Screen black and not transmitting
Posted: Wed May 17, 2017 9:00 pm
by rpt1700
Hello everyone -
Yesterday Wunderground notified me that my station wasn't transmitting and it'd been down for about two hours. This was the first time this had happened in quite awhile, so I rebooted and thought nothing of it, and all was well. Just now I noticed that the screen on the front of the Pro was black. I checked Wunderground and sure enough, it had been 20 minutes since the last transmission. Here's the screen:
http://imgur.com/a/O7v4k
I just rebooted about five minutes ago and the screen is back on and we're transmitting again, but I'm not sure what's up, wondering if you could provide some insight.
Here's what's in System > Info before the latest reboot:
Platform: Meteobridge PRO (no USB hub)
RAM: 61500 kB total, 18868 kB free (69% used)
SW Version: Meteobridge 3.3 (May 14 2017, build 11195), FW 1.4
Uptime: 19 hours, 29 minutes Buffer: 0 items (0%)
Power Data: 5.48V 232mA 1.27W (Box Climate: 40.3°C 16%)
And here's what was in System > Messages just before the latest reboot:
oled (16.05.2017 23:22:06): process started.
database (16.05.2017 16:24:00): process started.
wnetd (16.05.2017 16:24:02): process started.
system (16.05.2017 23:24:02): start of logging process initiated.
logger (16.05.2017 16:24:02): databases connected. Update interval 3600 seconds.
logger (16.05.2017 16:24:02): historical data loaded (0 records).
logger (16.05.2017 16:24:02): data logger (version 5.0v, build 11195) started.
logger (16.05.2017 16:24:05): connect station 0 (Meteostick Vantage via USB serial).
logger (16.05.2017 16:24:05): connect station 9 (System Data via Plug-in).
logger (16.05.2017 16:24:08): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (16.05.2017 16:24:08): services paused.
logger (16.05.2017 16:24:09): transmitter 1 registered as ISS
logger (16.05.2017 16:24:09): Meteostick Version 2.4
logger (16.05.2017 16:24:09): debug off
logger (16.05.2017 16:24:09): verbose off
logger (16.05.2017 16:24:09): output raw (8 bytes)
logger (16.05.2017 16:24:09): output raw (10 bytes)
logger (16.05.2017 16:24:09): filter on
logger (16.05.2017 16:24:09): rx threshold set to -85db
logger (16.05.2017 16:24:09): listening to transmitter 1
logger (16.05.2017 16:24:09): bandwidth narrow
logger (16.05.2017 16:24:09): chip authentication ok: 14
logger (16.05.2017 16:24:09): frequency band 915MHz (US)
database (16.05.2017 16:24:30): database sync done (46 tables, 190/1933 writes)
logger (16.05.2017 16:26:03): give up waiting for sensors after 120 secs.
logger (16.05.2017 16:26:03): services activated.
logger (16.05.2017 16:26:45): wind0 data incomplete (missing outdoor temp for windchill)
logger (16.05.2017 16:26:47): message above repeats 1 time.
logger (17.05.2017 11:29:02): unexpected 0 bytes.
logger (17.05.2017 11:29:02): can't set attributes of device /dev/ttyMH to former values: Input/output error
logger (17.05.2017 11:29:02): disconnect station 0 (Meteostick Vantage): response without data
system (17.05.2017 18:30:23): stop of logging process initiated.
logger (17.05.2017 11:30:23): parent process received termination signal (15).
logger (17.05.2017 11:30:23): child process received termination signal (15).
database (17.05.2017 11:30:23): process terminated normally.
test5m (17.05.2017 18:30:24): USB storage remounted: /dev/
system (17.05.2017 18:30:24): start of logging process initiated.
database (17.05.2017 11:30:24): process started.
logger (17.05.2017 11:30:25): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:30:25): historical data loaded (0 records).
logger (17.05.2017 11:30:25): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:30:25): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:30:25): killed process "2457/sh" listening to port 5551.
database (17.05.2017 11:30:42): database sync done (46 tables, 1671/1671 writes)
logger (17.05.2017 11:30:54): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:30:54): historical data loaded (0 records).
logger (17.05.2017 11:30:54): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:30:54): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:30:55): killed process "2460/meteosys" listening to port 5551.
logger (17.05.2017 11:31:24): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:31:24): historical data loaded (0 records).
logger (17.05.2017 11:31:24): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:31:24): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:31:25): killed process "32217/sh" listening to port 5551.
logger (17.05.2017 11:31:54): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:31:54): historical data loaded (0 records).
logger (17.05.2017 11:31:54): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:31:54): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:31:55): killed process "32218/usbreset" listening to port 5551.
logger (17.05.2017 11:32:24): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:32:24): historical data loaded (0 records).
logger (17.05.2017 11:32:24): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:32:24): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:32:25): killed process "32218/usbreset" listening to port 5551.
logger (17.05.2017 11:32:54): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:32:54): historical data loaded (0 records).
logger (17.05.2017 11:32:54): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:32:54): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:32:55): killed process "32218/usbreset" listening to port 5551.
logger (17.05.2017 11:33:24): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:33:24): historical data loaded (0 records).
logger (17.05.2017 11:33:24): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:33:24): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:33:25): killed process "32218/usbreset" listening to port 5551.
logger (17.05.2017 11:33:54): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:33:54): historical data loaded (0 records).
logger (17.05.2017 11:33:54): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:33:54): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:33:55): killed process "32218/usbreset" listening to port 5551.
logger (17.05.2017 11:34:24): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:34:24): historical data loaded (0 records).
logger (17.05.2017 11:34:24): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:34:24): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:34:25): killed process "32218/usbreset" listening to port 5551.
logger (17.05.2017 11:34:54): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:34:54): historical data loaded (0 records).
logger (17.05.2017 11:34:54): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:34:54): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:34:55): killed process "32218/usbreset" listening to port 5551.
logger (17.05.2017 11:35:24): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:35:24): historical data loaded (0 records).
logger (17.05.2017 11:35:24): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:35:24): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:35:25): killed process "32218/usbreset" listening to port 5551.
logger (17.05.2017 11:35:54): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:35:54): historical data loaded (0 records).
logger (17.05.2017 11:35:54): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:35:54): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:35:55): killed process "32218/usbreset" listening to port 5551.
logger (17.05.2017 11:36:24): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:36:24): historical data loaded (0 records).
logger (17.05.2017 11:36:24): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:36:24): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:36:25): killed process "32218/usbreset" listening to port 5551.
logger (17.05.2017 11:36:54): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:36:54): historical data loaded (0 records).
logger (17.05.2017 11:36:54): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:36:54): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:36:55): killed process "32218/usbreset" listening to port 5551.
logger (17.05.2017 11:37:24): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:37:24): historical data loaded (0 records).
logger (17.05.2017 11:37:24): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:37:24): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:37:25): killed process "32218/usbreset" listening to port 5551.
logger (17.05.2017 11:37:54): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:37:54): historical data loaded (0 records).
logger (17.05.2017 11:37:54): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:37:54): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:37:55): killed process "32218/usbreset" listening to port 5551.
logger (17.05.2017 11:38:24): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:38:24): historical data loaded (0 records).
logger (17.05.2017 11:38:24): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:38:24): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:38:25): killed process "32218/usbreset" listening to port 5551.
logger (17.05.2017 11:38:54): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:38:54): historical data loaded (0 records).
logger (17.05.2017 11:38:54): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:38:54): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:38:55): killed process "32218/usbreset" listening to port 5551.
logger (17.05.2017 11:39:24): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:39:24): historical data loaded (0 records).
logger (17.05.2017 11:39:24): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:39:24): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:39:25): killed process "32218/usbreset" listening to port 5551.
logger (17.05.2017 11:39:54): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:39:54): historical data loaded (0 records).
logger (17.05.2017 11:39:54): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:39:54): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:39:55): killed process "32218/usbreset" listening to port 5551.
logger (17.05.2017 11:40:24): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:40:24): historical data loaded (0 records).
logger (17.05.2017 11:40:24): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:40:24): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:40:25): killed process "32218/usbreset" listening to port 5551.
logger (17.05.2017 11:40:54): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:40:54): historical data loaded (0 records).
logger (17.05.2017 11:40:54): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:40:54): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:40:55): killed process "32218/usbreset" listening to port 5551.
logger (17.05.2017 11:41:24): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:41:24): historical data loaded (0 records).
logger (17.05.2017 11:41:24): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:41:24): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:41:25): killed process "32218/usbreset" listening to port 5551.
logger (17.05.2017 11:41:54): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:41:55): historical data loaded (0 records).
logger (17.05.2017 11:41:55): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:41:55): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:41:55): killed process "32218/usbreset" listening to port 5551.
logger (17.05.2017 11:42:24): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:42:25): historical data loaded (0 records).
logger (17.05.2017 11:42:25): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:42:25): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:42:25): killed process "32218/usbreset" listening to port 5551.
logger (17.05.2017 11:42:55): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:42:55): historical data loaded (0 records).
logger (17.05.2017 11:42:55): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:42:55): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:42:55): killed process "32218/usbreset" listening to port 5551.
logger (17.05.2017 11:43:25): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:43:25): historical data loaded (0 records).
logger (17.05.2017 11:43:25): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:43:25): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:43:25): killed process "32218/usbreset" listening to port 5551.
logger (17.05.2017 11:43:55): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:43:55): historical data loaded (0 records).
logger (17.05.2017 11:43:55): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:43:55): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:43:55): killed process "32218/usbreset" listening to port 5551.
logger (17.05.2017 11:44:25): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:44:25): historical data loaded (0 records).
logger (17.05.2017 11:44:25): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:44:25): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:44:25): killed process "32218/usbreset" listening to port 5551.
logger (17.05.2017 11:44:55): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:44:55): historical data loaded (0 records).
logger (17.05.2017 11:44:55): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:44:55): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:44:55): killed process "32218/usbreset" listening to port 5551.
logger (17.05.2017 11:45:25): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:45:25): historical data loaded (0 records).
logger (17.05.2017 11:45:25): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:45:25): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:45:25): killed process "32218/usbreset" listening to port 5551.
logger (17.05.2017 11:45:54): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:45:54): historical data loaded (0 records).
logger (17.05.2017 11:45:55): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:45:55): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:45:55): killed process "32218/usbreset" listening to port 5551.
logger (17.05.2017 11:46:24): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:46:24): historical data loaded (0 records).
logger (17.05.2017 11:46:25): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:46:25): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:46:25): killed process "32218/usbreset" listening to port 5551.
logger (17.05.2017 11:46:54): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:46:55): historical data loaded (0 records).
logger (17.05.2017 11:46:55): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:46:55): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:46:55): killed process "32218/usbreset" listening to port 5551.
logger (17.05.2017 11:47:24): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:47:25): historical data loaded (0 records).
logger (17.05.2017 11:47:25): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:47:25): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:47:25): killed process "32218/usbreset" listening to port 5551.
logger (17.05.2017 11:47:54): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:47:55): historical data loaded (0 records).
logger (17.05.2017 11:47:55): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:47:55): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:47:55): killed process "32218/usbreset" listening to port 5551.
logger (17.05.2017 11:48:25): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:48:25): historical data loaded (0 records).
logger (17.05.2017 11:48:25): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:48:25): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:48:25): killed process "32218/usbreset" listening to port 5551.
logger (17.05.2017 11:48:55): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:48:55): historical data loaded (0 records).
logger (17.05.2017 11:48:55): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:48:55): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:48:55): killed process "32218/usbreset" listening to port 5551.
logger (17.05.2017 11:49:25): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:49:25): historical data loaded (0 records).
logger (17.05.2017 11:49:25): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:49:25): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:49:25): killed process "32218/usbreset" listening to port 5551.
logger (17.05.2017 11:49:55): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:49:55): historical data loaded (0 records).
logger (17.05.2017 11:49:55): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:49:55): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:49:55): killed process "32218/usbreset" listening to port 5551.
logger (17.05.2017 11:50:25): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:50:25): historical data loaded (0 records).
logger (17.05.2017 11:50:25): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:50:25): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:50:25): killed process "32218/usbreset" listening to port 5551.
logger (17.05.2017 11:50:55): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:50:55): historical data loaded (0 records).
logger (17.05.2017 11:50:55): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:50:55): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:50:55): killed process "32218/usbreset" listening to port 5551.
logger (17.05.2017 11:51:25): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:51:25): historical data loaded (0 records).
logger (17.05.2017 11:51:25): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:51:25): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:51:25): killed process "32218/usbreset" listening to port 5551.
logger (17.05.2017 11:51:55): databases connected. Update interval 3600 seconds.
logger (17.05.2017 11:51:55): historical data loaded (0 records).
logger (17.05.2017 11:51:55): data logger (version 5.0v, build 11195) started.
logger (17.05.2017 11:51:55): error while doing bind (port 5551): Address already in use
logger (17.05.2017 11:51:55): killed process "32218/usbreset" listening to port 5551.
Also, here's what's in .../cgi-bin/system.cgi?dmesg
command: dmesg
[ 0.000000] Linux version 3.10.49 (boris@mars) (gcc version 4.8.3 (OpenWrt/Linaro GCC 4.8-2014.04 r44550) ) #685 Thu Dec 17 00:17:35 CET 2015
[ 0.000000] MyLoader: sysp=2ab3abab, boardp=baababa3, parts=f2ba2aaa
[ 0.000000] bootconsole [early0] enabled
[ 0.000000] CPU revision is: 00019374 (MIPS 24Kc)
[ 0.000000] SoC: Atheros AR9330 rev 1
[ 0.000000] Clocks: CPU:400.000MHz, DDR:400.000MHz, AHB:200.000MHz, Ref:40.000MHz
[ 0.000000] Determined physical RAM map:
[ 0.000000] memory: 04000000 @ 00000000 (usable)
[ 0.000000] Initrd not found or empty - disabling initrd
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x00000000-0x03ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x00000000-0x03ffffff]
[ 0.000000] On node 0 totalpages: 16384
[ 0.000000] free_area_init_node: node 0, pgdat 803109b0, node_mem_map 81000000
[ 0.000000] Normal zone: 128 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 16384 pages, LIFO batch:3
[ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
[ 0.000000] Kernel command line: board=CARAMBOLA2 console=ttyATH0,115200 mtdparts=spi0.0:256k(u-boot)ro,64k(u-boot-env)ro,16000k(firmware),64k(art)ro rootfstype=squashfs,jffs2 noinitrd
[ 0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Writing ErrCtl register=00000000
[ 0.000000] Readback ErrCtl register=00000000
[ 0.000000] Memory: 61272k/65536k available (2239k kernel code, 4264k reserved, 603k data, 228k init, 0k highmem)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:51
[ 0.080000] Calibrating delay loop... 265.42 BogoMIPS (lpj=1327104)
[ 0.080000] pid_max: default: 32768 minimum: 301
[ 0.080000] Mount-cache hash table entries: 512
[ 0.090000] NET: Registered protocol family 16
[ 0.100000] MIPS: machine is 8devices Carambola2 board
[ 0.550000] bio: create slab <bio-0> at 0
[ 0.560000] Switching to clocksource MIPS
[ 0.570000] NET: Registered protocol family 2
[ 0.570000] TCP established hash table entries: 512 (order: 0, 4096 bytes)
[ 0.570000] TCP bind hash table entries: 512 (order: -1, 2048 bytes)
[ 0.580000] TCP: Hash tables configured (established 512 bind 512)
[ 0.580000] TCP: reno registered
[ 0.580000] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.590000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.600000] NET: Registered protocol family 1
[ 0.600000] PCI: CLS 0 bytes, default 32
[ 0.620000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.630000] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.640000] msgmni has been set to 119
[ 0.640000] io scheduler noop registered
[ 0.640000] io scheduler deadline registered (default)
[ 0.650000] Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
[ 0.660000] ar933x-uart: ttyATH0 at MMIO 0x18020000 (irq = 11) is a AR933X UART
[ 0.660000] console [ttyATH0] enabled, bootconsole disabled
[ 0.680000] ath79-spi ath79-spi: master is unqueued, this is deprecated
[ 0.680000] m25p80 spi0.0: found w25q128, expected m25p80
[ 0.690000] m25p80 spi0.0: w25q128 (16384 Kbytes)
[ 0.690000] 4 cmdlinepart partitions found on MTD device spi0.0
[ 0.700000] Creating 4 MTD partitions on "spi0.0":
[ 0.700000] 0x000000000000-0x000000040000 : "u-boot"
[ 0.710000] 0x000000040000-0x000000050000 : "u-boot-env"
[ 0.720000] 0x000000050000-0x000000ff0000 : "firmware"
[ 0.740000] 2 uimage-fw partitions found on MTD device firmware
[ 0.740000] 0x000000050000-0x000000160000 : "kernel"
[ 0.750000] 0x000000160000-0x000000ff0000 : "rootfs"
[ 0.750000] mtd: device 4 (rootfs) set to be root filesystem
[ 0.760000] 1 squashfs-split partitions found on MTD device rootfs
[ 0.760000] 0x0000006d0000-0x000000ff0000 : "rootfs_data"
[ 0.770000] 0x000000ff0000-0x000001000000 : "art"
[ 0.790000] libphy: ag71xx_mdio: probed
[ 1.340000] ag71xx-mdio.1: Found an AR7240/AR9330 built-in switch
[ 2.380000] eth0: Atheros AG71xx at 0xba000000, irq 5, mode:GMII
[ 2.930000] ag71xx ag71xx.0: connected to PHY at ag71xx-mdio.1:04 [uid=004dd041, driver=Generic PHY]
[ 2.940000] eth1: Atheros AG71xx at 0xb9000000, irq 4, mode:MII
[ 2.950000] TCP: cubic registered
[ 2.950000] NET: Registered protocol family 17
[ 2.960000] 8021q: 802.1Q VLAN Support v1.8
[ 2.970000] VFS: Mounted root (squashfs filesystem) readonly on device 31:4.
[ 2.970000] Freeing unused kernel memory: 228K (80327000 - 80360000)
[ 6.790000] usbcore: registered new interface driver usbfs
[ 6.800000] usbcore: registered new interface driver hub
[ 6.800000] usbcore: registered new device driver usb
[ 6.860000] SCSI subsystem initialized
[ 6.870000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 6.870000] ehci-platform: EHCI generic platform driver
[ 6.880000] ehci-platform ehci-platform: EHCI Host Controller
[ 6.880000] ehci-platform ehci-platform: new USB bus registered, assigned bus number 1
[ 6.890000] ehci-platform ehci-platform: irq 3, io mem 0x1b000000
[ 6.920000] ehci-platform ehci-platform: USB 2.0 started, EHCI 1.00
[ 6.920000] hub 1-0:1.0: USB hub found
[ 6.920000] hub 1-0:1.0: 1 port detected
[ 6.930000] usbcore: registered new interface driver usb-storage
[ 7.360000] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 7.540000] hub 1-1:1.0: USB hub found
[ 7.550000] hub 1-1:1.0: 4 ports detected
[ 7.830000] usb 1-1.3: new full-speed USB device number 3 using ehci-platform
[ 8.030000] usb 1-1.4: new high-speed USB device number 4 using ehci-platform
[ 8.140000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[ 8.150000] scsi0 : usb-storage 1-1.4:1.0
[ 9.450000] scsi 0:0:0:0: Direct-Access Intenso Premium Line 1100 PQ: 0 ANSI: 6
[ 9.460000] sd 0:0:0:0: [sda] 15720448 512-byte logical blocks: (8.04 GB/7.49 GiB)
[ 9.470000] sd 0:0:0:0: [sda] Write Protect is off
[ 9.470000] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[ 9.470000] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 9.490000] sda: unknown partition table
[ 9.500000] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 12.480000] jffs2: notice: (341) jffs2_build_xattr_subsystem: complete building xattr subsystem, 1 of xdatum (1 unchecked, 0 orphan) and 20 of xref (0 dead, 5 orphan) found.
[ 12.490000] block: attempting to load /tmp/jffs_cfg/upper/etc/config/fstab
[ 12.500000] block: unable to load configuration (fstab: Entry not found)
[ 12.500000] block: attempting to load /tmp/jffs_cfg/etc/config/fstab
[ 12.520000] block: extroot: not configured
[ 12.590000] jffs2: notice: (338) jffs2_build_xattr_subsystem: complete building xattr subsystem, 1 of xdatum (1 unchecked, 0 orphan) and 20 of xref (0 dead, 5 orphan) found.
[ 12.920000] block: attempting to load /tmp/jffs_cfg/upper/etc/config/fstab
[ 12.920000] block: unable to load configuration (fstab: Entry not found)
[ 12.930000] block: attempting to load /tmp/jffs_cfg/etc/config/fstab
[ 12.940000] block: extroot: not configured
[ 18.120000] NET: Registered protocol family 10
[ 18.150000] nf_conntrack version 0.5.0 (960 buckets, 3840 max)
[ 18.170000] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 18.200000] hidraw: raw HID events driver (C) Jiri Kosina
[ 18.210000] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 18.220000] Loading modules backported from Linux version master-2014-05-22-0-gf2032ea
[ 18.220000] Backport generated by backports.git backports-20140320-37-g5c33da0
[ 18.240000] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 18.270000] usbcore: registered new interface driver usbhid
[ 18.280000] usbhid: USB HID core driver
[ 18.290000] usbcore: registered new interface driver usbserial
[ 18.300000] usbcore: registered new interface driver usbserial_generic
[ 18.300000] usbserial: USB Serial support registered for generic
[ 18.340000] xt_time: kernel timezone is -0000
[ 18.340000] usbcore: registered new interface driver cdc_ether
[ 18.380000] usbcore: registered new interface driver ch341
[ 18.380000] usbserial: USB Serial support registered for ch341-uart
[ 18.390000] cfg80211: Calling CRDA to update world regulatory domain
[ 18.400000] usbcore: registered new interface driver cp210x
[ 18.400000] usbserial: USB Serial support registered for cp210x
[ 18.420000] cfg80211: World regulatory domain updated:
[ 18.420000] cfg80211: DFS Master region: unset
[ 18.420000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 18.430000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 18.440000] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 18.450000] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 18.460000] cfg80211: (5170000 KHz - 5250000 KHz @ 160000 KHz), (N/A, 2000 mBm), (N/A)
[ 18.470000] cfg80211: (5250000 KHz - 5330000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 18.470000] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 18.480000] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 18.490000] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 18.500000] usbcore: registered new interface driver ftdi_sio
[ 18.520000] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 18.520000] ftdi_sio 1-1.3:1.0: FTDI USB Serial Device converter detected
[ 18.540000] usb 1-1.3: Detected FT232RL
[ 18.540000] usb 1-1.3: Number of endpoints 2
[ 18.540000] usb 1-1.3: Endpoint 1 MaxPacketSize 16384
[ 18.550000] usb 1-1.3: Endpoint 2 MaxPacketSize 16384
[ 18.550000] usb 1-1.3: Setting MaxPacketSize 64
[ 18.590000] usb 1-1.3: FTDI USB Serial Device converter now attached to ttyUSB0
[ 18.650000] usbcore: registered new interface driver pl2303
[ 18.670000] usbserial: USB Serial support registered for pl2303
[ 18.670000] PPP generic driver version 2.4.2
[ 18.690000] NET: Registered protocol family 24
[ 18.740000] usbcore: registered new interface driver option
[ 18.760000] usbserial: USB Serial support registered for GSM modem (1-port)
[ 18.800000] ath: EEPROM regdomain: 0x0
[ 18.800000] ath: EEPROM indicates default country code should be used
[ 18.800000] ath: doing EEPROM country->regdmn map search
[ 18.800000] ath: country maps to regdmn code: 0x3a
[ 18.800000] ath: Country alpha2 being used: US
[ 18.800000] ath: Regpair used: 0x3a
[ 18.820000] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 18.820000] cfg80211: Calling CRDA for country: US
[ 18.830000] cfg80211: Regulatory domain changed to country: US
[ 18.830000] cfg80211: DFS Master region: FCC
[ 18.840000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 18.850000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm), (N/A)
[ 18.850000] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 1700 mBm), (N/A)
[ 18.860000] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm), (0 s)
[ 18.870000] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm), (N/A)
[ 18.880000] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
[ 18.890000] ieee80211 phy0: Atheros AR9330 Rev:1 mem=0xb8100000, irq=2
[ 19.010000] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
[ 19.010000] ftdi_sio 1-1.3:1.0: device disconnected
[ 19.050000] ftdi_sio 1-1.3:1.0: FTDI USB Serial Device converter detected
[ 19.050000] usb 1-1.3: Detected FT232RL
[ 19.060000] usb 1-1.3: Number of endpoints 2
[ 19.060000] usb 1-1.3: Endpoint 1 MaxPacketSize 16384
[ 19.060000] usb 1-1.3: Endpoint 2 MaxPacketSize 16384
[ 19.070000] usb 1-1.3: Setting MaxPacketSize 64
[ 19.080000] usb 1-1.3: FTDI USB Serial Device converter now attached to ttyUSB0
[ 21.120000] i2c /dev entries driver
[ 21.130000] Custom GPIO-based I2C driver version 0.1.1
[ 21.150000] i2c-gpio i2c-gpio.0: using pins 20 (SDA) and 21 (SCL)
[ 34.150000] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 34.150000] device eth0 entered promiscuous mode
[ 34.160000] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
[ 36.340000] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 39.910000] wlan0: authenticate with a6:04:60:1b:07:2c
[ 39.920000] wlan0: send auth to a6:04:60:1b:07:2c (try 1/3)
[ 39.940000] wlan0: authenticated
[ 39.960000] wlan0: associate with a6:04:60:1b:07:2c (try 1/3)
[ 40.000000] wlan0: RX AssocResp from a6:04:60:1b:07:2c (capab=0x1431 status=0 aid=1)
[ 40.010000] wlan0: associated
[ 40.010000] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 51.110000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[ 51.120000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[ 52.820000] EXT4-fs (sda): recovery complete
[ 52.830000] EXT4-fs (sda): mounted filesystem with ordered data mode. Opts: (null)
[ 53.670000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[ 53.680000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[ 53.700000] EXT4-fs (sda): mounted filesystem with ordered data mode. Opts: (null)
[ 76.270000] EXT4-fs (sda): re-mounted. Opts: data=ordered,commit=60,max_batch_time=1000000,min_batch_time=1000000,errors=remount-ro
Re: Screen black and not transmitting
Posted: Wed May 17, 2017 11:53 pm
by Mattk
There have been recent changes to the way the front display works, check the version release notes from around April 22 but not sure if this would be causing your transmission problems?
http://www.meteobridge.com/wiki/index.php/Forum
Posted: Thu May 18, 2017 6:29 pm
by rpt1700
Thanks for the heads up on that. Mine is set to:
template:BIG-scroll-IMP.dsp
After yesterday's reboot I haven't seen the screen go black again, but it's only been just about a day now. No connection drops either thus far.
