WeatherLink and MeteoBridge **Solved**
Posted: Fri Feb 13, 2015 5:33 pm
by Seedubs
I have my Meteobridge up and running ok with my Vantage Vue and USB Datalogger, but noticed in the release notes for 2.5 that there is now the facility to have a PC program running in parallel to Meteobridge?
" Meteobridge allows parallel use of the Vantage by a PC program, which connects to the Meteobridge on port 22222 (like with a Davis IP logger). Meteobridge can also pass through the connection to the Davis station to an additional PC weather program of your liking. Therefore, you can use Meteobridge and a PC weather program in parallel."
Does this mean I can also use my WeatherLink software and configure it to receive data on port 22222 from Meteobridge? If so can anyone explain how this is achieved, I attempted to start WeatherLink on TCP/IP with a port of 22222 and it failed to connect, if I attempt the connection via USB (I have a USB datalogger) then it warns me not to do this as the datalogger will no longer update any other device (Meteobridge)?
Cheers
Chris
Re: WeatherLink and MeteoBridge
Posted: Fri Feb 13, 2015 8:52 pm
Seedubs wrote:Does this mean I can also use my WeatherLink software and configure it to receive data on port 22222 from Meteobridge?
yes, exactly. Just configure your WeatherLink like connecting it via TCP/IP with the IP of your Meteobridge and using the default WLIP port 22222.
Posted: Fri Feb 13, 2015 10:24 pm
by Seedubs
I am doing this, but get the following error:
"TCP/IP : Communication error found. Check settings and try again."
I have rebooted my Meteobridge to pick up any changes to 2.5 but this is still showing as an error.
Cheers
Chris
Posted: Sun Feb 15, 2015 1:51 am
by Seedubs
Any suggestions, is this an existing error, or do I need to do something else?
(ver Feb 8 2015, build 5958)
I am seeing this in the log file:
192.168.1.64's request on port 22222 accepted.
logger (13.02.2015 23:46:45): connection on port 22222 closed.
logger (13.02.2015 23:46:45): 192.168.1.64's request on port 22222 accepted.
logger (13.02.2015 23:46:53): connection on port 22222 closed.
logger (13.02.2015 23:46:53): 192.168.1.64's request on port 22222 accepted.
logger (13.02.2015 23:47:02): connection on port 22222 closed.
logger (13.02.2015 23:47:02): 192.168.1.64's request on port 22222 accepted.
logger (13.02.2015 23:47:11): connection on port 22222 closed.
logger (13.02.2015 23:47:11): 192.168.1.64's request on port 22222 accepted.
logger (13.02.2015 23:47:22): connection on port 22222 closed.
logger (13.02.2015 23:47:22): 192.168.1.64's request on port 22222 accepted.
logger (13.02.2015 23:47:30): connection on port 22222 closed.
logger (13.02.2015 23:47:30): 192.168.1.64's request on port 22222 accepted.
logger (13.02.2015 23:47:39): connection on port 22222 closed.
logger (13.02.2015 23:47:39): 192.168.1.64's request on port 22222 accepted.
logger (13.02.2015 23:47:48): connection on port 22222 closed.
Chris
Posted: Sun Feb 15, 2015 7:15 pm
Is the davis logger an ip model?
Posted: Sun Feb 15, 2015 10:15 pm
by Seedubs
No, a USB model.
Posted: Thu Feb 19, 2015 2:21 pm
by Seedubs
Any suggestions? It works ok with Culumus?
Posted: Thu Feb 19, 2015 9:04 pm
by xionias
works fine to me.
Just tried to connect the weatherlink which is on my main desktop computer, to meteobridge which is at the other part of the house.
Downloaded all the missing data from the data logger!
Posted: Fri Feb 20, 2015 9:53 pm
by Seedubs
Well, its good to know it works, but mine does not, is there anything special I need to do apart from configuring the 'Communications Port' > 'Local Device ID' settings within WeatherLink?
By the way, my version of WeatherLink is 6.0.3, just in case it is a version problem?
Cheers
Chris
Posted: Sat Feb 21, 2015 10:55 am
by xionias
mine 6.03 too.
TCP/IP setting, 22222 port. Needed to press test for a couple of times, untill the station was found. Tried it on another computer in the same network, and works fine. In fact I copied all the weatherlink folder to the other computer, and connected automatically...
Posted: Sat Feb 21, 2015 5:59 pm
by Seedubs
Well obviously the network is fine as Culumbus connects on the same port & IP to meteobridge, so must be something in WL, might try reinstalling and seeing what happens.
Cheers
Chris
Posted: Sat Feb 21, 2015 6:17 pm
by Seedubs
Well, reinstalled, and still the same, I suppose I will have to use Cumulus.
Posted: Sun Feb 22, 2015 12:23 pm
by BigJazza
Hi there, my weatherlink works fine also, but in the Davies software you have to programme the Remote IP and NOT the Local Device ID. That is the second box in that part of the communications form of Weatherlink. I was initially caught out by this, as it is a little counter-intuitive. I understand the "Local" box searches for a a Davies MAC number. I wonder if that might be your problem?
John
Posted: Sun Feb 22, 2015 7:32 pm
by Seedubs
BigJazza,
Many thanks, that was it, I had tried the remote setting before, but failed and therefore dismissed it, as you said, seems counter-intuitive when I am connecting locally.
Thanks for all the help guys, much appreciated.
