- FedeMasso
- Fresh Boarder
It's still the same, it looks bad
Meteorology enthusiast, from the city of Chivilcoy, Buenos Aires Province...
LIVE DATA FROM MY EMA:
https://climachivilcoy.com.ar
https://www.facebook.com/climachivilcoy
https://twitter.com/ClimaChivilcoy
can you please send me the URL, so that I can check? info(at)meteobridge.com
How about the little data banner that appears when you open the Webcam. Can it be removed?
It covers the timestamp on my sun image.
And I don't need it for the other image as I have the overlay done already.
TIA
D
TIA
D
lorenz1982
- Expert Boarder
There was another repetition of the data. However, the data from the last day is missing.
Can this be solved? Thanks.
- IMG_3408.jpeg (166.29 KiB) Viewed 9119 times
I checked graphs of some other users and they are fine. Does the issue repeat on next day?
Boris,
I had a wierd issue on 20th and 21st July. I got an entry for each day, but the entries are duplicates so are exactly the same for each day. Cou;d be co-incidence, but the same data can be seen for max and min for temp, pressure, humidity etc. Not seen this issue before - all other duplicates have exactly the same date. The data for the 22nd July was back to normal???
Paul
Paul
lorenz1982
- Expert Boarder
I checked today.admin wrote: Wed Jul 23, 2025 3:04 pm I checked graphs of some other users and they are fine. Does the issue repeat on next day?
July 21 and 22 have the same data but it is wrong.
Today the data is wrong by 1 day (July 23 shows the data of July 22).
There was a blackout on July 21st, and Meteobridge restarted after 30 minutes. Could this be the cause of the problem?
- IMG_1194.jpeg (82.63 KiB) Viewed 9092 times
- IMG_1193.jpeg (221.08 KiB) Viewed 9092 times
I have exactly the same problem.
so your data is moved one day into the past? Is that still the case?
lorenz1982
- Expert Boarder
Yes, that's right. It's still like that.admin wrote: Sat Jul 26, 2025 12:19 pm so your data is moved one day into the past? Is that still the case?
can you please send the link to your cloud dashboard to "info(at)meteobridge.com"?
lorenz1982
- Expert Boarder
Ok, just sent!admin wrote: Sat Jul 26, 2025 3:01 pm can you please send the link to your cloud dashboard to "info(at)meteobridge.com"?
Hello, I have the same problem.https://content.meteobridge.com/dashboa ... /index.php
I found the issue. Just testing the updated code.
