Where are "stick with...". entries for 3.7 and 3.8? **solved**
Posted: Tue Jan 08, 2019 4:38 pm
by doncurtis
I am on 'get newest on boot' and at the January 6th build of 3.9 but in the drop down selection it only shows stick with versions 2.0 thru 3.6. No entries to stick with 3.7 or 3.8
Is the above just an oversight or is 3.6 the last "solid" build?
Don
Re: Where are "stick with...". entries for 3.7 and 3.8?
Posted: Wed Jan 09, 2019 2:21 pm
Which HW platform are you on?
Posted: Wed Jan 09, 2019 4:39 pm
by wvdkuil
Same here with 3.8
Posted: Thu Jan 10, 2019 3:40 pm
by doncurtis
admin wrote: Wed Jan 09, 2019 2:21 pm
DIR-505L
Posted: Sun Jan 13, 2019 2:12 am
by doncurtis
Bump
Posted: Sun Jan 13, 2019 11:27 am
This is a bug of the finalized version 3.8. When you want to get to 3.7 you first need to go to the newest version and can down step to 3.7 from there.
From version 3.9 on going back will be limited to version 3.2.
I don't think anybody needs to step down from 3.9 or later to any of the versions years ago. If needed one can go to 3.2 first and then from there reach the very old versions.
Re: Where are "stick with...". entries for 3.7 and 3.8? **solved**
Posted: Sun Jan 13, 2019 3:58 pm
by doncurtis
I have the newest version (3.9 dated 6 Jan 2019), I want to stick with 3.8 but neither 3.8 nor 3.7 are available in the version drop down.
Posted: Sun Jan 13, 2019 4:04 pm
Which HW platform are you using?
Posted: Sun Jan 13, 2019 7:17 pm
by doncurtis
admin wrote: Sun Jan 13, 2019 4:04 pm
I answered above DIR-505L
It obviously runs fine on 3.9. I am guessing that the bug you mentioned in the final 3.8 version carried over into the January 6, 2019 version of 3.9
I am seeing the same thing wvdkuil posted above, same HW too.
Don
Posted: Sun Jan 13, 2019 10:31 pm
by doncurtis
Ok, you fixed it in 3.9, January 13th build, and I can go back to 3.8. However, when I do, the "stick with..." goes back to get newest on boot and, of course since the bug exists in 3.8, it doesn't allow me to stay with 3.8
Please fix the final build of 3.8 so I can stay there.
My "free updates" ends on the 31st of this month and I am not sure if 3.9 will be finalized by then... So I would have to go back to 3.6.
Don
Posted: Sun Jan 13, 2019 10:52 pm
You can leave settings at "newest" and it will simply limit this to the newest available in your span of update support. So no need to manually restrict this.
Posted: Mon Jan 14, 2019 3:14 pm
by doncurtis
Ok, thank you!
