Modify annual rainfall total in NANO SD. **solved**
Posted: Fri Jun 21, 2019 5:38 pm
by splobsterman
When I set up the SD on my VP2 Pro it did not read the annual rainfall to date. How can I correct that? Is there a way to do so in the NANO SD interface?
Re: Modify annual rainfall total in NANO SD
Posted: Fri Jun 21, 2019 11:23 pm
by Mattk
Not sure if there is a specific bulk update but go to the History tab, select the sensor (say rain0total), select Year, Month, Day etc, in the Edit Data window at the bottom click a data value to edit/change it. If you have a yearly total by day or month then add it into a single day or edit each day etc
Posted: Sat Jun 22, 2019 7:23 pm
by splobsterman
Thanks, that worked, though when you check the box to use Imperial measure it doesn't accept inches correctly, so I entered the values converted to mm and all is well.
Posted: Fri Mar 12, 2021 3:46 am
by wdg
I need to update my rain totals for this year as well. I can select a day to update the rain, but it shows fields by hour. If I input the rainfall for that (ex. 50mm) day into hour 23, won't the system treat that as receiving 50mm of rain in a single hour? I don't want such a reading to disturb any future hourly record totals.
Posted: Sat Mar 13, 2021 1:51 pm
As all aggregations are based on real data, you have to enter the rain somewhere. If you want to distribute across hours/days/months you can do. Meteobridge does not support to enter a total rain value that is inconsistent with the aggregation of its hourly data.
Posted: Sat Mar 13, 2021 4:14 pm
by wdg
I see. One more question. Is there a way to enter data in a previous year? I only see 2021 as an option for a year.
Posted: Mon Mar 15, 2021 6:06 pm
by wdg
No need to reply. I just uploaded some fake weather data from a past year and then subsequent years popped up. All is good!
