TL-WR703N fast blinking **solved**
Posted: Wed May 04, 2016 12:42 am
by Karl139
My TL-WR703N frezzed during a reboot. Now is stucked in fail safe mode, endless fast blinking and only reachable via OpenWRT telnet on 192.168.1.1. There is no http access.
Any help is appreciated.
/ Johan
Re: TL-WR703N fast blinking
Posted: Fri May 06, 2016 10:12 am
Fast blinking indicates that I cannot read the application stack from the Meteobridge server.
It can be a DNS or DHCP problem on your side.
Is the Meteobridge defined as a DHCP LAN device or did you use WiFi or static IP settings?
Posted: Tue May 10, 2016 10:47 pm
by Karl139
Thanks for your answer.
There was probably a hardware failure. Finally the 703 unit died and was not accessible at all. The unit was scrapped and will be replaced.
