MB pro (red) eccentricities **solved**
Posted: Sat May 21, 2016 6:21 pm
by peterb
I wonder if any one else is experiencing eccentricities with their MB pro (red), it is transmitting information form my Davis Vantage Pro2 (batteries all a ok) plus solar sensor and extra temperature sensor in my pond, out by a LAN(not WiFi) to BT Home hub 5 on a fibre connection. The VP2 is connected to Cumulus on a PC which is not always on, hence the MB Pro. Mine worked very well at first. I noticed that there was readings missing which I put down to a poor connection with the SSI. Admin suggested raising the sensitivity (which they very helpfully did remotely) to cut out noise and if that did not work to re transmit form the Davis which I have eventually done. The main reason for this tinkering was I kept noticing the WeatherUnderground graphs had gaps in them, it appeared to help (not having read all of this excellent forum). Then the display which was set to BIG-scroll-ISO.dsp stopped and only showed the start screen but all was working so I left it as it was. The live data page always showed green ticks so all was well? Then we noticed it had stopped tweeting a couple of re boots got it going intermittently, test would always work. WOW and CWOP always appeared to get data (as did WU from our Netatmo except when MetoWare plus when down as that is used to retransmit) so I ruled out connection and hub. Last week we noticed no data to WU and no tweets, display still only showing start screen. So had a check, green ticks in all the right places including live data except it said intermittently the web cam pics were going out too large, software was the most up to the date. Having a read the instructions and the Wiki and tinkered and rebooted to no avail, I decided to to a factory reset and start again, set MB going again and had problems but realised I should have updated the software (good job I made notes as I set it up the first time!) Anyway to cut a long story short 3 days of perfect results then to day at 5.43am lost data and gap the WU until I rebooted at 8.15am so far today 2 total drop outs and many on the solar only? Interestingly I only have 3 options for the display all data metric or imperial which work or RF which shows nothing? Having read a lot of the forum now I can see there are WU up load problems.
Any suggestions as to what I'm doing wrong? ( PS keep it simple we are not in the first flush of youth :wink: )
This is me at WU:
Davis
ISCOTLAN367
Netatmo
IMUSSELB7
Re: MB pro (red) eccentricities
Posted: Mon May 23, 2016 7:06 pm
by peterb
His is what mines says when it looses connection to the VP2 on retransmmit at the moment its about 1meter away, there is no data on the MBpros screen and at WU
logger (23.05.2016 17:11:32): output raw (8 bytes)
logger (23.05.2016 17:11:32): output raw (10 bytes)
logger (23.05.2016 17:11:32): filter on
logger (23.05.2016 17:11:32): rx threshold set to -85db
logger (23.05.2016 17:11:32): listening to transmitter 2 3
logger (23.05.2016 17:11:32): bandwidth normal
logger (23.05.2016 17:11:33): chip authentication ok: 14
logger (23.05.2016 17:11:33): frequency band 868MHz (EU)
database (23.05.2016 17:12:14): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:12:15): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:12:33): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:12:33): cannot commit (after 0 tries in 20ms): database or disk is full
database (23.05.2016 17:12:34): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:13:00): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:13:01): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:13:02): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:13:05): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:13:13): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:13:27): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:13:27): cannot commit (after 0 tries in 3ms): database or disk is full
database (23.05.2016 17:13:34): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:14:01): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:14:02): cannot commit (after 0 tries in 22ms): database or disk is full
database (23.05.2016 17:14:02): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:14:08): cannot commit (after 1 tries in 52ms): database or disk is full
database (23.05.2016 17:14:10): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:14:26): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:14:33): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:14:34): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:14:34): cannot commit (after 0 tries in 13ms): database or disk is full
database (23.05.2016 17:15:01): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:15:01): cannot commit (after 0 tries in 38ms): database or disk is full
database (23.05.2016 17:15:01): cannot commit (after 0 tries in 12ms): database or disk is full
database (23.05.2016 17:15:02): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:15:03): cannot commit (after 0 tries in 2ms): database or disk is full
logger (23.05.2016 17:15:06): parent process received termination signal (15).
logger (23.05.2016 17:15:06): child process received termination signal (15).
logger (23.05.2016 17:15:06): disconnect station 0 (Meteostick Vantage): exit
logger (23.05.2016 17:15:06): disconnect station 9 (System Data): exit
logger (23.05.2016 17:15:06): data logger stopped.
database (23.05.2016 17:15:06): process terminated normally.
test5m (23.05.2016 17:15:07): USB storage remounted: /dev/sda
database (23.05.2016 17:15:07): process started.
logger (23.05.2016 17:15:08): database connected.
logger (23.05.2016 17:15:08): Historical data loaded (46 records).
logger (23.05.2016 17:15:08): data logger (version 5.0p, build 9911) started.
logger (23.05.2016 17:15:09): connect station 0 (Meteostick Vantage via USB serial).
logger (23.05.2016 17:15:09): connect station 9 (System Data via Plug-in).
logger (23.05.2016 17:15:10): transmitter 2 registered as Temperature
logger (23.05.2016 17:15:10): transmitter 3 registered as ISS
logger (23.05.2016 17:15:10): Meteostick Version 2.4
logger (23.05.2016 17:15:10): debug off
logger (23.05.2016 17:15:10): verbose off
logger (23.05.2016 17:15:10): output raw (8 bytes)
logger (23.05.2016 17:15:10): output raw (10 bytes)
logger (23.05.2016 17:15:10): filter on
logger (23.05.2016 17:15:10): rx threshold set to -85db
logger (23.05.2016 17:15:10): listening to transmitter 2 3
logger (23.05.2016 17:15:10): bandwidth normal
logger (23.05.2016 17:15:11): chip authentication ok: 14
logger (23.05.2016 17:15:11): frequency band 868MHz (EU)
database (23.05.2016 17:16:03): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:16:08): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:16:10): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:16:11): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:16:12): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:16:14): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:17:01): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:17:02): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:17:02): cannot commit (after 0 tries in 3ms): database or disk is full
database (23.05.2016 17:17:03): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:17:06): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:17:07): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:17:12): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:17:12): cannot commit (after 0 tries in 3ms): database or disk is full
database (23.05.2016 17:17:28): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:17:29): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:18:01): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:18:02): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:18:02): cannot commit (after 0 tries in 7ms): database or disk is full
database (23.05.2016 17:18:03): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:18:09): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:18:12): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:18:12): cannot commit (after 1 tries in 52ms): database or disk is full
database (23.05.2016 17:18:30): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:18:50): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:19:01): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:19:02): cannot commit (after 0 tries in 3ms): database or disk is full
database (23.05.2016 17:19:02): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:19:03): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:19:12): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:19:13): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:19:21): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:19:22): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:19:29): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:19:30): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:19:40): cannot commit (after 1 tries in 52ms): database or disk is full
database (23.05.2016 17:20:02): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:20:03): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:20:04): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:20:04): cannot commit (after 0 tries in 23ms): database or disk is full
database (23.05.2016 17:20:05): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:20:12): cannot commit (after 0 tries in 12ms): database or disk is full
database (23.05.2016 17:20:12): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:20:15): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:20:16): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:21:01): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:21:02): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:21:03): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:21:04): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:21:06): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:21:08): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:21:12): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:21:12): cannot commit (after 0 tries in 12ms): database or disk is full
logger (23.05.2016 17:21:33): parent process received termination signal (15).
logger (23.05.2016 17:21:33): child process received termination signal (15).
logger (23.05.2016 17:21:33): disconnect station 0 (Meteostick Vantage): exit
logger (23.05.2016 17:21:33): disconnect station 9 (System Data): exit
database (23.05.2016 17:21:33): process terminated normally.
test5m (23.05.2016 17:21:35): USB storage remounted: /dev/sda
database (23.05.2016 17:21:35): process started.
logger (23.05.2016 17:21:35): database connected.
logger (23.05.2016 17:21:35): Historical data loaded (46 records).
logger (23.05.2016 17:21:35): data logger (version 5.0p, build 9911) started.
logger (23.05.2016 17:21:36): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (23.05.2016 17:21:36): connect station 9 (System Data via Plug-in).
logger (23.05.2016 17:22:06): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (23.05.2016 17:22:36): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (23.05.2016 17:23:06): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
database (23.05.2016 17:23:29): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:23:30): cannot commit (after 0 tries in 2ms): database or disk is full
logger (23.05.2016 17:23:36): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
database (23.05.2016 17:24:01): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:24:01): cannot commit (after 0 tries in 3ms): database or disk is full
logger (23.05.2016 17:24:06): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (23.05.2016 17:24:36): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
database (23.05.2016 17:25:01): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:25:02): cannot commit (after 0 tries in 2ms): database or disk is full
logger (23.05.2016 17:25:06): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (23.05.2016 17:25:18): parent process received termination signal (15).
logger (23.05.2016 17:25:18): child process received termination signal (15).
logger (23.05.2016 17:25:18): disconnect station 9 (System Data): exit
logger (23.05.2016 17:25:18): data logger stopped.
database (23.05.2016 17:25:19): process terminated normally.
test5m (23.05.2016 17:25:20): USB storage remounted: /dev/sda
database (23.05.2016 17:25:20): process started.
logger (23.05.2016 17:25:20): database connected.
logger (23.05.2016 17:25:21): Historical data loaded (46 records).
logger (23.05.2016 17:25:21): data logger (version 5.0p, build 9911) started.
logger (23.05.2016 17:25:21): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (23.05.2016 17:25:21): connect station 9 (System Data via Plug-in).
logger (23.05.2016 17:25:51): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (23.05.2016 17:26:21): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (23.05.2016 17:26:51): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
database (23.05.2016 17:27:01): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:27:02): cannot commit (after 0 tries in 2ms): database or disk is full
logger (23.05.2016 17:27:21): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (23.05.2016 17:27:51): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
database (23.05.2016 17:28:01): cannot commit (after 0 tries in 2ms): database or disk is full
logger (23.05.2016 17:28:21): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (23.05.2016 17:28:51): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
database (23.05.2016 17:29:01): cannot commit (after 0 tries in 2ms): database or disk is full
logger (23.05.2016 17:29:21): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (23.05.2016 17:29:51): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
database (23.05.2016 17:30:01): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:30:01): cannot commit (after 1 tries in 52ms): database or disk is full
database (23.05.2016 17:30:02): cannot commit (after 0 tries in 2ms): database or disk is full
logger (23.05.2016 17:30:21): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (23.05.2016 17:30:51): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
database (23.05.2016 17:31:01): cannot commit (after 0 tries in 2ms): database or disk is full
logger (23.05.2016 17:31:21): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (23.05.2016 17:31:42): parent process received termination signal (15).
logger (23.05.2016 17:31:42): child process received termination signal (15).
logger (23.05.2016 17:31:42): disconnect station 9 (System Data): exit
logger (23.05.2016 17:31:42): data logger stopped.
database (23.05.2016 17:31:43): process terminated normally.
test5m (23.05.2016 17:31:44): USB storage remounted: /dev/sda
database (23.05.2016 17:31:44): process started.
logger (23.05.2016 17:31:45): database connected.
logger (23.05.2016 17:31:45): Historical data loaded (46 records).
logger (23.05.2016 17:31:45): data logger (version 5.0p, build 9911) started.
logger (23.05.2016 17:31:45): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (23.05.2016 17:31:45): connect station 9 (System Data via Plug-in).
logger (23.05.2016 17:32:15): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (23.05.2016 17:32:45): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
database (23.05.2016 17:33:01): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:33:02): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:33:02): cannot commit (after 0 tries in 22ms): database or disk is full
logger (23.05.2016 17:33:15): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (23.05.2016 17:33:45): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
database (23.05.2016 17:34:01): cannot commit (after 0 tries in 2ms): database or disk is full
logger (23.05.2016 17:34:15): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (23.05.2016 17:34:45): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
database (23.05.2016 17:35:01): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:35:02): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:35:03): cannot commit (after 0 tries in 2ms): database or disk is full
logger (23.05.2016 17:35:15): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (23.05.2016 17:35:22): parent process received termination signal (15).
logger (23.05.2016 17:35:22): child process received termination signal (15).
logger (23.05.2016 17:35:22): disconnect station 9 (System Data): exit
logger (23.05.2016 17:35:22): data logger stopped.
database (23.05.2016 17:35:22): process terminated normally.
test5m (23.05.2016 17:35:23): USB storage remounted: /dev/sda
database (23.05.2016 17:35:23): process started.
logger (23.05.2016 17:35:24): database connected.
logger (23.05.2016 17:35:24): Historical data loaded (46 records).
logger (23.05.2016 17:35:24): data logger (version 5.0p, build 9911) started.
logger (23.05.2016 17:35:25): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (23.05.2016 17:35:25): connect station 9 (System Data via Plug-in).
logger (23.05.2016 17:35:55): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (23.05.2016 17:36:25): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (23.05.2016 17:36:55): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
database (23.05.2016 17:37:02): cannot commit (after 0 tries in 2ms): database or disk is full
logger (23.05.2016 17:37:25): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (23.05.2016 17:37:55): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
database (23.05.2016 17:38:01): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:38:02): cannot commit (after 0 tries in 2ms): database or disk is full
logger (23.05.2016 17:38:25): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (23.05.2016 17:38:55): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (23.05.2016 17:39:25): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
database (23.05.2016 17:39:29): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:39:30): cannot commit (after 0 tries in 2ms): database or disk is full
logger (23.05.2016 17:39:55): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
database (23.05.2016 17:40:01): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:40:02): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:40:03): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:40:04): cannot commit (after 0 tries in 2ms): database or disk is full
logger (23.05.2016 17:40:24): parent process received termination signal (15).
logger (23.05.2016 17:40:24): child process received termination signal (15).
logger (23.05.2016 17:40:24): disconnect station 9 (System Data): exit
logger (23.05.2016 17:40:24): data logger stopped.
database (23.05.2016 17:40:25): process terminated normally.
test5m (23.05.2016 17:40:26): USB storage remounted: /dev/sda
database (23.05.2016 17:40:26): process started.
logger (23.05.2016 17:40:27): database connected.
logger (23.05.2016 17:40:27): Historical data loaded (46 records).
logger (23.05.2016 17:40:27): data logger (version 5.0p, build 9911) started.
logger (23.05.2016 17:40:28): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (23.05.2016 17:40:28): connect station 9 (System Data via Plug-in).
logger (23.05.2016 17:40:58): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (23.05.2016 17:41:28): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (23.05.2016 17:41:58): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
database (23.05.2016 17:42:02): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:42:02): cannot commit (after 0 tries in 22ms): database or disk is full
database (23.05.2016 17:42:03): cannot commit (after 0 tries in 2ms): database or disk is full
logger (23.05.2016 17:42:28): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (23.05.2016 17:42:58): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
database (23.05.2016 17:43:01): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:43:02): cannot commit (after 0 tries in 2ms): database or disk is full
logger (23.05.2016 17:43:28): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (23.05.2016 17:43:58): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
database (23.05.2016 17:44:01): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:44:02): cannot commit (after 0 tries in 2ms): database or disk is full
logger (23.05.2016 17:44:28): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (23.05.2016 17:44:58): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
database (23.05.2016 17:45:01): cannot commit (after 0 tries in 12ms): database or disk is full
database (23.05.2016 17:45:01): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:45:02): cannot commit (after 0 tries in 37ms): database or disk is full
database (23.05.2016 17:45:02): cannot commit (after 0 tries in 2ms): database or disk is full
logger (23.05.2016 17:45:28): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (23.05.2016 17:45:58): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
database (23.05.2016 17:46:01): cannot commit (after 0 tries in 2ms): database or disk is full
database (23.05.2016 17:46:01): cannot commit (after 0 tries in 3ms): database or disk is full
logger (23.05.2016 17:46:29): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (23.05.2016 17:46:44): parent process received termination signal (15).
logger (23.05.2016 17:46:44): child process received termination signal (15).
logger (23.05.2016 17:46:44): disconnect station 9 (System Data): exit
logger (23.05.2016 17:46:44): data logger stopped.
database (23.05.2016 17:46:45): process terminated normally.
test5m (23.05.2016 17:46:46): USB storage remounted: /dev/sda
database (23.05.2016 17:46:46): process started.
logger (23.05.2016 17:46:47): database connected.
logger (23.05.2016 17:46:47): Historical data loaded (46 records).
logger (23.05.2016 17:46:47): data logger (version 5.0p, build 9911) started.
logger (23.05.2016 17:46:48): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (23.05.2016 17:46:48): connect station 9 (System Data via Plug-in).
Now for the second reboot of the day.
During this time the VP2 's little x is flashing away and al the data is there looking in Cumulus
This reboot when to the black screen of death
Powerd down and back up again
oled (23.05.2016 16:52:37): process started.
database (23.05.2016 17:58:58): process started.
wnetd (23.05.2016 17:58:58): process started.
logger (23.05.2016 17:58:58): database connected.
logger (23.05.2016 17:58:58): Historical data loaded (0 records).
logger (23.05.2016 17:58:58): data logger (version 5.0p, build 9911) started.
logger (23.05.2016 17:59:00): connect station 0 (Meteostick Vantage via USB serial).
logger (23.05.2016 17:59:00): connect station 9 (System Data via Plug-in).
logger (23.05.2016 17:59:01): transmitter 2 registered as Temperature
logger (23.05.2016 17:59:02): transmitter 3 registered as ISS
logger (23.05.2016 17:59:02): Meteostick Version 2.4
logger (23.05.2016 17:59:02): debug off
logger (23.05.2016 17:59:02): verbose off
logger (23.05.2016 17:59:02): output raw (8 bytes)
logger (23.05.2016 17:59:02): output raw (10 bytes)
logger (23.05.2016 17:59:02): filter on
logger (23.05.2016 17:59:02): rx threshold set to -85db
logger (23.05.2016 17:59:02): listening to transmitter 2 3
logger (23.05.2016 17:59:02): bandwidth normal
logger (23.05.2016 17:59:02): chip authentication ok: 14
logger (23.05.2016 17:59:02): frequency band 868MHz (EU)
logger (23.05.2016 17:59:05): parent process received termination signal (15).
logger (23.05.2016 17:59:05): child process received termination signal (15).
logger (23.05.2016 17:59:05): disconnect station 0 (Meteostick Vantage): exit
logger (23.05.2016 17:59:05): disconnect station 9 (System Data): exit
database (23.05.2016 17:59:06): process terminated normally.
test5m (23.05.2016 17:59:07): USB storage remounted: /dev/sda
database (23.05.2016 17:59:07): process started.
logger (23.05.2016 17:59:07): database connected.
logger (23.05.2016 17:59:07): Historical data loaded (0 records).
logger (23.05.2016 17:59:07): data logger (version 5.0p, build 9911) started.
logger (23.05.2016 17:59:08): connect station 0 (Meteostick Vantage via USB serial).
logger (23.05.2016 17:59:08): connect station 9 (System Data via Plug-in).
logger (23.05.2016 17:59:10): transmitter 2 registered as Temperature
logger (23.05.2016 17:59:10): transmitter 3 registered as ISS
logger (23.05.2016 17:59:10): Meteostick Version 2.4
logger (23.05.2016 17:59:10): debug off
logger (23.05.2016 17:59:10): verbose off
logger (23.05.2016 17:59:10): output raw (8 bytes)
logger (23.05.2016 17:59:10): output raw (10 bytes)
logger (23.05.2016 17:59:10): filter on
logger (23.05.2016 17:59:10): rx threshold set to -85db
logger (23.05.2016 17:59:10): listening to transmitter 2 3
logger (23.05.2016 17:59:10): bandwidth normal
logger (23.05.2016 17:59:10): chip authentication ok: 14
logger (23.05.2016 17:59:10): frequency band 868MHz (EU)
logger (23.05.2016 17:59:30): parent process received termination signal (15).
logger (23.05.2016 17:59:30): child process received termination signal (15).
logger (23.05.2016 17:59:30): disconnect station 0 (Meteostick Vantage): exit
logger (23.05.2016 17:59:30): disconnect station 9 (System Data): exit
database (23.05.2016 17:59:30): process terminated normally.
test5m (23.05.2016 17:59:32): USB storage remounted: /dev/sda
database (23.05.2016 17:59:32): process started.
logger (23.05.2016 17:59:32): database connected.
logger (23.05.2016 17:59:32): Historical data loaded (0 records).
logger (23.05.2016 17:59:32): data logger (version 5.0p, build 9911) started.
logger (23.05.2016 17:59:33): connect station 0 (Meteostick Vantage via USB serial).
logger (23.05.2016 17:59:33): connect station 9 (System Data via Plug-in).
logger (23.05.2016 17:59:34): transmitter 2 registered as Temperature
logger (23.05.2016 17:59:34): transmitter 3 registered as ISS
logger (23.05.2016 17:59:34): Meteostick Version 2.4
logger (23.05.2016 17:59:34): debug off
logger (23.05.2016 17:59:34): verbose off
logger (23.05.2016 17:59:35): output raw (8 bytes)
logger (23.05.2016 17:59:35): output raw (10 bytes)
logger (23.05.2016 17:59:35): filter on
logger (23.05.2016 17:59:35): rx threshold set to -85db
logger (23.05.2016 17:59:35): listening to transmitter 2 3
logger (23.05.2016 17:59:35): bandwidth normal
logger (23.05.2016 17:59:35): chip authentication ok: 14
logger (23.05.2016 17:59:35): frequency band 868MHz (EU)
back to normal again!
Posted: Fri May 27, 2016 2:24 pm
I have an idea what is happening. Could you please grant me remote access as explained here:
viewtopic.php?f=57&t=9885
I will need URL and password sent to "info(at)meteobridge.com".
Posted: Fri Jun 10, 2016 11:26 pm
by peterb
The MBPro cam back from repair this week turn round was about a week and it is going again. There are some gaps in the data have a look at Weatherunderground ISCOTLAN367 and you will see the gaps but they look like thay are getting less. I have an issue with my web can see another post explaning. Its picking up a retransmit from my DVP2 anout a meter away on a wired LAN. Lets hope it settles down and I can work out what is going on with the camera. :cry:
Posted: Sun Jun 12, 2016 6:52 pm
by peterb
peterb wrote:The MBPro cam back from repair this week turn round was about a week and it is going again. There are some gaps in the data have a look at Weatherunderground ISCOTLAN367 and you will see the gaps but they look like thay are getting less. I have an issue with my web can see another post explaning. Its picking up a retransmit from my DVP2 anout a meter away on a wired LAN. Lets hope it settles down and I can work out what is going on with the camera. :cry:
Now have 48 hours of unbroken data :P But still no camera :(
