RF Data Reception light not showing and no data being received
Posted: Sun Apr 08, 2018 2:29 pm
by peterb
My MBPro has worked perfectly for a year or more, however, today the RF Data Reception light is not showing and no data being received. I've re booted and done a power on and off but its still not receiving. I can log into to and it is saying this in the messages on the system page:
led (08.04.2018 11:07:59): process started.
test5m (08.04.2018 12:11:08): weathernet daemon stalled, will be restarted now.
wnetd (08.04.2018 12:11:08): process started.
test5m (08.04.2018 12:11:08): logger stalled, will be restarted now.
system (08.04.2018 12:11:09): stop of logging process initiated.
Any suggestions? Tha data in all the other pages is the same nothing has changed and it is still sending the camera image to WU but no data. Internla RF data ticked Vantade Pro 2, all green ticks, RF Sens -80dbb via console annd set on EU (im in the UK), MB 3.6 5th April 2018.
Pete
Re: RF Data Reception light not showing and no data being received
Posted: Sun Apr 08, 2018 4:55 pm
can you please give me remote access? From your description I don't have an idea what goes on.
Posted: Sun Apr 08, 2018 5:08 pm
by peterb
Hi
Ive sent you a pm.Correction I can now nolonger log on to it either having experimented with pugging it by usb to the VP2 correcterd the settings for usb and save and reboot. Poor thing just says Bad Gateway.
Pete
Posted: Sun Apr 08, 2018 5:15 pm
"Bad Gateway" shows up, when you try to connect to it with your browser?
Can you check the IP on the MB PRO display? Did you try a power cycle?
I need to have it connected to the Internet and the remote login feature
enabled... otherwise I cannot login.
Posted: Sun Apr 08, 2018 5:22 pm
by peterb
Yes the ip address is corect I've just tried again with the same result.... Bad Gateway. Just the red System Oerational light is on nothing else flash. The sreen is static at the smartembedded and ip address screen.
Posted: Sun Apr 08, 2018 5:27 pm
by peterb
looking at my router it can see it with the same ip address as on the front but none of the 3 browsers on my pc will let me in the all say bad gateway
Posted: Sun Apr 08, 2018 5:33 pm
by peterb
and just power cycled (ie puller the plug out) and re started, still saying bad gateway when I try to access it.
Posted: Sun Apr 08, 2018 6:10 pm
The second led from the TOP is showing steady on, no blinking?
Does the display show the license number? Having that I can check if it connects to my server.
Posted: Sun Apr 08, 2018 6:13 pm
can you login with a ssh client to the IP?
Posted: Sun Apr 08, 2018 6:33 pm
by peterb
i have pm'ed the licence number to you.
