nano SD looses contact with console multiple times / hour
Posted: Fri Jan 18, 2019 4:21 pm
Example: 3 hours running, 9 times restart
Graphs are incomplete: see attached screenshot mbnano-graphs.jpeg
Live data shows nothing: see attached screenshot mbnano-livedata.jpeg
Do I need to ask for a replacement or is there another problem?
logger (18.01.2019 12:09:26): connect station 9 (System Data via Plug-in).
logger (18.01.2019 12:09:26): wakeup sent.
logger (18.01.2019 12:09:28): no need to update console date/time.
logger (18.01.2019 12:09:28): setup script executed.
logger (18.01.2019 12:09:28): internal logger activated.
logger (18.01.2019 12:09:28): syncing.
logger (18.01.2019 12:09:29): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (18.01.2019 12:09:29): services paused.
logger (18.01.2019 12:09:38): gettime request sent.
logger (18.01.2019 12:09:38): no Vantage time offset.
logger (18.01.2019 12:09:38): eeprom request sent.
logger (18.01.2019 12:09:38): rain collector size 0.2 mm per tick.
logger (18.01.2019 12:09:38): transmitter 5 active as station type #0 "ISS".
logger (18.01.2019 12:09:38): firmware version request sent.
logger (18.01.2019 12:09:38): firmware version 4.33 (supports LOOP2)
logger (18.01.2019 12:09:38): no reading of Vantage's internal logger.
logger (18.01.2019 12:09:43): sensors are now providing data.
logger (18.01.2019 12:09:43): services started.
logger (18.01.2019 12:29:59): child process received timeout signal (14).
logger (18.01.2019 12:29:59): disconnect station 0 (Vantage): exit
logger (18.01.2019 12:29:59): disconnect station 9 (System Data): exit
logger (18.01.2019 12:30:04): data logger stopped.
logger (18.01.2019 12:30:04): databases disconnected.
logger (18.01.2019 12:30:04): databases connected. Update interval 3600 seconds.
logger (18.01.2019 12:30:04): data logger (version 5.1a, build 1865) started.
logger (18.01.2019 12:30:05): connect station 0 (Vantage via USB serial).
logger (18.01.2019 12:30:05): connect station 9 (System Data via Plug-in).
logger (18.01.2019 12:30:05): wakeup sent.
logger (18.01.2019 12:30:06): no need to update console date/time.
logger (18.01.2019 12:30:07): setup script executed.
logger (18.01.2019 12:30:07): internal logger activated.
logger (18.01.2019 12:30:07): syncing.
logger (18.01.2019 12:30:08): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (18.01.2019 12:30:08): services paused.
logger (18.01.2019 12:30:17): gettime request sent.
logger (18.01.2019 12:30:17): no Vantage time offset.
logger (18.01.2019 12:30:17): eeprom request sent.
logger (18.01.2019 12:30:17): rain collector size 0.2 mm per tick.
logger (18.01.2019 12:30:17): transmitter 5 active as station type #0 "ISS".
logger (18.01.2019 12:30:17): firmware version request sent.
logger (18.01.2019 12:30:17): firmware version 4.33 (supports LOOP2)
logger (18.01.2019 12:30:17): no reading of Vantage's internal logger.
logger (18.01.2019 12:30:21): sensors are now providing data.
logger (18.01.2019 12:30:21): services started.
logger (18.01.2019 12:50:39): child process received timeout signal (14).
logger (18.01.2019 12:50:39): disconnect station 0 (Vantage): exit
logger (18.01.2019 12:50:39): disconnect station 9 (System Data): exit
logger (18.01.2019 12:50:42): data logger stopped.
logger (18.01.2019 12:50:42): databases disconnected.
logger (18.01.2019 12:50:42): databases connected. Update interval 3600 seconds.
logger (18.01.2019 12:50:42): data logger (version 5.1a, build 1865) started.
logger (18.01.2019 12:50:42): connect station 0 (Vantage via USB serial).
logger (18.01.2019 12:50:42): connect station 9 (System Data via Plug-in).
logger (18.01.2019 12:50:43): wakeup sent.
logger (18.01.2019 12:50:44): no need to update console date/time.
logger (18.01.2019 12:50:44): setup script executed.
logger (18.01.2019 12:50:45): internal logger activated.
logger (18.01.2019 12:50:45): syncing.
logger (18.01.2019 12:50:46): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (18.01.2019 12:50:46): services paused.
logger (18.01.2019 12:50:55): gettime request sent.
logger (18.01.2019 12:50:55): no Vantage time offset.
logger (18.01.2019 12:50:55): eeprom request sent.
logger (18.01.2019 12:50:55): rain collector size 0.2 mm per tick.
logger (18.01.2019 12:50:55): transmitter 5 active as station type #0 "ISS".
logger (18.01.2019 12:50:55): firmware version request sent.
logger (18.01.2019 12:50:55): firmware version 4.33 (supports LOOP2)
logger (18.01.2019 12:50:55): no reading of Vantage's internal logger.
logger (18.01.2019 12:50:59): sensors are now providing data.
logger (18.01.2019 12:50:59): services started.
logger (18.01.2019 13:11:17): child process received timeout signal (14).
logger (18.01.2019 13:11:17): disconnect station 0 (Vantage): exit
logger (18.01.2019 13:11:17): disconnect station 9 (System Data): exit
logger (18.01.2019 13:11:20): data logger stopped.
logger (18.01.2019 13:11:20): databases disconnected.
logger (18.01.2019 13:11:20): databases connected. Update interval 3600 seconds.
logger (18.01.2019 13:11:20): data logger (version 5.1a, build 1865) started.
logger (18.01.2019 13:11:21): connect station 0 (Vantage via USB serial).
logger (18.01.2019 13:11:21): connect station 9 (System Data via Plug-in).
logger (18.01.2019 13:11:21): wakeup sent.
logger (18.01.2019 13:11:23): no need to update console date/time.
logger (18.01.2019 13:11:23): setup script executed.
logger (18.01.2019 13:11:23): internal logger activated.
logger (18.01.2019 13:11:23): syncing.
logger (18.01.2019 13:11:24): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (18.01.2019 13:11:24): services paused.
logger (18.01.2019 13:11:33): gettime request sent.
logger (18.01.2019 13:11:33): no Vantage time offset.
logger (18.01.2019 13:11:33): eeprom request sent.
logger (18.01.2019 13:11:33): rain collector size 0.2 mm per tick.
logger (18.01.2019 13:11:33): transmitter 5 active as station type #0 "ISS".
logger (18.01.2019 13:11:33): firmware version request sent.
logger (18.01.2019 13:11:33): firmware version 4.33 (supports LOOP2)
logger (18.01.2019 13:11:33): no reading of Vantage's internal logger.
logger (18.01.2019 13:11:37): sensors are now providing data.
logger (18.01.2019 13:11:37): services started.
logger (18.01.2019 13:31:55): child process received timeout signal (14).
logger (18.01.2019 13:31:55): disconnect station 0 (Vantage): exit
logger (18.01.2019 13:31:55): disconnect station 9 (System Data): exit
logger (18.01.2019 13:31:58): data logger stopped.
logger (18.01.2019 13:31:58): databases disconnected.
logger (18.01.2019 13:31:58): databases connected. Update interval 3600 seconds.
logger (18.01.2019 13:31:58): data logger (version 5.1a, build 1865) started.
logger (18.01.2019 13:31:58): connect station 0 (Vantage via USB serial).
logger (18.01.2019 13:31:58): connect station 9 (System Data via Plug-in).
logger (18.01.2019 13:31:58): wakeup sent.
logger (18.01.2019 13:32:00): no need to update console date/time.
logger (18.01.2019 13:32:00): setup script executed.
logger (18.01.2019 13:32:00): internal logger activated.
logger (18.01.2019 13:32:00): syncing.
logger (18.01.2019 13:32:00): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (18.01.2019 13:32:00): services paused.
logger (18.01.2019 13:32:10): gettime request sent.
logger (18.01.2019 13:32:10): no Vantage time offset.
logger (18.01.2019 13:32:10): eeprom request sent.
logger (18.01.2019 13:32:10): rain collector size 0.2 mm per tick.
logger (18.01.2019 13:32:10): transmitter 5 active as station type #0 "ISS".
logger (18.01.2019 13:32:10): firmware version request sent.
logger (18.01.2019 13:32:10): firmware version 4.33 (supports LOOP2)
logger (18.01.2019 13:32:10): no reading of Vantage's internal logger.
logger (18.01.2019 13:32:15): sensors are now providing data.
logger (18.01.2019 13:32:15): services started.
logger (18.01.2019 13:52:31): child process received timeout signal (14).
logger (18.01.2019 13:52:31): disconnect station 0 (Vantage): exit
logger (18.01.2019 13:52:31): disconnect station 9 (System Data): exit
logger (18.01.2019 13:52:34): data logger stopped.
logger (18.01.2019 13:52:34): databases disconnected.
logger (18.01.2019 13:52:34): databases connected. Update interval 3600 seconds.
logger (18.01.2019 13:52:34): data logger (version 5.1a, build 1865) started.
logger (18.01.2019 13:52:34): connect station 0 (Vantage via USB serial).
logger (18.01.2019 13:52:34): connect station 9 (System Data via Plug-in).
logger (18.01.2019 13:52:34): wakeup sent.
logger (18.01.2019 13:52:36): no need to update console date/time.
logger (18.01.2019 13:52:36): setup script executed.
logger (18.01.2019 13:52:37): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (18.01.2019 13:52:37): services paused.
logger (18.01.2019 13:52:37): internal logger activated.
logger (18.01.2019 13:52:37): syncing.
logger (18.01.2019 13:52:47): gettime request sent.
logger (18.01.2019 13:52:47): no Vantage time offset.
logger (18.01.2019 13:52:47): eeprom request sent.
logger (18.01.2019 13:52:47): rain collector size 0.2 mm per tick.
logger (18.01.2019 13:52:47): transmitter 5 active as station type #0 "ISS".
logger (18.01.2019 13:52:47): firmware version request sent.
logger (18.01.2019 13:52:47): firmware version 4.33 (supports LOOP2)
logger (18.01.2019 13:52:47): no reading of Vantage's internal logger.
logger (18.01.2019 13:52:51): sensors are now providing data.
logger (18.01.2019 13:52:51): services started.
logger (18.01.2019 14:13:07): child process received timeout signal (14).
logger (18.01.2019 14:13:07): disconnect station 0 (Vantage): exit
logger (18.01.2019 14:13:07): disconnect station 9 (System Data): exit
logger (18.01.2019 14:13:10): data logger stopped.
logger (18.01.2019 14:13:10): databases disconnected.
logger (18.01.2019 14:13:10): databases connected. Update interval 3600 seconds.
logger (18.01.2019 14:13:10): data logger (version 5.1a, build 1865) started.
logger (18.01.2019 14:13:10): connect station 0 (Vantage via USB serial).
logger (18.01.2019 14:13:10): connect station 9 (System Data via Plug-in).
logger (18.01.2019 14:13:11): wakeup sent.
logger (18.01.2019 14:13:12): no need to update console date/time.
logger (18.01.2019 14:13:12): setup script executed.
logger (18.01.2019 14:13:13): internal logger activated.
logger (18.01.2019 14:13:13): syncing.
logger (18.01.2019 14:13:14): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (18.01.2019 14:13:14): services paused.
logger (18.01.2019 14:13:23): gettime request sent.
logger (18.01.2019 14:13:23): no Vantage time offset.
logger (18.01.2019 14:13:23): eeprom request sent.
logger (18.01.2019 14:13:23): rain collector size 0.2 mm per tick.
logger (18.01.2019 14:13:23): transmitter 5 active as station type #0 "ISS".
logger (18.01.2019 14:13:23): firmware version request sent.
logger (18.01.2019 14:13:23): firmware version 4.33 (supports LOOP2)
logger (18.01.2019 14:13:23): no reading of Vantage's internal logger.
logger (18.01.2019 14:13:27): sensors are now providing data.
logger (18.01.2019 14:13:27): services started.
logger (18.01.2019 14:33:45): child process received timeout signal (14).
logger (18.01.2019 14:33:45): disconnect station 0 (Vantage): exit
logger (18.01.2019 14:33:45): disconnect station 9 (System Data): exit
logger (18.01.2019 14:33:48): data logger stopped.
logger (18.01.2019 14:33:48): databases disconnected.
logger (18.01.2019 14:33:48): databases connected. Update interval 3600 seconds.
logger (18.01.2019 14:33:48): data logger (version 5.1a, build 1865) started.
logger (18.01.2019 14:33:48): connect station 0 (Vantage via USB serial).
logger (18.01.2019 14:33:48): connect station 9 (System Data via Plug-in).
logger (18.01.2019 14:33:49): wakeup sent.
logger (18.01.2019 14:33:50): no need to update console date/time.
logger (18.01.2019 14:33:50): setup script executed.
logger (18.01.2019 14:33:51): internal logger activated.
logger (18.01.2019 14:33:51): syncing.
logger (18.01.2019 14:33:52): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (18.01.2019 14:33:52): services paused.
logger (18.01.2019 14:34:01): gettime request sent.
logger (18.01.2019 14:34:01): no Vantage time offset.
logger (18.01.2019 14:34:01): eeprom request sent.
logger (18.01.2019 14:34:01): rain collector size 0.2 mm per tick.
logger (18.01.2019 14:34:01): transmitter 5 active as station type #0 "ISS".
logger (18.01.2019 14:34:01): firmware version request sent.
logger (18.01.2019 14:34:01): firmware version 4.33 (supports LOOP2)
logger (18.01.2019 14:34:01): no reading of Vantage's internal logger.
logger (18.01.2019 14:34:05): sensors are now providing data.
logger (18.01.2019 14:34:05): services started.
logger (18.01.2019 14:54:23): child process received timeout signal (14).
logger (18.01.2019 14:54:23): disconnect station 0 (Vantage): exit
logger (18.01.2019 14:54:23): disconnect station 9 (System Data): exit
logger (18.01.2019 14:54:27): data logger stopped.
logger (18.01.2019 14:54:27): databases disconnected.
logger (18.01.2019 14:54:27): databases connected. Update interval 3600 seconds.
logger (18.01.2019 14:54:27): data logger (version 5.1a, build 1865) started.
logger (18.01.2019 14:54:28): connect station 0 (Vantage via USB serial).
logger (18.01.2019 14:54:28): connect station 9 (System Data via Plug-in).
logger (18.01.2019 14:54:28): wakeup sent.
logger (18.01.2019 14:54:30): no need to update console date/time.
logger (18.01.2019 14:54:30): setup script executed.
logger (18.01.2019 14:54:30): internal logger activated.
logger (18.01.2019 14:54:30): syncing.
logger (18.01.2019 14:54:31): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (18.01.2019 14:54:31): services paused.
logger (18.01.2019 14:54:40): gettime request sent.
logger (18.01.2019 14:54:40): no Vantage time offset.
logger (18.01.2019 14:54:40): eeprom request sent.
logger (18.01.2019 14:54:40): rain collector size 0.2 mm per tick.
logger (18.01.2019 14:54:40): transmitter 5 active as station type #0 "ISS".
logger (18.01.2019 14:54:40): firmware version request sent.
logger (18.01.2019 14:54:40): firmware version 4.33 (supports LOOP2)
logger (18.01.2019 14:54:40): no reading of Vantage's internal logger.
logger (18.01.2019 14:54:45): sensors are now providing data.
logger (18.01.2019 14:54:45): services started.Live data shows nothing: see attached screenshot mbnano-livedata.jpeg
