E-mail event does not work with version 3.8 **solved**
webcam
Post by webcam » Thu Nov 08, 2018 12:59 pm
have there so strange entries in the log file.
And somehow the email does not work anymore.
logger (08.11.2018 11:58:07): error while doing bind (port 5551): Address already in use
logger (08.11.2018 11:58:07): killed process "4314/meteosys" listening to port 5551.
webcam
Post by webcam » Thu Nov 08, 2018 4:22 pm
So apparently the emails do not go out.
Did not change anything. Must have happened last week.
Bildschirmfoto 2018-11-08 um 11.46.30.png (89.63 KiB) Viewed 563 times
webcam
Post by webcam » Fri Nov 09, 2018 1:57 pm
Why is this file not being sent to me via email?
--ANFANG WETTERDATEN--
d.suter@bluewin.ch
http://www.wetterbrienz.ch
Brienz BE (NN 566m)
CH
[DD]-[MM]-[YYYY] [hh]:[mm]
Temperatur: [th0temp-act.1:--] °C
Taupunkt: [th0dew-act.1:--] °C
Luftfeuchte: [th0hum-act.0:--] %
Luftdruck: [thb0seapress-act.1:--] hpa
Windaktuel: [wind0avgwind-act=kmh.1:--] km/h
Windboen: [wind0wind-dmax=kmh.1:--] km/h
Regen Rate: [rain0rate-act.1:--] mm
Regen: [rain0total-sumday.1:--] mm/am Tag
--ENDE WETTERDATEN--
Re: Error messages
Post by Mattk » Fri Nov 09, 2018 10:15 pm
Is your email setup correctly on the bottom of the services page and when you click the <Test Mail> button does it work?
webcam
Post by webcam » Sat Nov 10, 2018 7:59 am
Hello Mattk,
yes that's all right and works well.
For example, the own template borgerveji.mail works too. Unfortunately, my own meteo.mail not. With the content as above.
(Attention, this is a text with the Google English translator)
webcam
Re: Error messages
Post by webcam » Sat Nov 10, 2018 8:48 am
have now switched to version 3.6 at Meteobridge. And look, here it works.
That means something has changed since version 3.6
Re: Error messages
Post by admin » Sat Nov 10, 2018 12:25 pm
Does email sending in general not work for your specific email credentials on 3.8 or is just sending of this particular email not doing as expected?
I doubt that 3.8 can do less in regard to email than 3.6. But you never know...
webcam
Post by webcam » Sat Nov 10, 2018 12:52 pm
I have now created a test event with my e-mail. Can test it that way?
First with version 3.6. Works wonderfully.
Then update to 3.8. And it does not work here.
Bildschirmfoto 2018-11-10 um 11.46.28.png (46.41 KiB) Viewed 506 times
webcam
Post by webcam » Sat Nov 10, 2018 1:22 pm
Have something forgotten. At 3.7 it works too.
Re: E-mail event does not work with version 3.8
Post by admin » Sat Nov 10, 2018 1:27 pm
can you please send me your email template file? info(at)meteobridge.com
webcam
Post by webcam » Sat Nov 10, 2018 1:44 pm
Ok e-mail sent.
Merci for the help
webcam
Post by webcam » Sun Nov 11, 2018 9:54 am
Ok, with the newest version it works again.
Merci for the help.
