MB RF from ISS reception problems
Posted: Thu Dec 27, 2018 3:20 am
I set up a new Meteobridge Pro Red a few days ago, and seem to be having problems with the RF connection to my Vantage Pro 2 (also only a few weeks old). I've found several threads with people having very similar problems, but not the solution. The problem is this:
At a distance of 62m direct line of site through open window, MB only receives rain sensor, at -85 db for 5 seconds then drops and never reacquires in 3 hours, all other sensor show -- on MB display.
At distance of 10m direct line of site (outside running on battery pack), MB only receives rain sensor, at -75 db for 5 seconds then drops and doesn't reacquire in 30 minutes.
At distance of 3m direct line of site (outside running on battery pack), MB receives no sensors and doesn't acquire in 20 minutes. All sensors on MB RF display a --
With Davis logger set to repeat and MB set to receive via console:
At distance 1m all sensors acquired in 8 minutes at -38 to -40 db.
At distance 15m all sensors acquired at -55 to -65 db.
At distance 24m all sensors acquired at -75 db, degrading to -80 db over 10 minutes, then signal lost and not reacquired.
MB connection to home WiFi is good and stays stable out to at least 32m (furthest tested). The installation is on a small acreage in a rural area with very little signal interference other than WiFi network. The Davis console reception from ISS is acceptable in all locations within the house at furthest tested distance of 80m.
My ideal installation location is 60m from ISS through single brick wall. My second choice installation is 62m from ISS through single glass window. I'd be happy enough to buy a repeater if absolutely necessary, but with the current reception issue I don't think this would solve the problem.
I am in Australia and Davis equipment was purchased in Australia (as was MB). The MB is set correctly to ISS on stn#1, RF module Vantage on AU915 MHz, direct reception selected, RF Sense on -90 for all direct ISS attempts.
For console repeat attempts all setting the same except for Stn#2 set to match logger repeat station, via console selected and RF sense set to -10 db below reported signal strength at each trial and -80, -90 and -95 tried at 24m trial.
I'm currently running the MB via repeating off the logger at a separation of 1m, which is not ideal for me, so I'd really appreciate any advice or assistance about the MB reception problem.
Secondary problem is that the MB inside Temp and inside Hum are reporting wildly different to console: MB indoor temp is 14 to 22 C high, hum is approx. 20% low, pressure matches between logger and MB. Although the Davis console inside T and H readings have struck me as a bit erroneous since I set the station up a fortnight ago, the values being reported by the MB are a fantasy, and though I don't use these datum, it bothers me that they are so wildly wrong. The error magnitude appears non-linear.
Thanks Daemon.
Thanks Daemon.
