1982
Post by lorenz1982 »
This happens every now and then:
Immagine 2026-03-24 164210.jpg (28.4 KiB) Viewed 1568 times
MeteoBorgo: www.meteoborgo.it
alexvanuxem
Post by alexvanuxem »
you where abke to download the rev-3 release?
Grtz
Alex
lorenz1982
alexvanuxem wrote: Tue Mar 24, 2026 7:35 pm you where abke to download the rev-3 release?
Grtz
Alex
No it doesn’t work.
Good morning please wait a couple of days(SATURDAY) for a new version(V4) reworked a lot of stuff think you will all like this in terms of appearance , compatibility ,very smooth on performance and visuals, new charts for 90% of modules large and small. removed previous version forgot to remove expiry nag screen so apologies then before i could upload replacement our internet which we upgraded to 1000mps fiber a couple weeks ago stopped working which eventually turned out to be a faulty fiber cable from the fiber distribution box took a few days to find the fault due to being routed behind a wall from the basement anyway all good now ..Brian
Re: Aurora 2026 Rev-4 Release
Download Simple-Update-Aurora-2026-Rev 4
https://www.mediafire.com/file/mcbsmum4 ... 4.zip/file
Download Aurora-2026-Master-Rev 4
https://www.mediafire.com/file/6lv1h8g2 ... 4.zip/file
March 17th-28th Aurora 2026 Rev 4
17th-20th March
22nd-28th March
1. Removed expiry beta screen
2. Added new woodsmoke charts
3. Added new woodsmoke modules with charts
4. Added new charts to various small modules
5. Removed unused outputs in console setup screen
6. Added new/more css screen device compatibility
7. Removed all custom modules code (no interest or requests received)
8. Added warning icons where criteria is met
9. Added new air quality small descriptions
10. Fixed luftdaten air quality charts
11. *Template is English only ,no plans to get involved in multiple language support ..sorry
12. Reworked IOS / Android Home Screen app icon
13. Please update to this version (4)for future updates support, older previous revisions will not be be supported or may see errors when using simple updates in the future
...Brian
Re: Aurora 2026 Rev-4B Release
Simple-Update-Aurora-2026-4B 6th April 2026
https://www.mediafire.com/file/eec8bypq ... B.zip/file
Aurora-2046-4B Master 6th April 2026
https://www.mediafire.com/file/0h7wejnd ... B.zip/file
1st-6th April 2026
1.Adds new charts to many small modules where valid
2.New earthquake module with chart
3.Reworked all small modules anomalies
4.Updated backup code via setup screen
5.Added windchill and heat index to chartstoday output position 21/22
6.Added new charts for windchill and heatindex(allow an hour or so for charts to build data also switch out modules according to season )
7.Small modules recompiled to slightly larger area to accommodate additional data
8.New SVG chart and info icons added
9.New IOS home screen app ICON
10.Recompiled and updated forecast module
11.Metar small module updated
This is the final version being sent to Boris to include this version into meteobridge software for 2026 . This version is far more manageable and
easier to implement ideas also fixing issues...Brian
woolfg
Post by woolfg »
Hi
I love the new template but I have noticed a couple of things ( I am being a bit picky though)
Firstly i'm pretty sure the wind is not stated in fractions of a degree - its always whole degrees (see attached)
Secondly the ATC Wind option doesn't appear to be working - degrees les than 100 degrees should still show three digits with a leading zero
Warm Wishes
Screenshot 2026-04-07 084613.jpg (21.49 KiB) Viewed 1436 times
Graham
lorenz1982
weatherist34 wrote: Mon Apr 06, 2026 5:06 pm Simple-Update-Aurora-2026-4B 6th April 2026
Just one question.
Once it's sent to Boris, will it no longer be possible to have the graphics like the one in my photo?
I like the new version, but I think the old one is perfect for a small display because it has large numbers.
woolfg wrote: Tue Apr 07, 2026 10:49 am Hi
Warm Wishes
Screenshot 2026-04-07 084613.jpgGraham
Hello stranger are you picky (older generation) or is it the modern view called OCD :-) just kidding :-) .
I will fix that and upload a simple update later this evening which I can include some other changes I missed adding on yesterday.
@Lorenzo I don't know I can't answer that if it will be removed or be optional or stay as it is. but all I will say is that version which has multiple layouts (10) will sooner or later have some significant issues with
future php releases , I've already seen a few issues using PHP 8.5.4 so if and when Boris updates the PHP core of meteobridge or the cloud then problems arise and requires some modifications to a lot of files across the 10 layouts ! its no easy fix just requires a lot of time and checking .
the current Aurora 2026 version from a maintenance point of view is considerably easier to maintain because I focused on structure for not only visual but maintaining going forward.
I will release another simple update later today with recompiled bottom modules again simplified .see below ..Brian
Screenshot 2026-04-07 at 13.00.00.png (93.84 KiB) Viewed 1251 times
woolfg
Post by woolfg »
Hi Brian
My wife might agree with you thats its OCD !!!
Just one other thing when I click on the AQ symbol within the chart menu I get a blank screen as shown in the attached.
Now it may be that its my data but either way its not a big issue
You can see my site here http://ringwoodweather.ddns.net:8000/Weather34
Warm Wishes
Graham
Screenshot 2026-04-07 102411.jpg (130.49 KiB) Viewed 1413 times
alexeysailman
lorenz1982 wrote: Tue Apr 07, 2026 11:16 am
Just one question.
I fully support it! The best template in history (without charts in the cards)! I only use it because of the enlarged font. Unfortunately, the latest version of Aurora on a separate screen is unacceptable to me. I only use it on my tablet or phone.
Re: Aurora 2026 Rev-4.1B Release
Download Simple-Update-Aurora-2026-Rev 4.1B
https://www.mediafire.com/file/3cvii9lt ... B.zip/file
Download Aurora-2026-Rev 4.1B
https://www.mediafire.com/file/r4373huy ... B.zip/file
April 8th-12th Aurora 2026 Rev 4.1B
1.Corrects ATC wind direction average..ref Graham
2.Adds close anywhere outside pop up window *note click anywhere in template outside window pop up or close with X
3.Corrected resizing of charts in small modules when in portrait or landscape on tablets ..Ref Geoff
4.Added resizing of 4K resolution image in webcam
5.Fixed error output logged in windchill/heatindex charts ..Ref Geoff
6.Fixed lightning chart icon always showing in menu.*new setup screen option added new in previous version 4 ..Ref Geoff
..Brian
Screenshot 2026-04-12 at 18.53.21.png (1.74 MiB) Viewed 989 times
