Version 2.8 HTTP request no longer working **solved**
Posted: Thu Mar 03, 2016 12:34 pm
by frogfoot
Hi, I have just loaded version 2.8 (3-March) and noticed the the HTTP upload I had defined no longer works.
The 'Live data' tab simply says " HTTP Upload: No HTTP traffic"
Have there been any changes to the HTTP request setting?
Re: Version 2.8 HTTP request no longer working
Posted: Thu Mar 03, 2016 12:38 pm
by MeteoOudkarspel
I have the same problem too.
I have switched back to version 2.7 and all is working fine.
Posted: Thu Mar 03, 2016 2:12 pm
by frogfoot
I tried downgrading to 2.7 and all worked as expected. Then I re-booted to install 2.8 and observed the same symptoms
Output of system log follows...
oled (03.03.2016 12:00:14): process started.
wnetd (03.03.2016 12:01:40): process started.
test5m (03.03.2016 12:01:44): logger stalled, will be restarted now.
test5m (03.03.2016 12:01:44): database daemon stalled, will be restarted now.
database (03.03.2016 12:01:44): process started.
logger (03.03.2016 12:01:44): database connected.
logger (03.03.2016 12:01:45): Historical data loaded (40 records).
logger (03.03.2016 12:01:45): data logger (version 5.0p, build 9367) started.
logger (03.03.2016 12:01:46): connect station 0 (Meteostick Vantage via USB serial).
logger (03.03.2016 12:01:46): connect station 9 (System Data via Plug-in).
logger (03.03.2016 12:01:48): transmitter 1 registered as ISS
logger (03.03.2016 12:01:48): Meteostick Version 2.4
logger (03.03.2016 12:01:48): debug off
logger (03.03.2016 12:01:48): verbose off
logger (03.03.2016 12:01:48): output raw (8 bytes)
logger (03.03.2016 12:01:48): output raw (10 bytes)
logger (03.03.2016 12:01:48): filter on
logger (03.03.2016 12:01:48): rx threshold set to -80db
logger (03.03.2016 12:01:48): listening to transmitter 1
logger (03.03.2016 12:01:48): bandwidth narrow
logger (03.03.2016 12:01:49): chip authentication ok: 14
logger (03.03.2016 12:01:49): frequency band 868MHz (EU)
wnetd (03.03.2016 12:02:53): process received signal (11) and terminated.
logger (03.03.2016 12:02:59): open named pipe "/dev/meteobridge" failed: No such device or address
logger (03.03.2016 12:03:06): Bad wind0(0) sensor data, "chill x10" (-999) out of range [-700:1500]
logger (03.03.2016 12:03:07): open named pipe "/dev/meteobridge" failed: No such device or address
logger (03.03.2016 12:03:13): open named pipe "/dev/meteobridge" failed: No such device or address
logger (03.03.2016 12:03:13): Bad wind0(0) sensor data, "chill x10" (-999) out of range [-700:1500]
logger (03.03.2016 12:03:16): Bad wind0(0) sensor data, "chill x10" (-999) out of range [-700:1500]
logger (03.03.2016 12:03:19): open named pipe "/dev/meteobridge" failed: No such device or address
logger (03.03.2016 12:03:21): Bad wind0(0) sensor data, "chill x10" (-999) out of range [-700:1500]
logger (03.03.2016 12:03:24): Bad wind0(0) sensor data, "chill x10" (-999) out of range [-700:1500]
logger (03.03.2016 12:03:26): Bad wind0(0) sensor data, "chill x10" (-999) out of range [-700:1500]
logger (03.03.2016 12:03:27): open named pipe "/dev/meteobridge" failed: No such device or address
logger (03.03.2016 12:03:32): Bad wind0(0) sensor data, "chill x10" (-999) out of range [-700:1500]
logger (03.03.2016 12:03:34): Bad wind0(0) sensor data, "chill x10" (-999) out of range [-700:1500]
logger (03.03.2016 12:03:35): open named pipe "/dev/meteobridge" failed: No such device or address
logger (03.03.2016 12:03:36): Bad wind0(0) sensor data, "chill x10" (-999) out of range [-700:1500]
logger (03.03.2016 12:03:39): Bad wind0(0) sensor data, "chill x10" (-999) out of range [-700:1500]
logger (03.03.2016 12:03:41): open named pipe "/dev/meteobridge" failed: No such device or address
logger (03.03.2016 12:03:42): Bad wind0(0) sensor data, "chill x10" (-999) out of range [-700:1500]
logger (03.03.2016 12:03:44): Bad wind0(0) sensor data, "chill x10" (-999) out of range [-700:1500]
logger (03.03.2016 12:03:47): open named pipe "/dev/meteobridge" failed: No such device or address
logger (03.03.2016 12:03:52): open named pipe "/dev/meteobridge" failed: No such device or address <--- last line repeated several times
test5m (03.03.2016 12:06:19): weathernet daemon stalled, will be restarted now.
wnetd (03.03.2016 12:06:19): process started.
Posted: Thu Mar 03, 2016 2:33 pm
by plex
I see same pattern here on my MBP Red - no more http request or ftp upload
oled (03.03.2016 12:21:00): process started.
wnetd (03.03.2016 13:22:30): process started.
test5m (03.03.2016 13:24:41): logger stalled, will be restarted now.
test5m (03.03.2016 13:24:42): database daemon stalled, will be restarted now.
database (03.03.2016 13:24:42): process started.
logger (03.03.2016 13:24:42): database connected.
logger (03.03.2016 13:24:42): Historical data loaded (63 records).
logger (03.03.2016 13:24:42): data logger (version 5.0p, build 9367) started.
logger (03.03.2016 13:24:44): connect station 0 (Meteostick Vantage via USB serial).
logger (03.03.2016 13:24:44): connect station 9 (System Data via Plug-in).
logger (03.03.2016 13:24:46): transmitter 1 registered as ISS
logger (03.03.2016 13:24:46): transmitter 2 registered as Wind
logger (03.03.2016 13:24:46): Meteostick Version 2.3b3
logger (03.03.2016 13:24:46): debug off
logger (03.03.2016 13:24:46): verbose off
logger (03.03.2016 13:24:46): output raw (8 bytes)
logger (03.03.2016 13:24:46): output raw (10 bytes)
logger (03.03.2016 13:24:46): filter on
logger (03.03.2016 13:24:46): rx threshold set to -85db
logger (03.03.2016 13:24:46): listening to transmitter 1 2
logger (03.03.2016 13:24:46): bandwidth narrow
logger (03.03.2016 13:24:46): chip authentication ok: 14
logger (03.03.2016 13:24:46): frequency band 868MHz (EU)
wnetd (03.03.2016 13:25:39): process received signal (11) and terminated.
logger (03.03.2016 13:25:43): open named pipe "/dev/meteobridge" failed: No such device or address
logger (03.03.2016 13:25:50): open named pipe "/dev/meteobridge" failed: No such device or address
logger (03.03.2016 13:25:55): open named pipe "/dev/meteobridge" failed: No such device or address
test5m (03.03.2016 13:25:57): weathernet daemon stalled, will be restarted now.
wnetd (03.03.2016 13:25:57): process started.
wnetd (03.03.2016 13:26:10): process received signal (11) and terminated.
logger (03.03.2016 13:26:16): open named pipe "/dev/meteobridge" failed: No such device or address
logger (03.03.2016 13:26:24): open named pipe "/dev/meteobridge" failed: No such device or address
logger (03.03.2016 13:26:29): open named pipe "/dev/meteobridge" failed: No such device or address
Sent E-Mail: No email traffic
no Triggered Display: 2016-03-03 13:30:46 Success!
FTP Upload: No upload
FTP Upload (Camera): No upload
Posted: Thu Mar 03, 2016 6:36 pm
Bug is solved with just uploaded release. Just reboot please.
