Page 7 of 13
Re: Aurora 2026 Rev-4.1B Release
Posted: Mon Apr 13, 2026 8:39 am
by weatherist34
Update for forecast scripts and windchill/heatindex, use simple update method in setup screen only valid for
rev 4.1B April 12th
Download wuforecast-update-April-13th
https://www.mediafire.com/file/mn2j9ytl ... h.zip/file
1.Fixed misalignment in forecast popup
2.Fixed overlap in small forecast module
3.Removed weather34-forecast-alt-2026.php option (please change to weather34-forecast-2026.php for future use)
4.Fixed alignment for windchill/heatindex phrase to close to icon
5.Fixed overlap when long airport name appears in Metar module
todo fix long place names overlap in earthquake module ..
..Brian..has always thanks for the feedback
- Screenshot 2026-04-13 at 09.39.33.png (1.29 MiB) Viewed 1174 times
Posted: Mon Apr 13, 2026 11:41 am
by lorenz1982
Hi, I'm just reporting these alignment issues on Google Chrome.
Posted: Mon Apr 13, 2026 1:13 pm
by weatherist34
hello you will have too put up with it for a while, im very busy with a new local project for a few weeks. that said charts are balanced across multiple screen sizes and devices so you may see some alignment differences but after cross checking across 18 variations of device resolutions i did not see any popping outside of the module widths, for example samsung devices renders css completely different from apple devices so there are variables to accommodate so this might render chrome slightly different to apple os and ios. have a good week.. brian
ios iphone 16 pro max
- IMG_0576.png (1.44 MiB) Viewed 1134 times
Re: Aurora 2026 Rev-4.3 Release
Posted: Mon Apr 27, 2026 7:08 am
by weatherist34
Simple-Update-Aurora-2026-April-27th
https://www.mediafire.com/file/kj3vzww2 ... 7.zip/file
Aurora-2026-Master-April-2026
https://www.mediafire.com/file/5mhp4o2i ... 6.zip/file
1.removed charts from small modules
2.reworked all small modules.
3.added color to sensor output values..(Ref Geoff)
4.minor change to Apple Watch and android watches view
5.earthquake pop up added chart and info
...Brian
- Screenshot 2026-04-27 at 07.49.10.png (1.23 MiB) Viewed 959 times
- 1.jpg (287.36 KiB) Viewed 959 times
- Screenshot 2026-04-27 at 09.00.32.png (1.14 MiB) Viewed 952 times
Re: Aurora 2026 Rev-4.3B Release
Posted: Tue Apr 28, 2026 7:20 am
by weatherist34
Sincere apologies forgot to include the wind module redesign
yesterday.
Simple-Update-Aurora-2026-4.3B-April 28th
https://www.mediafire.com/file/85e9jm7a ... h.zip/file
Aurora-2026-Master-April-2026-4.3B
https://www.mediafire.com/file/73kkxfzn ... B.zip/file
1.wind module redesign with ATC bearing
2.metar module alignment in phone view
3.apple watch fixed indoor module
4.apple watch fixed wind
..Brian
- 1.jpg (299.86 KiB) Viewed 921 times
- Screenshot 2026-04-28 at 08.07.44.png (1.13 MiB) Viewed 921 times
Posted: Tue Apr 28, 2026 12:03 pm
by lorenz1982
Minor issue on iPhone 17 Pro Max.
Posted: Tue Apr 28, 2026 9:26 pm
by xxvincixx
Hi Brian, I wanted to ask if it would be possible to insert the forescast/alt module into one of the main modules, since I don't use the small modules. Thanks.
Posted: Wed Apr 29, 2026 8:23 am
by weatherist34
good morning
no problem added forecast large module option to position 8-12 in setup screen will push simple update later today ..hope this all sufficient.
@Lorenzo fixed metar alignment
..Brian
- Screenshot 2026-04-29 at 09.22.51.png (1.27 MiB) Viewed 867 times
Re: Aurora 2026 Rev-4.3D Release
Posted: Wed Apr 29, 2026 11:06 am
by weatherist34
Simple-Update-Aurora2026-4.3D-April 29th
https://www.mediafire.com/file/mfd24oaa ... h.zip/file
Aurora-2026-Master-4.3D April 29th
https://www.mediafire.com/file/x3zzlxgg ... D.zip/file
1.Added Large WU Forecast Module
2.Added position option to setup screen for WU Forecast Module Large
3.Adjusted Metar alignment
4.Fixed missing color range for large feels like module
5.Fixed Large clock module showing colors for time
..Brian
- Screenshot 2026-04-29 at 12.17.41.png (1.15 MiB) Viewed 852 times
- setupscr.jpg (457.33 KiB) Viewed 857 times
Posted: Wed Apr 29, 2026 12:53 pm
by lorenz1982
With the latest update there is this problem:
Posted: Wed Apr 29, 2026 4:03 pm
by weatherist34
I think the update file got messed up because I can reproduce it in any screen or resolution .. I will upload again shortly
- 1.jpg (74.57 KiB) Viewed 833 times
Posted: Wed Apr 29, 2026 6:37 pm
by pwilman
Its mucked up for me too.
Re: Aurora 2026 Rev-4.3E Release
Posted: Wed Apr 29, 2026 7:10 pm
by weatherist34
Simple-Update-Aurora-2026-4.3E
https://www.mediafire.com/file/tkni5rxa ... 9.zip/file
Aurora-2026-Master-4.3E
https://www.mediafire.com/file/zcb5g9ci ... 9.zip/file
hopefully fixes corrupt update ?? can't replicate any issue here with wind module (all browsers, device simulators checked)
Brian
- w.jpg (90.88 KiB) Viewed 820 times
Posted: Wed Apr 29, 2026 9:21 pm
by pwilman
Just upgraded to the latest simple update (version E) and the wind direction is still not working properly.
http://www.paulwilman.com/W34/
Posted: Wed Apr 29, 2026 9:35 pm
by weatherist34
pwilman wrote: Wed Apr 29, 2026 9:21 pm
hi Paul can you go into setup and turn on ATC or set to yes ?
