Network issue - 5.0q
Posted: Tue Jun 28, 2016 5:25 pm
by RickNY
Using Meteohub 5.0q on a Sheevaplug... Running into two issues:
1) Setting networking to DHCP causes MH not to set DHCP-assigned DNS server -- it leaves it blank, and then MH does not have access to Internet. If I set IP static and manually enter DNS1 value properly, it works. Not sure if it matters -- but DNS server on my network is same as my DHCP server. All other hosts on the subnet receive proper DNS via DHCP.
2) I notice the emergency IP (192.168.1.77) is attempting NetBios broadcasts even though the MH is configured on an entirely different subnet. Is this expected? My FW is blocking the NB broadcasts from that address -- but I should note that SMB access is working properly on the configured IP.
