how to connect usb thumb drive
Posted: Sat Jan 12, 2019 5:14 am
I bought a Ambient Weather weatherbridge server with Meteohub installed. I plugged in a 16GB thumb drive into the hub. I formated it ext4 before plugging it in. is there a way to access the drive over the network. i saw a reference to that somewhere. don't see where it is mounted in file system.
perhaps i don't know what i'm doing.
https://www.ambientweather.com/amweatherbridge.html
hardware is TP-Link MR3020(UN) Ver 1.9
USB V2 Hub
dmesg:
[ 8.450000] Initializing USB Mass Storage driver...
[ 8.450000] usbcore: registered new interface driver usb-storage
[ 8.460000] USB Mass Storage support registered.
[ 8.660000] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 8.810000] hub 1-1:1.0: USB hub found
[ 8.810000] hub 1-1:1.0: 4 ports detected
[ 9.090000] usb 1-1.2: new high-speed USB device number 3 using ehci-platform
[ 9.220000] scsi0 : usb-storage 1-1.2:1.0
[ 9.320000] usb 1-1.3: new full-speed USB device number 4 using ehci-platform
[ 10.450000] scsi 0:0:0:0: Direct-Access PNY USB 2.0 FD 1100 PQ: 0 ANSI: 4
[ 10.460000] sd 0:0:0:0: [sda] 31405824 512-byte logical blocks: (16.0 GB/14.9 GiB)
[ 10.470000] sd 0:0:0:0: [sda] Write Protect is off
[ 10.470000] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[ 10.470000] sd 0:0:0:0: [sda] No Caching mode page present
[ 10.480000] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 10.490000] sd 0:0:0:0: [sda] No Caching mode page present
[ 10.490000] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 10.500000] sda: sda1
[ 10.510000] sd 0:0:0:0: [sda] No Caching mode page present
[ 10.510000] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 10.520000] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 64.300000] EXT4-fs (sda1): couldn't mount as ext3 due to feature incompatibilities
[ 64.310000] EXT4-fs (sda1): couldn't mount as ext2 due to feature incompatibilities
[ 64.350000] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 70.600000] EXT4-fs (sda1): couldn't mount as ext3 due to feature incompatibilities
[ 70.610000] EXT4-fs (sda1): couldn't mount as ext2 due to feature incompatibilities
[ 70.630000] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 83.530000] EXT4-fs (sda1): couldn't mount as ext3 due to feature incompatibilities
[ 83.540000] EXT4-fs (sda1): couldn't mount as ext2 due to feature incompatibilities
[ 83.570000] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 89.720000] EXT4-fs (sda1): couldn't mount as ext3 due to feature incompatibilities
[ 89.750000] EXT4-fs (sda1): couldn't mount as ext2 due to feature incompatibilities
[ 89.780000] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 89.860000] usb 1-1: USB disconnect, device number 2
[ 89.870000] usb 1-1.2: USB disconnect, device number 3
[ 89.900000] usb 1-1.3: USB disconnect, device number 4
[ 89.900000] cp210x ttyUSB0: cp210x converter now disconnected from ttyUSB0
[ 89.910000] cp210x 1-1.3:1.0: device disconnected
[ 91.300000] usb 1-1: new high-speed USB device number 5 using ehci-platform
[ 91.450000] hub 1-1:1.0: USB hub found
[ 91.450000] hub 1-1:1.0: 4 ports detected
[ 92.040000] usb 1-1.2: new high-speed USB device number 6 using ehci-platform
[ 92.190000] scsi1 : usb-storage 1-1.2:1.0
[ 92.290000] usb 1-1.3: new full-speed USB device number 7 using ehci-platform
[ 92.420000] cp210x 1-1.3:1.0: cp210x converter detected
[ 92.530000] usb 1-1.3: reset full-speed USB device number 7 using ehci-platform
[ 92.660000] usb 1-1.3: cp210x converter now attached to ttyUSB0
[ 93.490000] scsi 1:0:0:0: Direct-Access PNY USB 2.0 FD 1100 PQ: 0 ANSI: 4
[ 93.520000] sd 1:0:0:0: [sda] 31405824 512-byte logical blocks: (16.0 GB/14.9 GiB)
[ 93.520000] sd 1:0:0:0: [sda] Write Protect is off
[ 93.530000] sd 1:0:0:0: [sda] Mode Sense: 43 00 00 00
[ 93.550000] sd 1:0:0:0: [sda] No Caching mode page present
[ 93.550000] sd 1:0:0:0: [sda] Assuming drive cache: write through
[ 93.580000] sd 1:0:0:0: [sda] No Caching mode page present
[ 93.580000] sd 1:0:0:0: [sda] Assuming drive cache: write through
[ 93.610000] sda: sda1
[ 93.620000] sd 1:0:0:0: [sda] No Caching mode page present
[ 93.620000] sd 1:0:0:0: [sda] Assuming drive cache: write through
[ 93.630000] sd 1:0:0:0: [sda] Attached SCSI removable disk
[ 720.260000] EXT4-fs (sda1): couldn't mount as ext3 due to feature incompatibilities
[ 720.270000] EXT4-fs (sda1): couldn't mount as ext2 due to feature incompatibilities
[ 720.310000] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 1322.170000] EXT4-fs (sda1): couldn't mount as ext3 due to feature incompatibilities
[ 1322.180000] EXT4-fs (sda1): couldn't mount as ext2 due to feature incompatibilities
[ 1322.210000] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
USB V2 Hub
dmesg:
