Meteobridge does now support Davis repeaters via Meteostick
Post by admin » Sat Mar 07, 2015 1:24 pm
This feature has been requested by quite some Meteobridge/Meteostick users.
Once this new Meteostick firmware has proven to be stable it will be made the next
official Meteostick firmware that can be installed by one-click on "system" tab.
Please find details here: viewtopic.php?f=59&t=10243
gcams
Re: Meteobridge does now support Davis repeaters via Meteostick
Post by gcams » Fri Nov 02, 2018 6:59 pm
I'm wondering how mature the repeater support is now in meteostick?
I have a Davis station in Australia that is constantly having issues with the data-logger locking up inside the Davis console and dropping the data feed to the meteoplug box (MR3020 via RS232->USB). I'm thinking of trying meteostick as a replacement, but the setup uses a repeater (2 hops). Will meteostick work OK in this setup reliably?
Thanks for any thoughts/experience!
Post by admin » Fri Nov 02, 2018 7:26 pm
I tested it and it worked. What else can I say?
gcams
Post by gcams » Mon Nov 05, 2018 8:23 pm
Thank you Boris, I just wanted to make sure it was still supported and that I can expect it to work OK using a Meteoplug client (MR3020). Am I correct in thinking there is nothing special I would need to do inside Meteoplug's meteostick configuration, other than select the appropriate transmitter ID/station type based on the ID being transmitted by the remote weather station at the far end of the repeater link?
Thank you again!
Post by admin » Tue Nov 06, 2018 12:28 am
To be honest the Meteoplug client port of the MR3020 is very old and no longer actively supported (as the Meteobridge is todays Meteoplug client). I can for sure speak about Meteobridge and Meteohub and there it is supported fine.
gcams
Post by gcams » Thu Nov 08, 2018 9:42 am
OK, thanks Boris. It sounds like to be sure, I probably need to upgrade this setup to Meteobridge. I'll need to take a look at my options there. Thanks again for the feedback.
