Using MBPro and template Leuven **solved**
Posted: Sat Dec 10, 2016 11:40 am
I would like to send you this message for a support request
I just moved to the MB Pro for a few days
Before this migration, i was using the TL-MR3020 (version from TP-Link) to pilot my second weather station Davis using two templates like Saratoga and Leuven...
i had no bug for the postponement of my datas ...
With the MB Pro, if the Saratoga always works well, cons for the Leuven I have a bug !
I do not change anything in the settings HTTP requests, FTP uploads for the additional "Push Services"
http://leuven-template.eu/dokuwiki28/do ... n:uploadmb
Think that when downloading a file, Meteobridge follows these steps
There is probably an error on the upload / live data of the MB which can not rename mb_tagsMB.txt_ file visible in my uploadMB / folder
I tried this:
by setting the download of the tagsMB.txt to once per minute (instead of the 5 'recommended) in my MB Pro;
i then use my FTP program to rename the old uploadMB / tagsMB.txt file with a different name and waited until a new download;
be finished to probably have a tagsMB.txt created ....
no result ! i always have the file mb_tagsMB.txt_ that is created ...
an idea ?
Thank you in advance for your attention and hoping to have clearly exposed my problem
Best regards
I tried this:
an idea ?
Best regards
