reading 200degF when -10degF
Posted: Sat Nov 29, 2014 6:25 pm
by lanwickum
My temp dropped below zero here and suddenly it starting reading very high. Wondering of there is a bug or setting I don't about. I have only had this station for maybe 2 weeks. wunderground station is kmtshelb7 if anyone wants to look at data.
The accrual temps in title are not correct, but close. Appears that on nov 28th when temp dropped to a negative it started reading the approximately 200degF.
Thank you
Re: reading 200degF when -10degF
Posted: Sun Nov 30, 2014 12:08 pm
Are you experiencing this...
a) on the vantage console?
b) on a Meteohub/Meteobridge connected via a Davis data logger to a console or envoy?
c) by using Meteostick with Meteohub/Meteobridge?
Posted: Sun Nov 30, 2014 7:19 pm
by lanwickum
I have no console. Only airbridge with meteostick? I bought through ambient weather. the temp just went into positive today and is reading correct again. Something must have a calculation error? My live data, when connected to meteobridge, says same as weather underground.
203degF is actually -1degF. temps drops properly from 203 as temps drop.
Posted: Wed Dec 03, 2014 1:38 am
This looks like a computation error. As I don't have a chance to go into minus degrees Fahrenheit
here in northern Germany (although I feel it is uncomfortable cold in the winter), it would be great if
you could give me access to your Meteobridge as explained here:
viewtopic.php?f=57&t=9885
Please send link to "info(at)smartbedded.com" and set password to "needhelp". Thanks.
Posted: Wed Jan 14, 2015 10:15 pm
by akillip
Hello, my Davis vantage2 also will read about 100 degrees positive for each degree below zero the temp drops. I do have a console and the temp on the console reads ok. The weather underground folks verified that the data I was sending them was incorrect data an they have removed me from the site until the problem is fixed. Can you help
Posted: Wed Jan 14, 2015 10:40 pm
just reboot your Meteobridge and be fine. This bug was solved a week ago.
