HomeWeatherStation Dashboard password? **solved**
Posted: Sat Dec 15, 2018 9:14 pm
by Barry
Good Morning!
I have successfully installed my new NANO+SD (Meteobridge 3.8 (Dec 9 2018, build 1682), FW 1.3 ).
Everything seems to be working.
When I go to the "settings" selection in the HomeWeatherStation Dashboard, I am being asked for a "Password".
Where do I find my password, or where is the option to set it up?
Also, how would I be able to see my HomeWeatherStation Dashboard outside my home network?
Thank you in advance.
Re: HomeWeatherStation Dashboard password?
Posted: Sat Dec 15, 2018 10:09 pm
by Mattk
Initially default Password is blank, simply clink Login to get into settings then you will be able to set your own password.
Local Display and remote Display button options are on the Local Dashboard window under Weather Nets
Posted: Sat Dec 15, 2018 10:18 pm
by Barry
nope. doesn't work for me. this is all that i get:
Posted: Sat Dec 15, 2018 11:19 pm
by Mattk
So if you click LOGIN on that screen nothing happens?
Posted: Sat Dec 15, 2018 11:44 pm
by Barry
correct. nothing happens. i can see the black weather page. When I go to the upper left corner and select ADMIN -> Settings, I get the previous aforementioned screen shot, asking for may password.
Posted: Sun Dec 16, 2018 12:01 am
by Barry
<SOLVED> it was a browser issue with ab pop-up and/or ad-blocker :oops:
thanks for your help
