Conversion Incorrect **solved**
LAWx
Post by LAWx » Thu Feb 14, 2019 4:02 pm
Meteobridge conversion from mm to inches is incorrect. This can be tested during any rain event by entering the following alarm:
RAISE: [rain0total-sum24h] > 0
BODY: [rain0total-sum24h=in.01] should equal {*[rain0total-sum24h]/25.4*}
The result In my case? "2.0 should equal 2.04"
Re: Conversion Incorrect
Post by wvdkuil » Thu Feb 14, 2019 5:07 pm
As far as I can see with =in.01 the number of decimals requested is 1 , the default
If you want two decimals it should be =in.2
