Meteobridge Pro Red - Soil Station Data Differences with Weatherlink and Cumulus **solved**
Posted: Sun Feb 11, 2018 9:35 pm
by simonjf
I've just recently setup a Meteobridge Pro (Red) with my Davis Vantage Pro 2 weather station. I'm loving the graphing features and the additional tags and selectors. Everytings seems to be working fine except the data for the soil station which appears to be getting separate figures for the temperature and mositure:
As an example heres the current data from the Meteobridge Pro.
Which gives the following:
Soil Temp1 3.0°C
Soil Temp2 3.0°C
Soil Temp3 3.8°C
Soil Temp4 4.2°C
Soil Moisture1 2cb
Soil Moisture2 1cb
Soil Moisture3 0cb
Soil Moisture4 0cb
Here's the Weatherlink Data.
Weather Link.PNG (6.21 KiB) Viewed 2680 times
And heres the same data in CumulusMX
Both Weatherlink and CumulusMX give the sensor data as follows:
Soil Temp1 2.8°C
Soil Temp2 2.8°C
Soil Temp3 3.9°C
Soil Temp4 3.9°C
Soil Moisture1 1cb
Soil Moisture2 1cb
Soil Moisture3 0cb
Soil Moisture4 1cb
As you can see the Weatherlink Data matches the Cumulus Data which also appears to match the Vantage Pro Console (Temperatures are reported as whole numbers in the console).
Have I missed a setting somewhere to get the Soil Station correctly setup?
How often is the soil data updated in Meteobridge looking at the dates and times for the high and lows for the soil data they're all time stamped at 2 minutes past the hour which would make me think they only update once per hour. Here's a link to my webpage showing the highs and lows https://westerhopewx.co.uk/wxsoil.php.
I've set it up so that only todays Highs and Lows displays the time stamp.
Any thoughts or assitance would be much appreciated and thanks for the work to date on the Meteobridge Pro.
Regards,
Simon
Re: Meteobridge Pro Red - Soil Station Data Differences with Weatherlink and Cumulus
Posted: Mon Feb 12, 2018 9:54 pm
by simonjf
Ignore this bit
It's my bad PHP programming using 'm' instead of 'i' for minutes so the 02 was the month.:roll:
Apologies for any confusion caused.
Regards,
Simon
Posted: Tue Feb 13, 2018 12:35 am
Is MB PRO reading RF data from the sensors while Weatherlink and Cumulus are using the Davis logger?
If so, minor differences are to be expected as the sensors are not sending this data as digital values but
as raw data that needs to be approximated to proper temps. We tried to convert as close to the Davis
interpretation as we can, but it is of course not 100% identical.
Regards,
Boris
Posted: Tue Feb 13, 2018 12:47 am
by simonjf
Hi Boris,
Thanks for the reply and looking into this.
Yes that's correct.
Okay thanks, I understand.
Regards,
Simon
