Killed process
Posted: Sat Jun 20, 2020 10:06 am
Last week, MB pro stopped recording and transmitting data twice within a few days. After a restart, everything returned to normal.
Logger: logger (06.06.2020 08:01:09): killed process "2866 / sh" listening to port 5551; logger (20.06.2020 01:56:00): killed process "24180 / sh" listening to port 5551.
BB
oled (18.06.2020 05:08:50): process started.
database (18.06.2020 07:10:55): process started.
database (18.06.2020 07:10:55): Content of RAM database restored.
wnetd (18.06.2020 07:10:58): process started.
system (18.06.2020 07:10:58): start of logging process initiated.
wnetd (18.06.2020 07:10:58): send data thread started (pid:2763 tid:2764)
logger (18.06.2020 07:10:58): databases connected. Update interval 3600 seconds.
logger (18.06.2020 07:10:58): data logger (version 5.1d, build 13568) started.
logger (18.06.2020 07:11:01): connect station 0 (Meteostick Vantage via USB serial).
logger (18.06.2020 07:11:01): connect station 9 (System Data via Plug-in).
logger (18.06.2020 07:11:03): transmitter 1 registered as ISS
logger (18.06.2020 07:11:03): transmitter 2 registered as Wind
logger (18.06.2020 07:11:03): transmitter 3 registered as Temperature
logger (18.06.2020 07:11:03): transmitter 4 registered as Temperature
logger (18.06.2020 07:11:03): Meteostick Version 2.5.2
logger (18.06.2020 07:11:03): debug off
logger (18.06.2020 07:11:03): verbose off
logger (18.06.2020 07:11:03): output raw (8 bytes)
logger (18.06.2020 07:11:03): output raw (10 bytes)
logger (18.06.2020 07:11:03): filter on
logger (18.06.2020 07:11:03): rx threshold set to -90db
logger (18.06.2020 07:11:03): listening to transmitter 1 2 3 4
logger (18.06.2020 07:11:03): bandwidth narrow
logger (18.06.2020 07:11:03): chip authentication ok: 14
logger (18.06.2020 07:11:03): frequency band 868MHz (EU)
logger (18.06.2020 07:11:04): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (18.06.2020 07:11:04): services paused.
database (18.06.2020 07:11:33): database sync done (60 tables, 168/2580 writes).
logger (18.06.2020 07:12:04): sensors are now providing data.
logger (18.06.2020 07:12:04): services started.
logger (18.06.2020 08:01:09): databases connected. Update interval 3600 seconds.
logger (18.06.2020 08:01:09): data logger (version 5.1d, build 13568) started.
logger (18.06.2020 08:01:09): error (125) while doing bind (port 5551): Address already in use
logger (18.06.2020 08:01:09): killed process "2866/sh" listening to port 5551.
logger (18.06.2020 08:01:39): databases connected. Update interval 3600 seconds.
logger (18.06.2020 08:01:39): data logger (version 5.1d, build 13568) started.
logger (18.06.2020 08:01:39): error (125) while doing bind (port 5551): Address already in use
logger (18.06.2020 08:01:39): killed process "2867/meteosys" listening to port 5551.
logger (18.06.2020 08:02:09): databases connected. Update interval 3600 seconds.
logger (18.06.2020 08:02:09): data logger (version 5.1d, build 13568) started.
logger (18.06.2020 08:02:10): connect station 0 (Meteostick Vantage via USB serial).
logger (18.06.2020 08:02:10): connect station 9 (System Data via Plug-in).
logger (18.06.2020 08:02:10): transmitter 1 registered as ISS
logger (18.06.2020 08:02:10): transmitter 2 registered as Wind
logger (18.06.2020 08:02:10): transmitter 3 registered as Temperature
logger (18.06.2020 08:02:10): transmitter 4 registered as Temperature
logger (18.06.2020 08:02:10): Meteostick Version 2.5.2
logger (18.06.2020 08:02:10): debug off
logger (18.06.2020 08:02:10): verbose off
logger (18.06.2020 08:02:10): output raw (8 bytes)
logger (18.06.2020 08:02:10): output raw (10 bytes)
logger (18.06.2020 08:02:10): filter on
logger (18.06.2020 08:02:10): rx threshold set to -90db
logger (18.06.2020 08:02:10): listening to transmitter 1 2 3 4
logger (18.06.2020 08:02:10): bandwidth narrow
logger (18.06.2020 08:02:10): chip authentication ok: 14
logger (18.06.2020 08:02:10): frequency band 868MHz (EU)
logger (18.06.2020 08:02:13): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (18.06.2020 08:02:13): services paused.
logger (18.06.2020 08:03:11): sensors are now providing data.
logger (18.06.2020 08:03:11): services started.
logger (18.06.2020 08:22:15): child process received termination signal (11) in functions: termination_handler < inetupload_getline < inetupload_getfilteredline < generate_loggerevalfile < generate_loggerfile < gen_CLIENTLOGFILE < gen_...
logger (18.06.2020 08:22:15): disconnect station 0 (Meteostick Vantage): exit
logger (18.06.2020 08:22:15): disconnect station 9 (System Data): exit
logger (18.06.2020 08:22:16): databases connected. Update interval 3600 seconds.
logger (18.06.2020 08:22:16): data logger (version 5.1d, build 13568) started.
logger (18.06.2020 08:22:17): connect station 0 (Meteostick Vantage via USB serial).
logger (18.06.2020 08:22:17): connect station 9 (System Data via Plug-in).
logger (18.06.2020 08:22:17): transmitter 1 registered as ISS
logger (18.06.2020 08:22:17): transmitter 2 registered as Wind
logger (18.06.2020 08:22:17): transmitter 3 registered as Temperature
logger (18.06.2020 08:22:17): transmitter 4 registered as Temperature
logger (18.06.2020 08:22:17): Meteostick Version 2.5.2
logger (18.06.2020 08:22:17): debug off
logger (18.06.2020 08:22:17): verbose off
logger (18.06.2020 08:22:17): output raw (8 bytes)
logger (18.06.2020 08:22:17): output raw (10 bytes)
logger (18.06.2020 08:22:17): filter on
logger (18.06.2020 08:22:17): rx threshold set to -90db
logger (18.06.2020 08:22:17): listening to transmitter 1 2 3 4
logger (18.06.2020 08:22:17): bandwidth narrow
logger (18.06.2020 08:22:18): chip authentication ok: 14
logger (18.06.2020 08:22:18): frequency band 868MHz (EU)
logger (18.06.2020 08:22:20): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (18.06.2020 08:22:20): services paused.
logger (18.06.2020 08:23:19): sensors are now providing data.
logger (18.06.2020 08:23:19): services started.
logger (18.06.2020 08:42:22): child process received termination signal (11) in functions: termination_handler < inetupload_getline < inetupload_getfilteredline < generate_loggerevalfile < generate_loggerfile < gen_CLIENTLOGFILE < gen_...
logger (18.06.2020 08:42:22): disconnect station 0 (Meteostick Vantage): exit
logger (18.06.2020 08:42:22): disconnect station 9 (System Data): exit
logger (18.06.2020 08:42:23): databases connected. Update interval 3600 seconds.
logger (18.06.2020 08:42:23): data logger (version 5.1d, build 13568) started.
logger (18.06.2020 08:42:24): connect station 0 (Meteostick Vantage via USB serial).
logger (18.06.2020 08:42:24): connect station 9 (System Data via Plug-in).
logger (18.06.2020 08:42:24): transmitter 1 registered as ISS
logger (18.06.2020 08:42:24): transmitter 2 registered as Wind
logger (18.06.2020 08:42:24): transmitter 3 registered as Temperature
logger (18.06.2020 08:42:24): transmitter 4 registered as Temperature
logger (18.06.2020 08:42:24): Meteostick Version 2.5.2
logger (18.06.2020 08:42:24): debug off
logger (18.06.2020 08:42:24): verbose off
logger (18.06.2020 08:42:24): output raw (8 bytes)
logger (18.06.2020 08:42:24): output raw (10 bytes)
logger (18.06.2020 08:42:24): filter on
logger (18.06.2020 08:42:24): rx threshold set to -90db
logger (18.06.2020 08:42:24): listening to transmitter 1 2 3 4
logger (18.06.2020 08:42:24): bandwidth narrow
logger (18.06.2020 08:42:25): chip authentication ok: 14
logger (18.06.2020 08:42:25): frequency band 868MHz (EU)
logger (18.06.2020 08:42:27): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (18.06.2020 08:42:27): services paused.
logger (18.06.2020 08:43:26): sensors are now providing data.
logger (18.06.2020 08:43:26): services started.
logger (18.06.2020 09:02:29): databases connected. Update interval 3600 seconds.
logger (18.06.2020 09:02:29): data logger (version 5.1d, build 13568) started.
logger (18.06.2020 09:02:29): error (125) while doing bind (port 5551): Address already in use
logger (18.06.2020 09:02:29): killed process "12561/sh" listening to port 5551.
logger (18.06.2020 09:02:59): databases connected. Update interval 3600 seconds.
logger (18.06.2020 09:02:59): data logger (version 5.1d, build 13568) started.
logger (18.06.2020 09:02:59): error (125) while doing bind (port 5551): Address already in use
logger (18.06.2020 09:02:59): killed process "12563/meteosys" listening to port 5551.
logger (18.06.2020 09:03:29): databases connected. Update interval 3600 seconds.
logger (18.06.2020 09:03:29): data logger (version 5.1d, build 13568) started.
logger (18.06.2020 09:03:30): connect station 0 (Meteostick Vantage via USB serial).
logger (18.06.2020 09:03:30): connect station 9 (System Data via Plug-in).
logger (18.06.2020 09:03:30): transmitter 1 registered as ISS
logger (18.06.2020 09:03:30): transmitter 2 registered as Wind
logger (18.06.2020 09:03:30): transmitter 3 registered as Temperature
logger (18.06.2020 09:03:30): transmitter 4 registered as Temperature
logger (18.06.2020 09:03:30): Meteostick Version 2.5.2
logger (18.06.2020 09:03:30): debug off
logger (18.06.2020 09:03:30): verbose off
logger (18.06.2020 09:03:30): output raw (8 bytes)
logger (18.06.2020 09:03:30): output raw (10 bytes)
logger (18.06.2020 09:03:30): filter on
logger (18.06.2020 09:03:30): rx threshold set to -90db
logger (18.06.2020 09:03:30): listening to transmitter 1 2 3 4
logger (18.06.2020 09:03:30): bandwidth narrow
logger (18.06.2020 09:03:31): chip authentication ok: 14
logger (18.06.2020 09:03:31): frequency band 868MHz (EU)
logger (18.06.2020 09:03:33): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (18.06.2020 09:03:33): services paused.
logger (18.06.2020 09:05:30): give up waiting for sensors after 120 secs.
logger (18.06.2020 09:05:30): services activated.
logger (18.06.2020 09:33:38): databases connected. Update interval 3600 seconds.
logger (18.06.2020 09:33:38): data logger (version 5.1d, build 13568) started.
logger (18.06.2020 09:33:38): error (125) while doing bind (port 5551): Address already in use
logger (18.06.2020 09:33:38): killed process "14974/sh" listening to port 5551.
logger (18.06.2020 09:34:08): databases connected. Update interval 3600 seconds.
logger (18.06.2020 09:34:08): data logger (version 5.1d, build 13568) started.
logger (18.06.2020 09:34:08): error (125) while doing bind (port 5551): Address already in use
logger (18.06.2020 09:34:08): killed process "14975/meteosys" listening to port 5551.
logger (18.06.2020 09:34:38): databases connected. Update interval 3600 seconds.
logger (18.06.2020 09:34:38): data logger (version 5.1d, build 13568) started.
logger (18.06.2020 09:34:39): connect station 0 (Meteostick Vantage via USB serial).
logger (18.06.2020 09:34:39): connect station 9 (System Data via Plug-in).
logger (18.06.2020 09:34:39): transmitter 1 registered as ISS
logger (18.06.2020 09:34:39): transmitter 2 registered as Wind
logger (18.06.2020 09:34:39): transmitter 3 registered as Temperature
logger (18.06.2020 09:34:39): transmitter 4 registered as Temperature
logger (18.06.2020 09:34:39): Meteostick Version 2.5.2
logger (18.06.2020 09:34:39): debug off
logger (18.06.2020 09:34:39): verbose off
logger (18.06.2020 09:34:39): output raw (8 bytes)
logger (18.06.2020 09:34:39): output raw (10 bytes)
logger (18.06.2020 09:34:39): filter on
logger (18.06.2020 09:34:39): rx threshold set to -90db
logger (18.06.2020 09:34:39): listening to transmitter 1 2 3 4
logger (18.06.2020 09:34:39): bandwidth narrow
logger (18.06.2020 09:34:40): chip authentication ok: 14
logger (18.06.2020 09:34:40): frequency band 868MHz (EU)
logger (18.06.2020 09:34:42): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (18.06.2020 09:34:42): services paused.
logger (18.06.2020 09:35:41): sensors are now providing data.
logger (18.06.2020 09:35:41): services started.
logger (18.06.2020 10:04:49): child process received termination signal (11) in functions: termination_handler < inetupload_getline < inetupload_getfilteredline < generate_loggerevalfile < generate_loggerfile < gen_CLIENTLOGFILE < gen_...
logger (18.06.2020 10:04:49): disconnect station 0 (Meteostick Vantage): exit
logger (18.06.2020 10:04:49): disconnect station 9 (System Data): exit
logger (18.06.2020 10:04:50): databases connected. Update interval 3600 seconds.
logger (18.06.2020 10:04:50): data logger (version 5.1d, build 13568) started.
logger (18.06.2020 10:04:51): connect station 0 (Meteostick Vantage via USB serial).
logger (18.06.2020 10:04:51): connect station 9 (System Data via Plug-in).
logger (18.06.2020 10:04:51): transmitter 1 registered as ISS
logger (18.06.2020 10:04:51): transmitter 2 registered as Wind
logger (18.06.2020 10:04:51): transmitter 3 registered as Temperature
logger (18.06.2020 10:04:51): transmitter 4 registered as Temperature
logger (18.06.2020 10:04:51): Meteostick Version 2.5.2
logger (18.06.2020 10:04:51): debug off
logger (18.06.2020 10:04:51): verbose off
logger (18.06.2020 10:04:51): output raw (8 bytes)
logger (18.06.2020 10:04:51): output raw (10 bytes)
logger (18.06.2020 10:04:51): filter on
logger (18.06.2020 10:04:51): rx threshold set to -90db
logger (18.06.2020 10:04:51): listening to transmitter 1 2 3 4
logger (18.06.2020 10:04:51): bandwidth narrow
logger (18.06.2020 10:04:52): chip authentication ok: 14
logger (18.06.2020 10:04:52): frequency band 868MHz (EU)
logger (18.06.2020 10:04:54): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (18.06.2020 10:04:54): services paused.
logger (18.06.2020 10:05:53): sensors are now providing data.
logger (18.06.2020 10:05:53): services started.
logger (18.06.2020 10:34:57): child process received termination signal (11) in functions: termination_handler < inetupload_getline < inetupload_getfilteredline < generate_loggerevalfile < generate_loggerfile < gen_CLIENTLOGFILE < gen_...
logger (18.06.2020 10:34:57): disconnect station 0 (Meteostick Vantage): exit
logger (18.06.2020 10:34:57): disconnect station 9 (System Data): exit
logger (18.06.2020 10:34:58): databases connected. Update interval 3600 seconds.
logger (18.06.2020 10:34:58): data logger (version 5.1d, build 13568) started.
logger (18.06.2020 10:34:59): connect station 0 (Meteostick Vantage via USB serial).
logger (18.06.2020 10:34:59): connect station 9 (System Data via Plug-in).
logger (18.06.2020 10:34:59): transmitter 1 registered as ISS
logger (18.06.2020 10:34:59): transmitter 2 registered as Wind
logger (18.06.2020 10:34:59): transmitter 3 registered as Temperature
logger (18.06.2020 10:34:59): transmitter 4 registered as Temperature
logger (18.06.2020 10:34:59): Meteostick Version 2.5.2
logger (18.06.2020 10:34:59): debug off
logger (18.06.2020 10:34:59): verbose off
logger (18.06.2020 10:34:59): output raw (8 bytes)
logger (18.06.2020 10:34:59): output raw (10 bytes)
logger (18.06.2020 10:34:59): filter on
logger (18.06.2020 10:34:59): rx threshold set to -90db
logger (18.06.2020 10:34:59): listening to transmitter 1 2 3 4
logger (18.06.2020 10:34:59): bandwidth narrow
logger (18.06.2020 10:35:00): chip authentication ok: 14
logger (18.06.2020 10:35:00): frequency band 868MHz (EU)
logger (18.06.2020 10:35:01): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (18.06.2020 10:35:01): services paused.
logger (18.06.2020 10:36:01): sensors are now providing data.
logger (18.06.2020 10:36:01): services started.
backup (19.06.2020 00:00:09): backup media size is 28.8G (26.3G free).
backup (19.06.2020 00:00:44): backup completed: dbase-202006190000 (46.0M)
backup (20.06.2020 00:00:09): backup media size is 28.8G (26.2G free).
backup (20.06.2020 00:00:38): backup completed: dbase-202006200000 (46.0M)
logger (20.06.2020 01:56:00): databases connected. Update interval 3600 seconds.
logger (20.06.2020 01:56:00): data logger (version 5.1d, build 13568) started.
logger (20.06.2020 01:56:00): error (125) while doing bind (port 5551): Address already in use
logger (20.06.2020 01:56:00): killed process "24180/sh" listening to port 5551.
logger (20.06.2020 01:56:29): databases connected. Update interval 3600 seconds.
logger (20.06.2020 01:56:29): data logger (version 5.1d, build 13568) started.
logger (20.06.2020 01:56:29): error (125) while doing bind (port 5551): Address already in use
logger (20.06.2020 01:56:29): killed process "24183/meteosys" listening to port 5551.
logger (20.06.2020 01:56:59): databases connected. Update interval 3600 seconds.
logger (20.06.2020 01:56:59): data logger (version 5.1d, build 13568) started.
logger (20.06.2020 01:57:00): connect station 0 (Meteostick Vantage via USB serial).
logger (20.06.2020 01:57:00): connect station 9 (System Data via Plug-in).
logger (20.06.2020 01:57:00): transmitter 1 registered as ISS
logger (20.06.2020 01:57:00): transmitter 2 registered as Wind
logger (20.06.2020 01:57:00): transmitter 3 registered as Temperature
logger (20.06.2020 01:57:00): transmitter 4 registered as Temperature
logger (20.06.2020 01:57:00): Meteostick Version 2.5.2
logger (20.06.2020 01:57:00): debug off
logger (20.06.2020 01:57:00): verbose off
logger (20.06.2020 01:57:00): output raw (8 bytes)
logger (20.06.2020 01:57:00): output raw (10 bytes)
logger (20.06.2020 01:57:00): filter on
logger (20.06.2020 01:57:00): rx threshold set to -90db
logger (20.06.2020 01:57:00): listening to transmitter 1 2 3 4
logger (20.06.2020 01:57:00): bandwidth narrow
logger (20.06.2020 01:57:01): chip authentication ok: 14
logger (20.06.2020 01:57:01): frequency band 868MHz (EU)
logger (20.06.2020 01:57:03): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (20.06.2020 01:57:03): services paused.
logger (20.06.2020 01:58:02): sensors are now providing data.
logger (20.06.2020 01:58:02): services started.
logger (20.06.2020 02:37:05): databases connected. Update interval 3600 seconds.
logger (20.06.2020 02:37:05): data logger (version 5.1d, build 13568) started.
logger (20.06.2020 02:37:05): error (125) while doing bind (port 5551): Address already in use
logger (20.06.2020 02:37:05): killed process "5720/sh" listening to port 5551.
logger (20.06.2020 02:37:35): databases connected. Update interval 3600 seconds.
logger (20.06.2020 02:37:35): data logger (version 5.1d, build 13568) started.
logger (20.06.2020 02:37:35): error (125) while doing bind (port 5551): Address already in use
logger (20.06.2020 02:37:35): killed process "5721/meteosys" listening to port 5551.
logger (20.06.2020 02:38:05): databases connected. Update interval 3600 seconds.
logger (20.06.2020 02:38:05): data logger (version 5.1d, build 13568) started.
logger (20.06.2020 02:38:06): connect station 0 (Meteostick Vantage via USB serial).
logger (20.06.2020 02:38:06): connect station 9 (System Data via Plug-in).
logger (20.06.2020 02:38:06): transmitter 1 registered as ISS
logger (20.06.2020 02:38:06): transmitter 2 registered as Wind
logger (20.06.2020 02:38:06): transmitter 3 registered as Temperature
logger (20.06.2020 02:38:06): transmitter 4 registered as Temperature
logger (20.06.2020 02:38:06): Meteostick Version 2.5.2
logger (20.06.2020 02:38:06): debug off
logger (20.06.2020 02:38:06): verbose off
logger (20.06.2020 02:38:06): output raw (8 bytes)
logger (20.06.2020 02:38:06): output raw (10 bytes)
logger (20.06.2020 02:38:06): filter on
logger (20.06.2020 02:38:06): rx threshold set to -90db
logger (20.06.2020 02:38:06): listening to transmitter 1 2 3 4
logger (20.06.2020 02:38:06): bandwidth narrow
logger (20.06.2020 02:38:06): chip authentication ok: 14
logger (20.06.2020 02:38:06): frequency band 868MHz (EU)
logger (20.06.2020 02:38:09): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (20.06.2020 02:38:09): services paused.
logger (20.06.2020 02:39:07): sensors are now providing data.
logger (20.06.2020 02:39:07): services started.
logger (20.06.2020 02:58:12): child process received termination signal (11) in functions: termination_handler < inetupload_getline < inetupload_getline < inetupload_getline < inetupload_getline < inetupload_getline < inetupload_getlin...
logger (20.06.2020 02:58:12): disconnect station 0 (Meteostick Vantage): exit
logger (20.06.2020 02:58:12): disconnect station 9 (System Data): exit
logger (20.06.2020 02:58:14): databases connected. Update interval 3600 seconds.
logger (20.06.2020 02:58:14): data logger (version 5.1d, build 13568) started.
logger (20.06.2020 02:58:14): connect station 0 (Meteostick Vantage via USB serial).
logger (20.06.2020 02:58:14): connect station 9 (System Data via Plug-in).
logger (20.06.2020 02:58:15): transmitter 1 registered as ISS
logger (20.06.2020 02:58:15): transmitter 2 registered as Wind
logger (20.06.2020 02:58:15): transmitter 3 registered as Temperature
logger (20.06.2020 02:58:15): transmitter 4 registered as Temperature
logger (20.06.2020 02:58:15): Meteostick Version 2.5.2
logger (20.06.2020 02:58:15): debug off
logger (20.06.2020 02:58:15): verbose off
logger (20.06.2020 02:58:15): output raw (8 bytes)
logger (20.06.2020 02:58:15): output raw (10 bytes)
logger (20.06.2020 02:58:15): filter on
logger (20.06.2020 02:58:15): rx threshold set to -90db
logger (20.06.2020 02:58:15): listening to transmitter 1 2 3 4
logger (20.06.2020 02:58:15): bandwidth narrow
logger (20.06.2020 02:58:15): chip authentication ok: 14
logger (20.06.2020 02:58:15): frequency band 868MHz (EU)
logger (20.06.2020 02:58:16): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (20.06.2020 02:58:16): services paused.
logger (20.06.2020 02:59:16): sensors are now providing data.
logger (20.06.2020 02:59:16): services started.
logger (20.06.2020 03:18:19): child process received termination signal (11) in functions: termination_handler < inetupload_getline < inetupload_getfilteredline < generate_loggerevalfile < generate_loggerfile < gen_CLIENTLOGFILE < gen_...
logger (20.06.2020 03:18:19): disconnect station 0 (Meteostick Vantage): exit
logger (20.06.2020 03:18:19): disconnect station 9 (System Data): exit
logger (20.06.2020 03:18:20): databases connected. Update interval 3600 seconds.
logger (20.06.2020 03:18:20): data logger (version 5.1d, build 13568) started.
logger (20.06.2020 03:18:21): connect station 0 (Meteostick Vantage via USB serial).
logger (20.06.2020 03:18:21): connect station 9 (System Data via Plug-in).
logger (20.06.2020 03:18:21): transmitter 1 registered as ISS
logger (20.06.2020 03:18:21): transmitter 2 registered as Wind
logger (20.06.2020 03:18:21): transmitter 3 registered as Temperature
logger (20.06.2020 03:18:21): transmitter 4 registered as Temperature
logger (20.06.2020 03:18:21): Meteostick Version 2.5.2
logger (20.06.2020 03:18:21): debug off
logger (20.06.2020 03:18:21): verbose off
logger (20.06.2020 03:18:21): output raw (8 bytes)
logger (20.06.2020 03:18:21): output raw (10 bytes)
logger (20.06.2020 03:18:21): filter on
logger (20.06.2020 03:18:21): rx threshold set to -90db
logger (20.06.2020 03:18:21): listening to transmitter 1 2 3 4
logger (20.06.2020 03:18:21): bandwidth narrow
logger (20.06.2020 03:18:22): chip authentication ok: 14
logger (20.06.2020 03:18:22): frequency band 868MHz (EU)
logger (20.06.2020 03:18:24): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (20.06.2020 03:18:24): services paused.
logger (20.06.2020 03:19:23): sensors are now providing data.
logger (20.06.2020 03:19:23): services started.
logger (20.06.2020 04:18:28): child process received termination signal (11) in functions: termination_handler < inetupload_getline < inetupload_getline < inetupload_getline < inetupload_getline < inetupload_getline < inetupload_getlin...
logger (20.06.2020 04:18:28): disconnect station 0 (Meteostick Vantage): exit
logger (20.06.2020 04:18:28): disconnect station 9 (System Data): exit
logger (20.06.2020 04:18:29): databases connected. Update interval 3600 seconds.
logger (20.06.2020 04:18:29): data logger (version 5.1d, build 13568) started.
logger (20.06.2020 04:18:30): connect station 0 (Meteostick Vantage via USB serial).
logger (20.06.2020 04:18:30): connect station 9 (System Data via Plug-in).
logger (20.06.2020 04:18:30): transmitter 1 registered as ISS
logger (20.06.2020 04:18:30): transmitter 2 registered as Wind
logger (20.06.2020 04:18:30): transmitter 3 registered as Temperature
logger (20.06.2020 04:18:30): transmitter 4 registered as Temperature
logger (20.06.2020 04:18:30): Meteostick Version 2.5.2
logger (20.06.2020 04:18:30): debug off
logger (20.06.2020 04:18:30): verbose off
logger (20.06.2020 04:18:30): output raw (8 bytes)
logger (20.06.2020 04:18:30): output raw (10 bytes)
logger (20.06.2020 04:18:30): filter on
logger (20.06.2020 04:18:30): rx threshold set to -90db
logger (20.06.2020 04:18:30): listening to transmitter 1 2 3 4
logger (20.06.2020 04:18:30): bandwidth narrow
logger (20.06.2020 04:18:31): chip authentication ok: 14
logger (20.06.2020 04:18:31): frequency band 868MHz (EU)
logger (20.06.2020 04:18:33): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (20.06.2020 04:18:33): services paused.
logger (20.06.2020 04:19:32): sensors are now providing data.
logger (20.06.2020 04:19:32): services started.
logger (20.06.2020 04:49:05): child process received timeout signal (14).
logger (20.06.2020 04:49:05): disconnect station 0 (Meteostick Vantage): exit
logger (20.06.2020 04:49:05): disconnect station 9 (System Data): exit
BB
