Using Davis Repeaters with Meteobridge Red?
Posted: Tue Dec 19, 2017 6:00 pm
by azchrisf
Can the Davis repeaters be used with the Meteobridge Red cap units?
Re: Using Davis Repeaters with Meteobridge Red?
Posted: Fri Dec 22, 2017 3:05 pm
by DouglasW
Yes I have the Davis 7627 solar powered repeater connected between a Vantage Vue ISS and the Meteobridge Pro Red. (The distance between the ISS and the MBP Red is 400m) Under the "station tab" I just have the Vantage Vue ISS chosen with its ID. The MBP Red does not need a special setting for the repeater (unlike the Davis console which needs to be set to either receive direct from the ISS or the via repeater).
Douglas
Posted: Sat Dec 23, 2017 6:25 pm
by azchrisf
Im using the Internal RF receiver, and even with the repeaters setup I don't see a change in signal strength.
Posted: Sat Dec 23, 2017 10:13 pm
by Mattk
Do you have a Console or Envoy in the system? if so you could re-transmit from either which could increase the signal to the MBPro
