VP2 Sensors
Posted: Tue Jun 24, 2008 10:54 pm
by scotebl
Greetigs,
I just added a second temp. station to my VP2. Is there a way to add that second station to meteohub?
Thanks, Scott
Re:VP2 Sensors
Posted: Tue Jun 24, 2008 11:46 pm
Doesn't that appear in the Sensors page after you stop data logging and restart data logging again?
could you please post what appears in the "meteohub log" when doing so.
Re:VP2 Sensors
Posted: Wed Jun 25, 2008 3:16 am
by scotebl
Thanks for your response!
I tried what you said, but it doesn't appear to have worked. Here is the log.
wmr928eval (24.06.2008 15:48:00): no sensor found to match export name th1
wmr928eval (24.06.2008 15:58:00): no sensor found to match export name th1
wmr928eval (24.06.2008 16:08:01): no sensor found to match export name th1
wmr928eval (24.06.2008 16:18:00): no sensor found to match export name th1
wmr928eval (24.06.2008 16:28:00): no sensor found to match export name th1
wmr928eval (24.06.2008 16:38:01): no sensor found to match export name th1
wmr928eval (24.06.2008 16:48:01): no sensor found to match export name th1
wmr928eval (24.06.2008 16:58:00): no sensor found to match export name th1
wmr928eval (24.06.2008 17:08:00): no sensor found to match export name th1
wmr928eval (24.06.2008 17:18:00): no sensor found to match export name th1
wmr928eval (24.06.2008 17:28:00): no sensor found to match export name th1
wmr928eval (24.06.2008 17:38:00): no sensor found to match export name th1
wmr928eval (24.06.2008 17:48:00): no sensor found to match export name th1
wmr928eval (24.06.2008 17:58:00): no sensor found to match export name th1
logger (24.06.2008 18:02:34): stopped.
logger (24.06.2008 18:02:55): started Vantage (5).
logger (24.06.2008 18:02:56): USB chip set: Vendor ID 10c4:ea60
logger (24.06.2008 18:02:57): rain collector size 0.01 inch per tick
logger (24.06.2008 18:02:57): transmitter 1 active as station type "ISS".
logger (24.06.2008 18:02:57): transmitter 2 active as station type "Temperature Only".
logger (24.06.2008 18:02:57): transmitter 3 active as station type "unknown".
logger (24.06.2008 18:02:57): transmitter 4 active as station type "unknown".
logger (24.06.2008 18:02:57): transmitter 5 active as station type "unknown".
logger (24.06.2008 18:02:57): transmitter 6 active as station type "unknown".
logger (24.06.2008 18:02:57): transmitter 7 active as station type "unknown".
logger (24.06.2008 18:02:57): transmitter 8 active as station type "unknown".
wmr928eval (24.06.2008 18:08:00): no sensor found to match export name th1
wmr928eval (24.06.2008 18:15:01): sensor rain0 specified more than one time as paramter.
wmr928eval (24.06.2008 18:15:02): sensor rain0 specified more than one time as paramter.
Thanks for your help.
Scott
Re:VP2 Sensors
Posted: Wed Jun 25, 2008 4:13 pm
This part of the log looks strange to me:
and this one I also don't understand:
Is there a chance for me to login to your Meteohub system? I would need ports 7777 and 22 open.
Re:VP2 Sensors
Posted: Wed Jun 25, 2008 4:31 pm
I have checked in the source. There is code to handle additional Temp/Hum stations but not for pure Temp stations. I can add this, but need remote access to your Meteohub to test the code. So access to your Meteohub is vital to solve the issue. Please send details to info(at)meteohub.de
Re:VP2 Sensors
Posted: Thu Jun 26, 2008 12:12 am
by scotebl
Sounds good to me! Let me open those ports and I will send you the info.
Thanks Scott
Re:VP2 Sensors
Posted: Fri Jun 27, 2008 8:23 pm
New code has been successfully tested. Will be part of update 2.4c.
Re:VP2 Sensors
Posted: Mon Jun 30, 2008 10:23 pm
by scotebl
Seems to be working fine. Thanks for your help on this! I'm new to meteohub. What would be he proper way to get this sensors info onto the web. I havemy own domain that I could upload to.
Thanks again, Scott
Re: VP2 Sensors
Posted: Tue Feb 17, 2015 1:14 pm
by RazaAli
For what it's worth - a while ago I was having all kinds or problems with the Davis Vantage Pro 2 USB interface - it was completely unreliable and finally got Davis to change out the USB version back to the serial version.... It's work great since then using other software... I just moved over to the Meteohub and had to buy the Serial to USB adapter - it is working well so far and I haven't had any problems except once with losing a sync between the too..... My guess is that the problem may be with the Davis rather than the Meteohub...
