UK Met Office WOW / WOW-NL **solved**
MeteoOudkarspel
Post by MeteoOudkarspel » Fri Sep 14, 2018 11:01 am
UK Met Office WOW / WOW-NL can not be set to 5 minutes if it is set to 5 mints and I click on save then state tie is just 10 minutes.
I thought I would let you pass.
Last edited by MeteoOudkarspel on Sat Sep 15, 2018 10:22 am, edited 1 time in total.
Sincerely,
http://www.meteooudkarspel-lt.pd0rok.nl
Re: UK Met Office WOW / WOW-NL
Post by Mattk » Fri Sep 14, 2018 11:54 am
What software version are you running which allows 5 minute uploads? WOW basically follows standard Met office intervals of 10 minutes, MBPro options are None, 10, 15, 30 minutes or 1 hour
MeteoOudkarspel
Post by MeteoOudkarspel » Fri Sep 14, 2018 1:12 pm
SW-versie: Meteobridge 3.7 (Sep 13 2018, build 12345), FW 1.4
MBPro
Sincerely,
Post by Mattk » Fri Sep 14, 2018 10:56 pm
Ok can see that listed in the most recent release, I will try that and see what happens.
Post by Mattk » Sat Sep 15, 2018 12:59 am
Doesn't appear to be any issues with 5 minute uploads to WoW, MBPro is doing 5 minute uploads and WoW dashboard is reflecting a 5 minute upload. Will check the Table tab later for 5 minute archives.
Post by admin » Sat Sep 15, 2018 6:46 am
Just fixed that bug. 5 minutes should now stick.
Post by Mattk » Sat Sep 15, 2018 7:46 am
Ok can see what the issue was, but wasn't affecting the 5 minute uploads, just showing as 10 minutes.
MeteoOudkarspel
Post by MeteoOudkarspel » Sat Sep 15, 2018 10:00 am
Many thanks Boris.
Sincerely,
