TP3020 Help **solved**
Posted: Wed Oct 23, 2019 4:45 pm
Hey everyone,
TLDR I had a local router my TP3020 was connected to go bad on me. Before I realized that the router was the the actual problem (it failed over a period of days through constant reboots until it finally bricked) I dove into OpenWRT and probably changed a few too many things, oops
. I did a reset on the firmware to start fresh. Now with my new router up and running and the TP3020 reset I'm having some issues getting it connected to my new network and it loading the application stack. If anyone could lend a hand I'd be very grateful.
Below is my log from the landing page. I can get any logs from OpenWRT as well if that will be helpful.
IFCONFIG:
eth0 Link encap:Ethernet HWaddr EC:08:6B:B3:30:72
inet addr:192.168.168.1 Bcast:192.168.168.255 Mask:255.255.255.0
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:4
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:824 errors:0 dropped:0 overruns:0 frame:0
TX packets:824 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:55888 (54.5 KiB) TX bytes:55888 (54.5 KiB)
wlan0 Link encap:Ethernet HWaddr EC:08:6B:B3:30:72
inet addr:192.168.1.122 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:310 errors:0 dropped:2 overruns:0 frame:0
TX packets:385 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:32
RX bytes:40471 (39.5 KiB) TX bytes:256216 (250.2 KiB)
RESOLV.CONF:
search lan
nameserver 127.0.0.1
ROUTE:
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
192.168.1.0 * 255.255.255.0 U 0 0 0 wlan0
192.168.168.0 * 255.255.255.0 U 0 0 0 eth0
NSLOOKUP:
Server: 127.0.0.1
Address 1: 127.0.0.1 localhost
