Power off issue during display service
Posted: Sun Feb 02, 2020 5:42 pm
by saalbers
I show BIG-scroll-ISO.dsp every full 10 minutes. I did the power off during the display off the different values. Eventually the leds stopped blinking but the display showed one of the values permanently and the Meteobridge Pro did not power off. I had to pull the power plug to stop the Meteobridge Pro.
It was build from 30th of January 2020.
Sjoerd
Re: Power off issue during display service
Posted: Sun Feb 02, 2020 6:43 pm
How did you do the power off? With the button on "System" tab?
BTW: I recommend to use the "once" version of the display scripts, otherwise you will wear out the OLED soon.
Posted: Sun Feb 02, 2020 9:52 pm
by saalbers
Ok, I will do that. Yes, I used the button on the system tab.
