No weather network traffic
Posted: Wed May 03, 2017 12:07 pm
by thegraylan
Hi all
i have a Meteobridge 3.2 (Apr 30 2017, build 11169), FW 1.4 running on a TL-WR703N (plus USB hub)
offset WH-1080
it has stopped feeding data to weather underground
https://www.wunderground.com/personal-w ... =ICAPTAIN2
wnetd (03.05.2017 19:53:55): process started.
system (03.05.2017 09:53:55): start of logging process initiated.
logger (03.05.2017 19:53:55): historical data loaded (24 records).
logger (03.05.2017 19:53:55): data logger (version 5.0v, build 11169) started.
logger (03.05.2017 19:53:56): connect station 0 (WH-1080/3080 via USB HID).
logger (03.05.2017 19:53:57): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (03.05.2017 19:53:57): services paused.
logger (03.05.2017 19:54:11): Bad thb0(0) sensor data, "pressure x10" (0) out of range [4000:13000]
logger (03.05.2017 19:55:50): message above repeats 7 times.
<----------- has always done this
logger (03.05.2017 19:55:57): services activated.
under the live data tab
Weather Network Status
Weather Underground: No weather network traffic
Triggered Script: No script invocation
but i am getting data under live Data
Live Data
Sensor Signal Metric Data Imperial Data
Data 4 sec 0.00 0.00
Solar 4 sec 0W/qm 0W/qm
UV 4 sec 0.0uvindex 0.0uvindex
Outdoor 4 sec 2.3°C 86% (dew 0.2°C, heat 2.3°C) 36.1°F 86% (dew 32.4°F, heat 36.1°F)
Rain 4 sec rate 0.0mm/h rate 0.00in/h
Wind 5 min 0.0m/s (avg 0.0m/s) 90° E 0.0mph (avg 0.0mph) 90° E
Network
MAC: 08:57:XX:XX:XX:XX
LAN IP: -- WLAN IP: 192.168.1.7
LAN Mask: -- WLAN Mask: 255.255.255.0
Gateway: 192.168.1.1 TX Traffic: 529.5 KB
DNS: 8.8.8.8 RX Traffic: 4.3 MB
WAN IP: XXX.XXX.XXX.XXX Provider: SkyMesh Pty
i have tried different Versions but didnt look to work
Any help will me great, Thank you
Re: No weather network traffic
Posted: Sat May 06, 2017 5:47 pm
Does this just happen from time to time or are you constantly missing pressure data?
