what is the RF sensitivity setting? (MB Pro) **solved**
Posted: Thu Mar 10, 2016 12:00 pm
by frogfoot
The wiki states to initially set the RF sensitivity to -90db, however I cant find any further reference to it, should it just be left at -90db or should it be brought down to say average signal strength -10 db
Re: what is the RF sensitivity setting? (MB Pro)
Posted: Thu Mar 10, 2016 9:11 pm
by plex
frogfoot wrote:The wiki states to initially set the RF sensitivity to -90db, however I cant find any further reference to it, should it just be left at -90db or should it be brought down to say average signal strength -10 db
Just google it
Meteostick and Red Cap Meteobridge PRO
Meteostick needs selection of a RF band to work with. Please select the setting that matches your geography. In addition you also have to define an RF sensitivity. Please make sure that that is about 10db more sensitive than signal level from incoming data. When you see data coming in on "Live Data" tab with -70db for example, then -80db is a good sensitivity level. Increasing sensitivity of the receiver too much will collect tons of RF noise which will disturb picking up valid data significantly. For normal Davis operation "narrow" bandwidth setting is best. If you want to work with signals retransmitted from your Vantage console, please switch to "normal" to limit dropped packets. Rain bucket size should also match the size used in your rain sensor.
Source:
http://www.meteobridge.com/wiki/index.p ... ct_Station
Posted: Thu Mar 10, 2016 10:32 pm
by frogfoot
Thanks, don't know how I missed that!
Re: what is the RF sensitivity setting? (MB Pro) **solved**
Posted: Fri Mar 11, 2016 5:06 am
by blacklistedcard
Thanks... This message thread help me a lot with my meteostick settings...
