TP-Link TL-WR902AC now supported
Re: TP-Link TL-WR902AC now supported
Post by admin » Mon Feb 05, 2018 12:07 pm
I checked the bridging feature that allows to have a device connected to the LAN port of the Meteobridge to also connect to the WLAN the Meteobridge is in. This Meteobridge feature does not work on the WR902AC port so far. Therefore, thanks for spotting this bug.
The just released update should fix it. Please reboot the Meteobridge and give it a second try.
Andyk1
Post by Andyk1 » Thu Feb 15, 2018 11:25 am
I put my TL-MR3020 to bed so to speak for the time being as I registered the TL-WR902AC on your site.
I have been getting an error in my Weather Network and live data area's the past few updates ago.
Weather Cloud: 2018-02-15 03:10:33 Error: http://api.weathercloud.net/set?wid=b27 ... rainrate=0: 2018-02-15 03:10:34
ERROR 500: Internal Server Error. (no more tries)
x's added for security.
I contacted Weather Cloud and there reply was that it was on my end. DNS server misconfigured or error in data sent.
I have a static IP sent for the 902AC with DNS of 8.8.8.8 and not sure what else to try. This is the only one of all the other feeds (7) I have set that does this. CWOP, APRS, WU, PWS etc.
I looked up error code 500 and it says a PHP error.
any guesses.
I almost forgot to mention. When I look at data sent to Weather Cloud it looks fine with no bad data being sent.
Post by admin » Thu Feb 15, 2018 8:10 pm
When Meteoebridge feeds all the other networks fine and Weather Cloud is reporting "Error 500: Internal Server Error" then it is rather obvious that the problem is on their side :-) Funny, that they try to point elsewhere, given that clear evidence ;-)
Even when data transmitted from Meteobridge is not as Weather Cloud expects, then they have to respond in a way explaining what looks wrong to them instead of crashing their PHP script.
When you give me remote access I can try to further analyze, where this network fails exactly.
BTW: I don't think this has anything to do with the WR902AC port.
Andyk1
Post by Andyk1 » Fri Feb 16, 2018 2:04 am
Yes I think your right. Not on meteobridge side. I checked and rechecked everything over and over and everything is correct on my end. You are more than welcome access to my system anytime.
Sent Private msg with the details.
Andyk1
Post by Andyk1 » Thu May 24, 2018 12:34 pm
Can anyone tell me what this means? See screen shot. My time to send to wow is at 10 min intervals. I have changed it as far as 1 hour with same results?
https://andykere-hotmail.tinytake.com/s ... 83ODg3MzI3
Andy
Post by Mattk » Thu May 24, 2018 1:11 pm
That generally means you have been flicking back and forth between tabs in the one open session in which WOW tests itself but based on a 10 minute interval is being detected as too many re-tries. This isn't a bug but what the system does and the best way to make sure all is well is simply monitor the WOW site itself to ensure the 10 minute updates are pushing through.
There shouldn't be any problem?
Andyk1
Post by Andyk1 » Thu May 24, 2018 5:33 pm
Thanks for the reply!!!
I actually left it run a few hours before checking. Did a reboot as my tl-903ac hasn't been rebooted in a long while. After checking is when I got the error. Leaving it run the past few hours it hasn't repeated. It seems to have skipped the sends between changing it to 10 min and then back to one hour and then back to 10 min again. I settled on 10 min sends... left it and seems to have fixed itself skipping 2 1/2 - 3 hours.
Thanks for all you do.
Regards.
Andy
P.S. Any progress getting the internet and activity leds working yet. Hard to let it is working with just the power reset leds steady on?
Andyk1
Post by Andyk1 » Thu May 24, 2018 5:39 pm
Sorry, I have one other question.
Maybe you could point me to the correct section but I have searched with no luck.
I would like to use a usb stick to not keep receiving updates as the version and build I have now work perfectly fine. I tried with just a backup on a usb stick but that does not work. I also wonder if the 902ac with extra memory can pass some of the sent data to the usb stick as a backup in MySQL or csv or even txt format. If this has been answered I am sorry but missed it and forgot about it for awhile.
Andy
Post by admin » Thu May 24, 2018 7:27 pm
Only Meteobridge PRO can store weather data locally.
Andyk1
Post by Andyk1 » Sat Jun 02, 2018 7:12 pm
Hello!!!
I seemed to have developed a new problem recently with the May 30 2018 update.
Platform: TL-WR902AC (no USB hub)
RAM: 60056 kB total, 21884 kB free (63% used)
SW Version: Meteobridge 3.6 (May 30 2018, build 542), FW 1.1
Uptime: 9 hours, 47 minutes Buffer: 0 items (0%)
I am getting an error number 429 on WoW only:
UK Met Office WOW / WOW-NL: 2018-06-02 11:58:35 ERROR 429: Too frequent observations.. (10 more tries)
The following is a screen shot:
https://andykere-hotmail.tinytake.com/s ... 83OTU5NjMw
Not sure what to make of it. Any help would be appreciated.
Andy
Post by Mattk » Sat Jun 02, 2018 11:54 pm
See the following link and explanation.
https://forum.meteohub.de/viewtopic.php ... ing#p21069
Andyk1
Post by Andyk1 » Tue Jul 17, 2018 7:06 pm
It appears my Meteobridge went down sometime the 12th. July 12 2018 at around 14:00, 2:00PM My system rebooted due to power failure and upgraded to:
https://andykere-hotmail.tinytake.com/s ... 84MzA5MzA0
But I do not see that upgrade in the wiki as it states the last update is Verstion 3.7 July 8,2018. Everything seems to work but my cam uploads is stuck on a picture from the July 12th. The time, date, temp and all peramiters seem to update normally but the picture is frozen and not changing. I made no changes in a very long time to my system... months and for some reason it started on the 12th.
My site is at https://www.nicomaparkwx.com and cam updates are on the left side. To view the cam please select more and the date... 12th to see the glitch around 2-4pm. My cron jobs report no errors and updating nornally every 5 min.
Andy
Andyk1
Post by Andyk1 » Sat Jul 28, 2018 5:16 am
Problem has been solved with next MB update "released July 26, 2018". Cam is now updating fine.
Andy
bpweather
Post by bpweather » Sat Aug 11, 2018 9:33 pm
I purchased a wr902ac from amazon 2 weeks ago and found that it is now version 3 not version 1.1
I tried but as I expected, the firmware was rejected. Is there any way to convert this device to work with meteobridge?
Andyk1
Post by Andyk1 » Sun Aug 12, 2018 6:46 am
Have you tried the TFTP method? I suspect Boris need to chime in on this. I am curious myself and was thinking of maybe getting a 3020 ver3 as a backup just in case. Seems the 3020v3 has the same ram and rom support as an AC902, it's basically the same I think but I am only guessing.
If you do get it going please let me know.
Andy
