Only problems with my MBPro. **solved**
Posted: Sun Jul 10, 2016 1:35 pm
For several months I have only problems with my MBPro with V2.9 and also with V3.0
- When I reboot Wifi AP then it come no further than the landing page. On network tab can't see my SSID anymore.
- Display after a few minutes going on black and stays there after reboot the same story.
- No data is stored on the Internal USB storage. The history date table remains empty.
- On history tab gives an System Message Error: Can't open database: disk I/O error
- After every reboot history data is empty.
Even an factory reset does’t make any improvement. Hope that the admin has a solution otherwise the MBPro will go back for warranty to the supplier.
System messages gives:
oled (10.07.2016 10:25:38): process started.
database (10.07.2016 12:27:00): process started.
wnetd (10.07.2016 12:27:00): process started.
database (10.07.2016 12:27:00): Can't open database: disk I/O error
database (10.07.2016 12:27:00): process stopped.
logger (10.07.2016 12:27:00): can't open database: disk I/O error
database (10.07.2016 12:27:00): cannot prepare init database: out of memory
logger (10.07.2016 12:27:00): Historical data loaded (0 records).
logger (10.07.2016 12:27:00): data logger (version 5.0q, build 10055) started.
logger (10.07.2016 12:27:02): connect station 0 (Vantage via USB serial).
logger (10.07.2016 12:27:02): connect station 9 (System Data via Plug-in).
logger (10.07.2016 12:27:02): wakeup sent.
logger (10.07.2016 12:27:02): internal logger activated.
logger (10.07.2016 12:27:02): syncing.
test5m (10.07.2016 12:27:03): database daemon stalled, will be restarted now.
database (10.07.2016 12:27:03): process started.
database (10.07.2016 12:27:03): Can't open database: disk I/O error
database (10.07.2016 12:27:03): process stopped.
logger (10.07.2016 12:27:12): gettime request sent.
logger (10.07.2016 12:27:12): no Vantage time offset.
logger (10.07.2016 12:27:12): eeprom request sent.
logger (10.07.2016 12:27:12): rain collector size 0.2 mm per tick.
logger (10.07.2016 12:27:12): transmitter 1 active as station type (#0) "ISS".
logger (10.07.2016 12:27:12): transmitter 2 active as station type (#4) "Wind".
logger (10.07.2016 12:27:12): firmware version request sent.
logger (10.07.2016 12:27:12): firmware version 1.90
logger (10.07.2016 12:27:12): no reading of Vantage's internal logger.
test5m (10.07.2016 12:30:17): database daemon stalled, will be restarted now.
database (10.07.2016 12:30:17): process started.
database (10.07.2016 12:30:17): Can't open database: disk I/O error
database (10.07.2016 12:30:17): process stopped.
test5m (10.07.2016 12:35:31): database daemon stalled, will be restarted now.
database (10.07.2016 12:35:31): process started.
database (10.07.2016 12:35:31): Can't open database: disk I/O error
database (10.07.2016 12:35:31): process stopped.
test5m (10.07.2016 12:41:35): database daemon stalled, will be restarted now.
database (10.07.2016 12:41:35): process started.
database (10.07.2016 12:41:35): Can't open database: disk I/O error
database (10.07.2016 12:41:35): process stopped.
test5m (10.07.2016 12:46:13): database daemon stalled, will be restarted now.
database (10.07.2016 12:46:13): process started.
database (10.07.2016 12:46:13): Can't open database: disk I/O error
database (10.07.2016 12:46:13): process stopped.
test5m (10.07.2016 12:50:47): database daemon stalled, will be restarted now.
database (10.07.2016 12:50:47): process started.
database (10.07.2016 12:50:47): Can't open database: disk I/O error
database (10.07.2016 12:50:47): process stopped.
test5m (10.07.2016 12:56:23): database daemon stalled, will be restarted now.
database (10.07.2016 12:56:23): process started.
database (10.07.2016 12:56:23): Can't open database: disk I/O error
database (10.07.2016 12:56:23): process stopped.
logger (10.07.2016 12:57:18): write persist data to "/tmp/mnt/persist/thb0temp" failed: No such file or directory
test5m (10.07.2016 13:00:28): database daemon stalled, will be restarted now.
database (10.07.2016 13:00:28): process started.
database (10.07.2016 13:00:28): Can't open database: disk I/O error
database (10.07.2016 13:00:28): process stopped.
test5m (10.07.2016 13:05:37): database daemon stalled, will be restarted now.
database (10.07.2016 13:05:37): process started.
database (10.07.2016 13:05:37): Can't open database: disk I/O error
database (10.07.2016 13:05:37): process stopped.
test5m (10.07.2016 13:10:24): database daemon stalled, will be restarted now.
database (10.07.2016 13:10:24): process started.
database (10.07.2016 13:10:24): Can't open database: disk I/O error
database (10.07.2016 13:10:24): process stopped.
test5m (10.07.2016 13:15:22): database daemon stalled, will be restarted now.
database (10.07.2016 13:15:22): process started.
database (10.07.2016 13:15:22): Can't open database: disk I/O error
database (10.07.2016 13:15:22): process stopped.
test5m (10.07.2016 13:20:24): database daemon stalled, will be restarted now.
database (10.07.2016 13:20:24): process started.
database (10.07.2016 13:20:24): Can't open database: disk I/O error
database (10.07.2016 13:20:24): process stopped.
Thanks Peter.
Thanks Peter.
