WMR200A & Meteohub 5i: No Wind Sensor data **solved**
Posted: Wed Jun 17, 2015 8:40 pm
by russcron
Hello All:
About a month ago I noticed that wind speed and direction were not reporting to Weather Underground. Meteohub 5i shows valid data for all other sensors. Wind0 says Last signal = 'never'. I tried new pod batteries and even a replacement wind pod I had on hand. No joy. The WMR200 console shows current correct wind speed and direction. I cleared the WMR200 memory. I performed a Meteohub 'recalculate'. Still no good.
Does anyone have a suggestion?
Thanks fellow forum members.
Russ in West Virginia, USA.
Re: WMR200A & Meteohub 5i: No Wind Sensor data
Posted: Fri Jun 19, 2015 8:44 pm
you need to assign an existing outdoor temp sensor on "weather station" page and press "save" there.
Posted: Sun Jun 21, 2015 5:14 am
by russcron
Thanks admin. That worked. I would never have figured that out!
This system worked for years without that assignment. Did the Meteohub software upgrade I installed several months ago cause the problem?
