antenna extension cable for Meteobridge PRO
Posted: Mon Feb 27, 2017 9:42 pm
We are planning a Meteobridge PRO installation at a remote outdoor location. There is an existing metal control panel at the site and the MB PRO will be installed inside the metal enclosure. The reception of the Davis wireless signal from the Vantage Pro2 sensors won't be so good inside the metal control panel.
Can we use a short (1 meter or less) antenna extension cable to mount the antenna on the outside of the metal enclosure so it can pick up the Davis wireless signal better? If so, what are the correct connectors that we should specify on the cable?
