MeteoBridge TL-MR3020 Configuration Backup **solved**
Posted: Fri Jan 02, 2015 11:56 am
by IC16
Setup: TL-MR3020 Running Linux 3.3.8 mips (BE), FW 1.4, MeteoBridge 2.4 (5389).
How do you backup the master configuration file on the MeteoBridge that contains all the network, station, weather network and push setup configuration data?
Thanks in advance for your help/ideas.
Re: MeteoBridge TL-MR3020 Configuration Backup
Posted: Fri Jan 02, 2015 3:27 pm
There is no feature on the web interface to do so.
When you login via ssh you will find the config file at "/root/meteobridge.conf".
While this contains the config data for the web interface, network settings needed for operation
are located in the "/etc/config/" folders. Network config files in there are generated by Meteobridge when
pressing "save and apply and reboot" button on "setup network" tab.
Posted: Fri Jan 02, 2015 3:53 pm
by IC16
Excellent. Thanks for the instructions. I will give this a try.
Happy New Year.
Posted: Sat Jan 03, 2015 3:54 am
by Ladd
For us folks who are less computer inclined, perhaps in some future version of Meteobridge, you would be so kind as to add a "one click" button for exporting the complete configuration info. I guess this would infer a "one click" button for importing said file also.
Posted: Sat Jan 03, 2015 10:58 am
That sounds reasonable. But I would spare the network data as importing that will normally do more harm than good.
As you need the Meteobridge already running fine in the network to import a configuration backup it will
not make sense to import another network configuration with good chances to render the unit no longer available in
the current network situation.
Any other pieces of information, that should not be restored?
Timezone looks like a candidate for not being restored to me.
Posted: Tue Jan 13, 2015 4:59 pm
Implemented with latest update.
Re: MeteoBridge TL-MR3020 Configuration Backup **solved**
Posted: Wed Jan 14, 2015 9:39 am
by IC16
Excellent. Thanks for actioning that so quickly.
All the best.
